Question about LG Washing Machines
Lg washer burning smell on spin - LG Washing Machines
IFIXALL
  • 868 Answers
SOURCE: Not spinning
You may have a frozen pump .Tilt the machine back so you can look under it and turn each pulley by hand if one isnt turning youll know whts wrong then.Please leave a rating!!
Posted on Jun 09, 2008
Lumpy816
  • 246 Answers
SOURCE: Maytag Washer will not spin
Pull the unit forwardand lean it back about 45 degrees. You'll have to play with it a bit, but once it's far enough out, it will lean back without you having to hold it. Remove and inspect the belt(s) are they in good condition? Next, check the pulleys (wheels) underneath. Do they turn? One is for your pump, one is for your transmission and one is for the motor. (in case one doesn't turn, you'll know what portion needs to be worked on). Also check the track on your pulley the belt sits in. Is it dammaged or worn?
Posted on Jun 16, 2008
duby1990
  • 367 Answers
SOURCE: Washer has burning smell and does not spin.
It sounds like your belt has burnt off. take the front off the washer or tip the washer back to check it. easy fix.
Posted on Nov 17, 2008
  • 17 Answers
SOURCE: Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Posted on Apr 10, 2009
  • 4090 Answers
SOURCE: washer wont spin, smells like burning glws1649
Burning smell could be the windings in the motor. Better not to use it and have it looked at. If the smell is a rubber smell then the belt is jammed while the motor spins. still needs intervention as it can catch on fire and you will have a bigger problem than the one you have now
Posted on Jul 31, 2009
I have a burning smell coming from my LG front load washer. I googled it,it says it's the bearings. Which would be easier? Buying a different drum with bearings already pressed in or doing my own?
Holly, always easier to buy an assembly, but probably a lot more expensive. If you can remove bearing and take to a industrial supplier and get matching bearing, the cost would be a fraction of that of a new drum assy. If you or a friend can do it, go for it.
You may want to get a second opinion on what you are smelling, it very well could be the drum rubbing gasket if it is a burning rubber smell.Maybe call a good appliance Tech. have them diagnose and estimate repair. Check LG washer bearing link below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG washer Burning Smell Service 7o7 4451591
How to Diagnose Drum Problems in Washing Machine
GE Washer Smoking During Spin Cycle
Aug 21, 2016 | LG Washing Machines
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
https://www.youtube.com/watch?v=vKeIDM78CFI
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
https://www.youtube.com/watch?v=a-ONJ2_RQvk
Jul 7, 2013 - Uploaded by ApplianceVideo.com
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
LG WM2487*M Washer smells like burning rubber in spin cycle
Smells like, I mean sounds like, a belt is burning either from friction caused by a bad bearing, or, a loose belt is slipping on the pully a bit, causing it to heat up from the friction.
Dec 05, 2013 | LG WM2277H Front Load Washer
Wont spin correctly, burning smell
Sounds like the belt is loose and or worn. Take off the back and inspect the belt.
Nov 30, 2011 | LG WM-2277HW Front Load Washer
My washer LG WH2277HW won't spin and it has a burning smell to it.
Call out a service engineer as it needs to be looked at to see what is going on inside.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | LG WM-2277HW Front Load Washer
Washer wont spin, smells like burning glws1649
Jul 31, 2009 | Frigidaire Washing Machines
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Nov 17, 2008 | Washing Machines
LG WD-1234FH
You will need to have it checked by a qualified LG technician to see what is the deal with the burning odor.  And the noise is probably the washer not balanced correctly.
Oct 28, 2007 | LG WD-1080FD Front Load Washer
Washing Machines Logo
14 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
