Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
My start button to turn stove on wont work - Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Stove works oven wont turn on. now is reading fault code (SA6). what does that mean? and how do I fix the proble
If sab Push and hold clock button in for a few seconds.When it clears, the oven should work fine. God-Bless! Just let me know if that works. It is in sabbath mode. Research said it is sab not sa6,
Dec 28, 2015 | Maytag Range Oven Part - Oven Temperature...
Heater serial # 3687823 was working fine then just stopped. cant get it to light now
if the pilot lights when held but wont stay lit, the thermocouple is shot, local hardware stores sell universal thermocouples. self explanatory to replace. if even when pressing the button the pilot doesn't light there is a blockage in the gas line or control valve. that needs a pro to fix.
Mar 16, 2014 | Procom Heating & Cooling
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
The display and buttons are dead, no display or oven lights but electric starter still works on stove top
find the breaker for the stove and turn it off for 2 minutes then back on, if that does not work look on back of stove in area of controles for a small reset button, some time they are hidden just inside a small hole
Jan 09, 2014 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Did a cleaning on the stove. in middle of cleaning the stove started to smoke so they hit the off button. Now the stove wont open. How do we get the stove oven door to open?
All you have to do it wait and it will unlock itself. It just gets very hot so the stoves are made to seal themselves until cool!
Aug 17, 2011 | Ovens
How do i stop the igniter from clicking on my gas stove top all 4 burners are clicking and wont stop when turned off
lift the push button up a bit if dont work u need to replace the push button. bsc appliances uk...07779933829 postal service too.
Feb 27, 2011 | Stoves 600SiDOm Gas Kitchen Range
Stove door wont close
try shutting off power and then turn on..If this doesnt work turn on self clean again ,start it then after a few seconds cancel. This should tell the lock to release.
Mar 30, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
20 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
