Question about Frigidaire GLTF2940ES Front Load Washer
Washer fills then shuts off
Washer will fill with water then turns off. It will pump out the drum but won't spin.
  • Official Brand Answer
  • 4,342 Answers
Hi scottterriz, I am happy to assist you!
Often when your washer does not spin, it is because your appliance cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your appliance.
Hope this helps!
Posted on Feb 11, 2014
4 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: washer go though all cycles but no spin
not a mechanical timer in this one..
Posted on Aug 30, 2007
  • 1122 Answers
SOURCE: My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
Posted on May 29, 2008
jyackle5
  • 8197 Answers
SOURCE: my siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Posted on Dec 16, 2008
Washer won't fill
check to make sure your clothes are not covering the middle of the drum it has a sensor there for the water to come in
Feb 02, 2013 | Whirlpool WTW57ESVW 4.0 Cu. Ft. Top Load...
Washer fills but won't agitate or spin
Try making sure the belts are actually on the drum, probably have to turn upside down. Sounds silly but a lot of simple things are missed.
Apr 02, 2012 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Will not fill with water but works on spin cycle
If your washer won't fill with water, but works in the spin cycle then the washer is sensing that water is in the tub. If there isn't water in the tub, then it is probably a sensor. If there is water but the spin cycle doesn't get it out, then look at the pump or control board.
Jun 08, 2011 | Maytag Washing Machines
Washing machine will fill with water, but won't spin.
hi there.
If the washer won't drain or spin there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014
SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...
or go to this link for more help.
Washing machine will fill with water but won spin Google Search
Nov 18, 2017 | Whirlpool 3.2 cu. ft. Plus Washer
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
67 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
