Question about Lexmark Interact S605 All-in-One Color Inkjet Wireless Printer
Lexmark interact s605 touchscreen error af.100109
Error on touchscreen and printer is frozen. Tried to unplug. Cannot copy or scan or print. No response from touchscreen at all. Any ideas.
SOURCE: System error 000 carrier stall Presss power Key
I just pressed the power button while holding the carriers to the right, then cycled power again.
Seems to have solved at least the "banging" issue.
Posted on Jan 07, 2008
SOURCE: Lexmark X3350 Printer
Thanks for everyones help, what worked for me is to reinstall the software that came with the printer. Works just fine now.
Posted on Apr 23, 2008
SOURCE: Lexmark 2500 won't print but no error message
Yes,I unplugged the printer for several hours.  I also tried another printer and it would do the same thing.  No error message but would not print.
Posted on Oct 14, 2008
stabelabel
  • 51 Answers
SOURCE: Scanner and copier not working
You have a problem with printer need to contact Lexmark your scanner is probably broken.
Posted on Mar 16, 2009
Touchscreen parts
how to clear the cm2320 mfp printer,
note: printer switch on 50.2 fuser error
Dec 29, 2013 | Lexmark Interact S605 All-in-One Color...
I have a lexmark interact s605 and it wont feed the paper
First, try to unplug the power of the printer for about 30 seconds then plug it back in.
Second, update the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
Third, make sure that the paper is properly placed in the tray and the paper guides is set.
Nov 18, 2012 | Lexmark Interact S605 All-in-One Color...
Interact s605 printing upside down
You can change the settings under printing preferences, just follow the steps below:
1 With a document open, click File > Print.
2 Click Properties, Preferences, Options, or Setup.
3 Navigate to:
Advanced tab > 2-Sided Printing area > select On
Note: To use the settings defined in the printer, select Use Printer Settings.
4 Select either the Side Flip or Top Flip option. Side Flip is the setting most often used.
5 Click OK to close any printer software dialogs.
6 Click OK or Print.
To return to single-sided printing, navigate to:
Advanced tab > 2-Sided Printing area > select Off
Sep 01, 2012 | Lexmark Interact S605 Wireless All-in-One...
My lexmark s605 doesn't work, but the pinter and copier are all fine
Plug in usb cable from printer directly to computer then print something. If you're successful, try to print something. If you're on wireless connection, disconnect the usb cord and try to scan.
Aug 27, 2012 | Lexmark "interact s605 wireless all-in-one...
My lexmark s605 does not work
If you tried to reinstall, then the problem is not coming from your computer but the unit itself. If it does not go through the motion of scanning, then it is a problem in the power to the motor which is most likely "fried."
Lexmark S605 printing blue streaks
If you're still having problem with the printer, please contact us at LxkListens@Lexmark.com or http://bit.ly/boldchat.
May 11, 2012 | Lexmark Interact S605 Wireless All-in-One...
Lexmark s605 will not print in colour
Try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H. Also, perform a maintenance on the cartridges, to do that, on the control panel of your printer, press on the Ink Levels > More Options > Deep Clean Printhead.
Make sure that you're using genuine Lexmark cartridges.
Apr 28, 2012 | Lexmark Interact S605 Wireless All-in-One...
A605s (Printhead cannot move). And I have not found any obstructions. The printhead is over to the left and I cannot get it out.
The error could be due to an outdated firmware. Please follow the steps below to fix the problem:
1. From the printer control panel, press the Setup button > Maintenance > Replace Printhead, or for touchscreen panels, touch Ink Levels > More Options > Replace Printhead.
2. Open the printer cover. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Press the tab, and lift the latch. Pull up to remove the printhead. Close the printer cover then turn off the printer/unplug the printer from the power source.
4. Turn the printer back on. It will ask you to "Open Cover to Install the Printhead". Press the Cancel (Red X) button or the Home icon for the touchscreen panels. It should take you back to the "Copy" menu.
5. Proceed with the firmware update. Just go to Lexmark S600 Series Firmware Update.
6. Once the firmware update is successful, firmly re-insert the printhead.
If the error continues to display on the screen, please contact Lexmark Technical Support Center for additional assistance.
Aug 10, 2011 | Lexmark Interact S605 All-in-One Color...
My lexmark interact S605 touchscreen is not working properly. It won't display the home screen and has only a small part of the solutions updated showing. When I try to get it to go to main screen it...
Try to unplug the power adapter from the printer.
Wait at least 10 seconds before replugging the adapter to the printer. This will give enough time for the printer to reset itself. Also, make sure the power cord is plugged in straight to the power outlet in the wall, bypass any power surge devices.
If the problem continues, it could be a faulty power adapter issue. Please contact Lexmark technical support for additonal assistance.
May 05, 2011 | Lexmark Interact S605 All-in-One Color...
Lexmark Interact S605 All-in-One Color Inkjet Wireless Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
