Question about Max Factor Pancake Makeup Tan 1 (Max Factor)
Where can get tan # 1 - Max Factor Pancake Makeup Tan 1 (Max Factor)
Identifix not showing color wiring harness for power coming from o2 sensor to ECM on 2003 G3500 6.0
Which O2 sensor ? There are four , Bank 1 sensor 1 Purple / white stripe an Tan . Bank 1 sensor 2 tan/white an PPL/ white Bank 2 sensor 1 PPL an Tan Bank 2 sensor 2 Tan an PPL .
May 18, 2016 | Cars & Trucks
How do you find the degree from tan
To calculate the arctangent, use 2ND TAN. For example, to calculate the arctangent of 1, press 2ND TAN 1 ENTER
Nov 20, 2013 | Texas Instruments TI-83 Plus Calculator
Use the identity tan(x/2)=sinx/1+cosx to solve for the value of tan45 degrees
tan(x/2)=sin(x)/(1+cos(x))
Setting x/2=45, means that x=90 (degrees)
But cos(90)=0 and sin(90)=1. Thus tan(45)=1/(1+0)=1.
Mar 13, 2013 | SoftMath Algebrator - Algebra Homework...
Cot(x) = -0.6
Let's start with a little background.
The cot(x) is also known as the cotangent(x) and it equals 1/tan(x) which equals cos(x)/sin(x). I'm showing these formulas because your calculator may not have a cot button but it will probably have buttons for tan, cos, and sin.
Your calculator may also have buttons for tan-1, cos-1 and sin-1. These are the inverse functions for tan, cos, and sin. If you enter a number and then push the tan-1 button, the result is the angle whose tangent is the entered number. For example, it you enter 1 and push the tan-1 button the answer will be 45 deg because tan (45 deg) = 1.
Now let's look at the problem, cot(x) = -0.6.
The first thing we need to know is do you want the answer in degrees or radians? Your calculator will have both modes. The default mode when you first turn it on is probably degrees. If this problem is in radians you will need to change the mode of your calculator over to radians before we start.
If cot(x) = -0.6, then tan(x) = 1/-0.6 from the formula I showed in the background section.
This means tan(x) = -1.6666666...
Now we just enter -1.66666667 and hit the tan-1 button to get the answer.
If we're operating in radians the answer is -1.0307 radians.
If we're operating in degrees the answer is -59.036 deg.
I hope this helps you out.
Dec 06, 2011 | SoftMath Algebrator - Algebra Homework...
Trying to figure out how to do cotangent, the problem says cot A= 1.71 we are supposed to solve for a degree
cot( A) =1/tan( A)l Your equation can be cast as tan(A) =1/1.71. To find the arc (angle A) you use the arc tangent or tan^-1 (SHIFT TAN).
You type in [SHIFT][TAN] (1/1.71) [EXE]
Apr 13, 2011 | Texas Instruments TI-30XA Calculator
How to get to the arctan on a TI-36
I have a TI-36X Pro, you have to press the tan button two times.
Mar 08, 2011 | Texas Instruments TI-36 X Solar Calculator
What do i punch in get a decimal answer from tan 19 degrees 45'
If you have the angular mode set to degrees,
TAN 1 9 2ND [ANGLE] 1 4 5 2ND [ANGLE] 2 ENTER
If you have the angular mode set to radians,
TAN 1 9 2ND [ANGLE] 1 4 5 2ND [ANGLE] 2 2ND [ANGLE] 1 ENTER
Jan 26, 2011 | Texas Instruments TI-84 Plus Silver...
How to solve for the trigonometric functions in the casio scientific calculator?
Press the relevant function key [SIN],[COS],[TAN] followed by the angle value.
For inverse trigonometric functions [SIN^-1], COS^-1], or [TAN^-1], Press [SHIFT][SIN], [SHIFT][COS], or [SHIFT][TAN].
For other functions
sec(x)=1/cos(x)
csc(x)=1/sin(x)
cot(x)=1/tan(x)
When calculating trigonometric functions one must make sure that the angle unit the calculator is using is the correct one.
Aug 26, 2010 | Casio FX-115ES Scientific Calculator
(1+cotx-cosecx)(1+tanx+secx)=2
I shall attempt :D
1) cosec A + cot A = 3
we know that (cot A)^2 + 1 = (cosec A)^2
Hence, (cosec A)^2 - (cot A)^2 = 1
thus, (cosec A + cot A) (cosec A - cot A) = 1
3 (cosec A - cot A) = 1
(cosec A - cot A) = 1/3
(cosec A + cot A) = 3
Summing them, 2 cosec A = 3 1/3
cosec A = 6 2/3 = 5/3
sin A = 0.15
Thus, cos A = sqrt (1 - (sin A)^2) = 0.989
2) Prove that (1+tan x - sec x)(1 + cot x + cosec x) =2
expand
LHS= 1 + cot x + cosec x + tan x + 1 + tan x cosec x - sec x - sec x cot x - sec x cosec x
We can calculate that
tan x cosec x = sec x (since tan x = sin x / cos x)
sec x cot x = cosec x
so the above is
LHS = 1 + cot x + cosec x + tan x + 1 + sec x - sec x - cosec x - sec x cosec x
LHS = 2 + cot x + tan x - sec x cosec x
LHS = 2 + cos x / sin x + sin x / cos x - 1 / (sin x cos x)
LHS = 2 + [{cos x}^2 + {sin x}^2 - 1] / (sin x cos x)
LHS = 2 (proved)
May 12, 2009 | ValuSoft Bible Collection (10281) for PC
Max Factor Pancake Makeup Tan 1 (Max Factor) Logo
Top Max Factor Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Max Factor Health and Beauty Expert? Answer questions, earn points and help others
