Question about Toshiba Computers & Internet
Boot key not function - Toshiba Computers & Internet
    Top Expert:
  • Toshiba Master
  • 23,659 Answers
What do you mean Boot Key, there is no Boot Key.
Posted on Feb 09, 2014
I don't see my question but this could be a repeat. My screen states hit F2 or F12 to start but neither of my F keys will work. Please help. Thank you.
F2 or F12 or Delete gets you into the BIOS. Why do you want to go there? To boot normally just power down and back up. Leave the Function keys alone unless you have a reason to go to the BIOS. You can create a lot of havoc in there!
The only function key you might need is F8 which you keep tapping as the computer boots. That gets you into Boot Normally, Boot with Last Known good configuration or Boot to Safe Mode.
Apr 09, 2016 | Computers & Internet
What are the functions of the Fn keys when booting
In my laptop, there is no any functions using Fn keys when booting.
Jun 11, 2015 | Computers & Internet
How do i press the f12 key without turning the wifi off?
You can set the function keys to act as "function Keys" or to work on the pictures that are printed on the function keys. To change it you need to enter the BIOS by pressing a key during the initial boot up of your computer. It will show you on the screen what to press as you boot it up, you usually only have a few seconds. If you don't know how to do it for your computer check your owners manual for how to enter BIOS, once in BIOS look for a setting to "change action key mode" or a reference to function keys. Change this setting then save changes and reboot your computer, that should solve your problem.
Sep 12, 2013 | HEWLETT-PACKARD Compaq Presario CQ56-110US...
Add boot option and change boot to usb
You need to change boot options in BIOS. Press required F key during boot. Look on the screen since Function keys vary with systems. In boot options make USB 1st. Save and reboot.
Note: Some systems have an boot option during startup. Thus eliminating the need for BIOS change. Again, look on the screen for F key.
Oct 28, 2012 | ASUS U46ERAL5 Notebook
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
How restart laptop using f bottons
You don't restart a laptop using the Function Keys (F1 thru F12). You restart the laptop by hitting the power button. The function keys will allow you to boot the laptop in SAFE MODE if you repeatedly hit the F8 key until you see the Safe Mode option after you hit the power button. Function keys will also allow you to change the boot order, go into the BIOS or Setup to change things also. You need to state your problem as to what is going on with your laptop.
Mar 19, 2012 | Computers & Internet
Linux mint 12 won't boot from CD
Restart your computer, press repetedly a key to enter BIOS, normally Del, go to Advanced BIOS Features probably and change to boot primarly from CD/DVD (1st Boot Device CD/DVD , or something like that), save and exit BIOS, and restart your computer with Linux Mint CD inside. Be aware that if you make wrong changes in BIOS, you could damage your computer.
Feb 18, 2012 | Acer TravelMate 4001LCi Notebook
How can I find out what all the F1, F2, F3, etc. keys on the keyboard do?
The link below will tell you what all the keys on the key board will do.
http://www.internet4classrooms.com/winkeyboard.htm
Good Luck and please rate 4 thumbs up for the free answer
Oct 01, 2010 | Computers & Internet
F2 & F12 keys don't work during bootup w/ Trust KB-2200 Keyboard
It is because of the "Function Key" It needs to be enabled for thenm to work. :))
Apr 11, 2009 | Computers & Internet
Cant install new hard drive
Usually, this issue is caused by pressing F12 multiple times to access the 1 time boot menu.  This can cause the keyboard buffer to fill up and the keyboard will not respond.  Resolution:  Press F12 ONLY one time at boot.
If this is not the issue, then the other main cause is having an INTERNET keyboard that has alternate Function Key functions (These will be listed on the front edge of the Function keys and there will be an extra key called an F-Lock) This type of keyboard has the ALTERNATE function of the F-Keys enabled by default, you need to press the F-Lock key to enable the normal F-Key function.
Sep 05, 2008 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
14 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
