Question about HP ScanJet Office Equipment & Supplies
Ubuntu scanjet 4500C
Ubuntu 13.10
Install 2400hp scanner step in ubuntu online autometically
Go to hp website for driver download and support,,they can help,,make sur u get the proper driver for ur product ,,for the windows os u have on your computer,good luck
Dec 23, 2011 | HP ScanJet 2400 Flatbed Scanner
I want to install my hp scanjet g4010 on ubuntu 11.04
you need a driver to do this, you can see this on the cartoon/box of your scanner or go to the nearest service center of HP. thanks
Jun 24, 2011 | HP Scanjet G4010 Flatbed Scanner
When try to scan, lamp warms up then message received is scanner could not scan. 22 is NOT blinking. The scanning mechanism begins move across the page but only moves about half inch.
The scanner may have one of two problems:
1. Scanner lamp has failed or does not come up to full color temp
2. Scanner attempts to initialize, which means it must move a bit to what is the "home" position where the scanner actually reads a very small coded imprint on the underside of the glass. If this area is too dusty or dirty, that will cause this problem, but also if the scanner motor and worm drive are binding for any reason, such as the scan rails internally being too dry this will also happen.
Locate a service manual and remove the copy glass by removing the lock guide on one side, the glass should lift partially, allowing some gentle cleaning with soft cloth and glass cleaner. Do not attempt to force the scanner to move inside, as it is worm gear driven and such an attempt will strip the nylon gears or worse.
Follow the manual instructions if you need to fully remove the top
cover, glass and platen assembly for cleaning. It is very simple once you are in the interior...but gentleness and care are necessary.
Sadly, parts are difficult to find for all scanners now, and it is often far more economical to replace with a new, low cost and higher performing, higher rez unit for $ 120 or less. Often a lot less.
Good Luck!
Aug 03, 2010 | HP ScanJet 4500C Flatbed Scanner
Hi, HP Scanjet 2200c (Scanner) does it work for windows 7?
Hi dorine...
HP Scanjet 2200c drivers (xp/vista/win7/win8/mac) can be found at driverupdate us It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Oct 07, 2009 | HP ScanJet 2200C Flatbed Scanner
All time I got this message driver is not found on windows NT, I don't have this windows, I have home XP, so what is the problem
NT = XP driver.
Be sure you got driver you need to run your printer.
follow installation instruction
Feb 16, 2009 | Samsung MJ 4500C InkJet Printer
Carriage jammed
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Oct 27, 2008 | HP ScanJet 4500C Flatbed Scanner
Cannot find driver for multi jet 4500c on xp
This site carries a link to driverguide.com, you will have to register at driverguide to be able to download the driver.
http://www.printer-drivers.com/drivers/118/118394.htm
Jul 23, 2008 | Samsung Office Equipment & Supplies
I have a SAMSUNG printer Model MultiJet 4500c.Please advis what color catridge or what number of lexmark I can use for this printer. Chaoho Meng
Hello there,
This printer can use the Lexmark color cartridge # 12A1980.
The black, FYI, is #12A1970.
Thanks,
Lolita
Apr 10, 2008 | Office Equipment & Supplies
21 people viewed this question
Seeker5211
Seeker5211
