Question about Ford Explorer Sport, Sport Trac & Ranger 4.0 SOHC thermostat housing k
Torque specs changing timing chains and need all the torque specs on camshaft sprockets and jackshaft bolts
  • 79 Answers
I believe auto parts stores can give you that information as they sell camshafts,crankshafts,etc. You could also try the dealer auto parts.
Posted on Feb 10, 2014
How do i set camshafts on 1999 duvil northstar
Remove camshaft covrs
Remove front cover
Remove or fully retract all three timing chain tensioners
Remove oil pump
Primary and secondary chain guides should remain in place. Rotate crankshaft until sprocket drive key is at about 1 o'clock position.
Set crankshaft and intermediate shaft sprockets into primary drive chain with their timing marks asjacent to each other.
Install crankshaft and intermediate sprockets over their respective shafts. Rotating crankshaft as necessary to engage crankshaft key in sprocket without changing the timing mark relationship.
Install Flywheel Holder Tool (J-39411) to lock crankshaft in position. Install intermediate shaft sprocket retaining bolt and torque to specifications.
Route secondary chain for left cylinder head over inner row of intermediate shaft teeth.
Route secondary drive chain over chain guide, and install exhaust cam sprocket to chain so camshaft drive pin engages the sprocket notch marked "LE" (Left Exhaust).
There dhould be no slack in the lower section of the chain, and the camshaft drive pin must be perpendicular (90 degrees) to the cylinder head surface.
Install the intake camshaft sprocket into the chain so the sprocket notch marked "LI" (Left Intake) engages camshaft drive pin, while drive pin remains perpendicular to the head face. Minor adjustments can be made to camshaft position to get pin to engage by using a wrench on the hex cast into the camshaft.
Install sprocket retainer bolts and torque to specification.
Repet steps as above to install the right secondary chain to the right camshafts. The right camshaft sprockets are marked "RE" and "RI". In addition, the RE sprocket must contain the camshaft position sensor pickup.
May 27, 2012 | 2000 Cadillac DeVille
Need timing gear marks for 2004 Kia Sadona 3.5L engine
Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Record the radio anti theft code data.
  3. Remove or disconnect the following:
    Negative battery cable Engine cover Accessory drive belts Idler pulley Crankshaft pulley Power steering pump pulley Belt tensioner pulley Upper and lower timing belt covers
  4. Support the engine with a floor jack and remove the engine mount.
  5. Rotate the engine to align the camshaft sprocket timing marks with the cylinder head cover timing marks.
    Fig. Timing belt routing and timing marks-3.5L Engine
  6. Remove or disconnect the following:
    Auto tensioner Timing belt
    Fig. Timing belt and related components-3.5L Engine
To install:
  1. Ensure that the engine is set to Top Dead Center (TDC).
  2. Prepare the auto tensioner for installation by compressing it in a vise and installing a retaining pin.
  3. Install the timing belt in the following order:
    1. Crankshaft sprocket
    2. Idler pulley
    3. Left bank exhaust camshaft sprocket
    4. Left bank intake camshaft sprocket
    5. Water pump pulley
    6. Right bank intake camshaft sprocket
    7. Right bank exhaust camshaft sprocket
    8. Tensioner pulley
  4. Install the auto tensioner. Do not remove the retaining pin at this time.
  5. Check that the crankshaft and camshaft timing marks are aligned correctly.
  6. Rotate the crankshaft 1 / 4 turn Counterclockwise .
  7. Rotate the crankshaft 1 / 4 turn Clockwise to return the engine to TDC.
  8. Loosen the tensioner pulley center bolt.
  9. Apply 44 inch lbs. (5 Nm) torque to the tensioner pulley as shown and tighten the center bolt to 32-41 ft. lbs. (43-55 Nm).
    Fig. Adjusting the tensioner pulley-3.5L Engine
  10. Remove the auto tensioner retaining pin.
  11. Rotate the crankshaft 2 revolutions Clockwise , then wait 5 minutes for the auto tensioner to adjust.
  12. Measure the auto tensioner rod as shown. If the measurement is not 3.8-4.5 mm, then repeat the belt tensioning procedure.
