Question about Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
Carb fuel FLOODING ON IH 806 TRACTOR - Farmall IH Tractor 706, 756, 806, 856, 1206, ITIH32
What year is my ih 706?
I think they were made from 1963 to 1967. Yours was made between '64 an '65.
Jul 02, 2015 | Farmall IH Tractor 706, 756, 806, 856,...
I have a 806 keeps slipping out of high gear
Did you find a solution yet , I have and 806 also and it does the same thing
Feb 14, 2013 | Farmall IH Tractor 706, 756, 806, 856,...
F 806 rear lift stays up, unless tractor is off....
i would think that the lift control handle is stuck in the lift position, and when the engine is on the fluid will bypass the control handle and thus raising the lift. replacing or repairing the control should solve the problem. good luck
jim
Oct 16, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Iam working on a 706 case IH gas. it hasent ran in many years. i draned all the old gas and rinsed the tank. and gas lines. new plugs points distributer, roter, plug wires. still nothing. i have spark....
carb is probably gummed up from the old gasoline. try squirting some gas into the carb where the air goes in to start it. probably won't keep running but sometimes it can shake something loose like a stuck FlOAT VALVE.
Aug 18, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Where is hydraulic filter located on IH 706 Tractor?
right hand side -teardrop shaped cover bolted to side of transmission should only lose a gallon or so of oil when changing
Aug 06, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
My steering on my 806 Farmall gets stiff, but I mash my breaks and it loosens up. What can it be?
More than likely the issue is in the multiple control valve that feeds both the brakes and the steering. It bolts to the left front of the tranny, right under the battery. While you're in there, it's a good time to re-gasket the pump. Buy yourself an I & T book, # IH-32. You'll need it! Also, don't lose the spring and check valve when you pull the control valve off the tractor!
Mar 15, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Slow acceleration low on power ih 1206 air filters new, good fuel supply turbo ok
have you checked fuel filters? make sure that fuel shutoff valve is fully open, and that your fuel is clean/water-free,and hasn't cold-weather gelled
Feb 01, 2010 | Farmall IH Tractor 706, 756, 806, 856,...
Farmall IH  Tractor 706, 756, 806, 856, 1206, ITIH32 Logo
24 people viewed this question
Top Farmall Toys Experts
Wayne Fellows
Wayne Fellows
Phil Walker
Phil Walker
Jerry Radcliffe
Are you a Farmall Toy Expert? Answer questions, earn points and help others
