Question about Watches
What battery does the Swiss Army Watch Model 24228 take?
I have a Swiss Army watch Model 24228 and it needs a battery. Someone took out the original, so I don't know which one it takes.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Just tell us what Friggin battery # it cslls far. If we needed a jeweler, we’d call one!
Posted on Jan 02, 2018
SOURCE: swiss army watch
Did you have the battery checked to see if it was bad a first? Take it to a Reputable watchrepair , and ask them to CHECK your battery NOT replace it. Alot of times your watch will have a mechanical problem which will make your watch look like it is o.k. once you replace the battery but, two weeks later the watch stops again because the battery has lost enough power to now stop the watch again. Also your watch may have a electrical problem which a battery will not solve the problem. The coil (the orange straight piece in the movement), or the curcit board could be bad. Always have the store check your battery because, if you ask them to change your battety they will no matter if your original battery is good or not.
Posted on Sep 09, 2008
  • 65 Answers
SOURCE: swiss army stopped
If qz. see previous answer. If it's mechanical and absolutely all the moisture is not eradicated then rust may begin to form and will over time cause damage. So if it's mechanical take it to a watchmaker for servicing asap.
Please rate my solutions.
Posted on Jul 27, 2009
disap1
  • 98 Answers
SOURCE: how to take links out of the band of a wenger
Save yourself the time and frustration and take it to a reputable watch repair shop and let them adjust your band for you. Could be screws or could be pins! Plus if anything small drops you might not find it again!
Posted on Jan 20, 2010
  • 299 Answers
SOURCE: How to remove the back cover of the swiss army
The back will either have a small slot on one edge to pry it off or indentations around the perimeter for a case wrench to unscrew it. Specialized tools are used to avoid scratching the case. You best bet is to take it to a watch shop and let them do it. Most places charge between $3 - $8 to properly do it without damaging the case and they should also change the gasket to maintain water resistance if so equipped. Once you have it open you risk damaging the movement as you change the battery. It's not that it's a tricky procedure but you can easily damage something that will cost a LOT more than $8 to fix if you don't have experience.
Posted on Apr 10, 2010
gemineye61
  • 831 Answers
SOURCE: Does the Swiss Army Wenger
Yes, it has a Swiss Quartz movement, so a battery is what makes your watch work. Need a new battery? Take it an authorized dealer or other business that has the right tool to open the case. It's not worth ruining an expensive watch just to save a couple of dollars to change the battery.
Posted on Aug 19, 2010
Swiss army watch S.A.W CO. Where do we find a list of model numbers. Model number 1789A 00146 I cant find on internet.
Swiss Army Watch S.A.W. Co was acquired at 2002 by VICTORINOX. You can find information about prouct at
VICTORINOX website and you can get more information through teit CONTACT link.
http://www.victorinox.com/ch/content/contact_us?lang=en&
Apr 23, 2015 | Swiss Army Watches
Swiss army watch 241083, what battery does it take
Any Brand, Type 371 1.55v. I replaced the same Swiss Army Victorinox Infantry Watch model 241083 specifically with the Energizer 371BPZ Zero Mercury Battery. BTW, the replaced original was also a 371.
Jun 30, 2013 | Swiss Army Watches
Does the Swiss Army Wenger Alpine 72558 Wrist Watch take a battery?
Aug 19, 2010 | Swiss Army Wenger Alpine 72558 Wrist Watch
How do you open back to change battery?
Swiss Army watches require a special tool. You will need to call your local jewelers and ask if they do Swiss Army watches as not every jeweler has the tool to do it.
Good luck
Jul 19, 2010 | Swiss Army Wenger Standard Issue 70609...
The second hand jumps forward every 5 seconds but the watch still keeps time OK.
You need to replace battery.
Q/A from swiss army website.
Q. How do I know when the battery needs changing?
A. In select models, the battery end-of-life indicator signals that the battery should be replaced within two or three days. When the battery is low, the second hand stands still for 2-4 seconds, and then speeds up to the correct time. This indication will last for approximately one week, and then the timepiece hands stand still.
Jul 02, 2010 | Swiss Army Wenger Victorinox Swiss Army...
Can't get the hour hand or minute hand to move
If your watch is genuine SWISS ARMY made, then follow this link, choose your watch and download the instructions (movie style): http://www.swissarmywatches.co.uk/index.htm
Feb 04, 2010 | Swiss Army Wenger Victorinox Swiss Army...
Swiss army stopped, im stressing..
If it's a quartz (battery powered) watch test the voltage of the battery. If below 1.5v then replace with new. Ensure battery contacts make good contact with the battery and are free of corrosion/rust/contamination of any sort. Check operating manual for any specifics regarding battery replacement proceedure.
Jul 26, 2009 | Watches
Swiss army watch
Sep 09, 2008 | Watches
Wenger watch
swiss army watch had battery replaced after stopping, will not restart, replacement battery new and good.
Apr 22, 2008 | Swiss Army Wenger Alpenrose 70450 Wrist...
Swiss Army watch 70609 second hand pauses
Battery life indicater just warning to get that battery replaced so it wont stop at an inconveinient time
Jan 09, 2007 | Swiss Army Wenger Standard Issue 70609...
Watches Logo
59 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
