Question about Garden
Runs and then stops
Run for a bit then motor stops
    Sergeant:
    Champion:
  • 266 Answers
Classic carburettor problem. B and Stratton sell a replacement kit
Posted on Mar 21, 2014
Ice maker stopped, freezer not freezing
Is the compressor running? Is the unit getting power to the motor? Unless that motor is running nada is going to work.
If the compressor is getting power and it is not running then the unit has seized. It will hum for a bit and then blow the circuit breaker.
If the compressor uses a starting capacitor, check to make sure that it is good.
Jun 28, 2015 | Refrigerators
Once the bit is tighten, the motor is to tight to run. It runs for half a second then freezes up
It sounds as though you have a motor problem, The bit, tight or loose shouldn't matter.
Sep 30, 2014 | Tools & Hardware - Others
BMW Z4 convertible top opened and now wont close. Motor runs then stops. Latch is stuck and the emergency pull cord will not release. How do I get to the latch to free the top?
try a spray lubricant into the motor mechanism and grease any visable wire cables that run from/to motor ,not the electrical cables the bare wire winder cables,also grease/ lubricate any accessable pivot/hinge points , gently pull the cord and gently push the roof back and forth occasionally trying motor with a bit of patience this should get the roof moving , also look for anything that may be snagging the roof/mechanism as there is a pressure protection system to stop the roof being fully closed on say someones hand so preventing injury
May 03, 2014 | 2004 BMW Z4 Roadster
Oscillating drum sander runs a few minutes and stops
This usually occurs if the motor is overheating and the internal circuit breaker is tripping. After it cools down, it self resets. This can be caused by bad bearings or parts dragging the motor down, making it work hard enough to over heat and trip the breaker. If you are running it on an extension cord or circuit that isn't able to provide it with the amps it needs the motor will overheat and trip the breaker also.
Dec 02, 2012 | Delta 17-960 Oscillating Spindle Sander...
I have a NordicTrack c2200. I find that the tread belt is not running smoothly while running on it. As I run, the belt temporarily stops during each running step, causing me to trip up. I tried to lube,...
There are a couple possibilities.
Remove the motor cover and run the machine.
Check the tension of the motor belt. It may need to be tightened. 2manyhobbies.jpg
Check that the pulley has not broken free from the front roller by stopping the walking belt when the machine is running. If the belt stops, but the motor and pulley keep turning, the pulley has broken free from the front roller.
If this is the case, with a drill and small drill bit, drill a hole through the pulley and roller on the inside edge of the pulley, between the ribs (not where the motor belt travels) and put a screw through the plastic into the metal roller.
Otherwise, change the roller.
Good Luck.
Dec 30, 2010 | Nordic Track Exercise & Fitness
My gas dryer has started making a metallic screeching sound after its been running for a bit. Its coming from the rear of the dryer. I'm concerned that it might be the motor. It kind of comes and goes and...
Could have been that the alignment is out of way andis rubbing on when in a particular direction or with the load.
As you have observed the motor could be the issue , it will be good to open and look for the movement of the motor.
The suspensions can be a little out of alignment . also place the dryer in a level postion.
Check for uneven running due to any friction of the drive. If so it can agitate and make it rub on the sides.
Aug 31, 2010 | Dryers
Motor stops running after starting
You might also find that the fuel filter is in need of a cleaning. Sitting that long can lead to a bit of rust dust in the tank, specially if you have given it a push.
Oct 27, 2008 | 1987 Mazda 323 4-Door
GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
I gather that it is the outdoor fan motor that runs a bit then stops.
Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
Jul 22, 2008 | Heating & Cooling
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
