Question about Canon EOS 600D Rebel T3i Digital Camera
Canon 600D LCD screen display problems
Hi, I have a Canon 600D. The LCD screen is only showing the top half. I first thought it was due to low battery, but this has not changed after I charged the battery. I can no longer see the bottom half of the screen and I have tried different settings. It also means I can not use part of the settings. Do you have any suggestions on how to resolve this?
  • Johanna Pronk
    Johanna Pronk Feb 11, 2014
    The camera has now gone in for repair and replacement of the LCD screen.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
Cables on the LCD screen needs replacement go to the nearest service center
Posted on Aug 22, 2014
t00nz
  • 4738 Answers
SOURCE: CANON A70 CAMERA
First try pressing the "DISP" button. If that doesn't work, try downloading a picture. Is the picture also black? If so, it's probably a defective CCD imager. Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Mar 09, 2008
josephmanoj
  • 71 Answers
SOURCE: Battery Problem
The batteries u r using for your camera are of very low rating or low ampere output, you should use atleast 2100mAhr rating batteries and you will be very much satisfied with the performance.
Regards,
Manoj Joseph
+91 9352008418
Posted on Jun 16, 2008
Testimonial: "Perfect solution!"
welcomejee
  • 10594 Answers
SOURCE: canon a95 display problem black screen
Does your A95 Canon shows old pictures in card? if yes, its problem with CCD Imager in your camera and Canon has free repair scheme for this problem. Please click Canon Advisory for details.
Regards,
Posted on Sep 11, 2008
SOURCE: Canon S3 no display on LCD screen
for the person whose screen is blank but the photos work- I had the same problem and solved it by replacing the smaller date/time battery which slides out of the larger battery copartment. The battery is a CR1220 smaller than a dime and even flatter. Hope this works for you.
Posted on Dec 31, 2008
SOURCE: No Display on Canon S3 LCD
Mine was the "optical assembly"
I wrote Canon's president pointing out all these postings about this issue and how the other earlier Powershots and A models had this issue and were part of service recalls. I compared Canon to Toyota, hoping it wasn't aware of the problem despite all the online chatter. I also said I was sad I could no longer recommend buying high end Canon photo or video products to organizations any more all over them not wanting to do a $130 repair on a widely publicized issue.
Outcome. I heard promptly from a Canon rep. They paid for speed shipping to Chicago service center. I had it back in 3 days, fixed for free. The repair sheet says "the optical assembly did not operate propoerly causing no image output... it was replaced..."
Posted on Mar 11, 2010
I have the canon 600d its flashing on the screen exp.sim please help
HI, the message indicates that the Exposure Simulation feature has been enabled, approximating the brightness of the final image on the rear panel LCD screen. It occurs in low light and is not a camera problem or error. Hope this helps.
Jul 13, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Sunlight prevents me from seeing my monitor
If you mean the LCD display on the back of the camera you can adjust the brightness in the camera menu. Press the menu button, move to the yellow spanner with 2 dots top right, below this you'll see LCD brightness, highlight this and press set you'll then go to another screen showing a scale 1 to 7 use the left / right button to move the pointer closer to 7 to increase the screen brightness.
May 19, 2014 | Canon EOS 600D Rebel T3i Digital Camera
What can I do to prevent sunlight from seeing my monitor
If your problem is that sunlight makes it difficult to see what is displayed on the LCD screen, you can make the LCD display brighter by going through the menus to the option to adjust the LCD brightness. Move it to the brightest setting and see if that makes enough difference. You can also buy an LCD hood to shield it from the sun. Hope this helps!
Canon 600D.LCD screen display problem
If the full size image is being recorded on the memory card then you may need a repair job. First try formatting the card in the computer and format again in the camera also try a different card. If the problem persists get a repair quote.
Sep 30, 2017 | Canon EOS 600D Rebel T3i Digital Camera
A blue vertical line appear on my screen when using the lcd on 600D. Though it doesn't appear on the pictures. How can I fix this?
Most common cause is a defective LCD unit (possibly impact) but it can be caused by a defect in the imaging circuit on the rear circuit board. Replacing this board requires software to initialize it before use that is not available
Oct 06, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Canon LCD screen flickering in picture mode
either you have a bad LCD, it is not connected properly, or the image section of the main circuit is bad. Take it back and demand they give you another one
Jul 03, 2013 | Canon EOS 600D Rebel T3i Digital Camera
Blank lcd
Hi there:
Some symptoms of a defective CCD include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
A CCD problem would explain the lines on your pictures and the lines on the LCD (since the CCD is used to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used in digital cameras.
When a picture is taken, the CCD is struck by light coming through the camera's lens. Each of the thousands or millions of tiny pixels that make up the CCD convert this light into electrons. The number of electrons, usually described as the pixel's accumulated charge, is measured, then converted to a digital value. This last step occurs outside the CCD, in a camera component called an analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details:Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Nov 20, 2012 | Canon EOS 600D Rebel T3i Digital Camera
Autofocus canon 600d
There is a seperate sensor for the autofocus. IT is either bad or dirty. You may not be able to clean it either.
Jul 18, 2012 | Canon EOS 600D Rebel T3i Digital Camera
Screen on laptop is distorted halfway
A) Video Cable connections are loose:
Connection at the motherboard, and the connection at the back of the LCD screen, in the Display Assembly.
Both need to be checked.
[For Toshiba the Video Cable is termed LVDS Cable.
Low-Voltage Differential Signaling Cable. I will just keep referring to it as the Video Cable ]
B) Video Cable is damaged:
Observe the sheath at the motherboard side of the Video Cable?
Is there obvious signs of damage to the sheath of the cable?
If so, there may also be damage to the tiny, thin wires inside the sheath, of the Video Cable.
Due to the routing of the Video Cable under the left Hinge, the Video Cable may be pulled on. This can create a bad connection.
Due to the above also, the Video Cable's sheath may be damaged, and the wires inside.
A view of the Video Cable by itself,
http://www.batterystyle.com/toshiba-satellite-a205-s5880-cable-p-484063.html
If the Video Cable checks out to be OK, the next item is the screen Inverter.
To test a screen Inverter you need a sensitive multimeter. This usually means expensive. { Or use a known to be good, compatible screen Inverter } Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter. {Or LCD screen)
Most consumers decide to just replace the screen Inverter because;
1) If the problem isn't the screen Inverter, it is the LCD screen.
(A LOT of people buy an LCD screen, when all they really needed was a screen Inverter)
An EXPENSIVE part.
(LCD screen? $150 to $400 approximately. Screen Inverter? Usually around $22 to $48 )
2) The ease of access to replace.
As stated, if the problem isn't the screen Inverter, then it is the LCD screen.
1) With ALL power removed, AC adapter (Charger), and Battery, remove the Keyboard Bezel, and the Keyboard.
This is the motherboard connection side.
Display Assembly removed with Video Cable.
Now remove the Display Bezel, and LCD screen assembly, to access the Video Cable connection to the back of the LCD screen.
{NOTE*
The screen Inverter is mounted at the bottom of the LCD screen, and behind the Display Bezel }
This shows the Video Cable, and it's connection at the motherboard side,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-2.htm
Scroll down, click on the photo in Step 9.
The Video Cable is the cable to the upper Left side. Has one Red arrow pointing to the left.
The photo in Step 10 shows the Video Cable disconnected from the motherboard.
(This is Page 2 of a disassembly guide. Pages 1 through 4 are available above, and below. Page1::Page2::Page3::Page4::Find another model,
in white.
Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter, or LCD screen) )
2) LCD screen side:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-4.htm
http://www.insidemylaptop.com/remove-lcd-screen-from-toshiba-laptop/
All three links above will help you with checking the connections, or removing the cable to perform a continuity check. (Test)
Also with accessing the screen Inverter, and LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 25, 2012 | Toshiba Satellite A205-S5880 Notebook
Canon EOS 600D Rebel T3i Digital Camera Logo
186 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