    Fig. Measuring the auto tensioner rod-3.5L Engine
  13. When the auto tensioner measurement is correct, install or connect the following:
    Engine mount Upper and lower timing belt covers Belt tensioner pulley Power steering pump pulley Crankshaft pulley Idler pulley Accessory drive belts Engine cover Negative battery cable
  14. Reprogram the radio anti theft codes.
    Kia_Sedona_2002-2006
    Timing Chain, Sprockets, Front Cover & Seal
    Print
    3.8L Engine
    3. Remove the engine from the vehicle.
    4. Remove the drive belt. Remove the power steering pump. Remove the air conditioning compressor.
    5. Remove the alternator. Remove the drive belt idler. Remove the drive belt tensioner. Remove the water pump pulley. Remove the intake manifold.
    6. Remove the connector bracket from the left cylinder head cover. Disconnect the right ignition coil connector, condenser connector and remove the bracket.
    7. Remove the left cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
    8. Remove the right cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
    9. Set the No. 1 cylinder to TDC on the compression stroke. Turn the crankshaft pulley and align its groove with the timing mark T of the lower timing chain cover.
    10. Check that the mark of the camshaft timing sprockets are in straight line positioning on the cylinder head surface. If not rotate the crankshaft 360 degrees. Do not rotate the engine counterclockwise.
    11. Remove the oil pan. Remove the crankshaft damper pulley. Remove the timing chain cover.
      NOTE Be careful not to damage the contact surfaces of the cylinder block, cylinder head and timing chain cover. Before removing the timing chain, mark the right and left timing chains with an identification mark based on the location of the sprocket because the identification mark on the chain for TDC can be erased.
    12. After compressing the timing chain tensioner, install a set pin. Remove the right cam to cam guide. Remove the right timing chain auto tensioner and timing chain tensioner arm.
    13. Remove the oil pump chain cover. Remove the oil pump chain tensioner assembly. Remove the oil pump chain guide. Remove the right timing chain.
    14. Remove the right timing chain guide. Remove the oil pump chain sprocket and oil pump chain. Remove the crankshaft sprocket, oil pump and camshaft drive gear.
    15. Remove the left cam to cam guide. Remove the left timing chain auto tensioner and timing chain tensioner arm. Remove the left timing chain.
    16. Remove the left timing chain guide. Remove the crankshaft sprocket and left camshaft drive. Remove the tensioner adapter assembly.
      Fig. Timing chain and related components-3.8L Engine
    To install:
    1. Check the camshaft and crankshaft sprockets for wear and damage, replace as required.
    2. Inspect the tensioner arm and chain guide for wear and damage, replace as required.
    3. Check that the tensioner pin moves smoothly when the ratchet pawl is released with a thin rod.
    4. The key of the crankshaft should be aligned with the timing mark of the timing chain cover. This indicates that the piston is at TDC on the compression stroke.
    5. Install the tensioner adapter assembly. Install the crankshaft sprocket and left camshaft drive.
    6. Install the left timing chain guide and torque the retaining bolts 14-18 ft. lbs.
    7. Install the left timing chain. Be sure to install the chain with no slack between the camshaft and the crankshaft (crankshaft sprocket, timing chain guide, exhaust camshaft sprocket, intake camshaft sprocket). The timing mark of each sprocket should be matched with the timing mark (color ink) of the timing chain at installation of the timing chain.
      Fig. Left timing chain markings and installation: (D) exhaust camshaft sprocket (C) intake camshaft sprocket-3.8L Engine
    8. Install the left timing chain tensioner arm and torque the retaining bolts 14-16 ft. lbs.
    9. Install the left timing chain tensioner and torque the retaining bolts 7-9 ft. lbs.
    10. Install the left cam to cam guide and torque the retaining bolts 7-9 ft. lbs.
    11. Install the crankshaft sprocket, oil pump and right camshaft drive.
    12. Install the oil pump chain and oil pump sprocket. Torque the retaining bolt to 14-16 ft. lbs.
    13. Install the right timing chain guide. Torque the retaining bolts to 14-18 ft. lbs.
    14. Install the right timing chain. Be sure to install the chain with no slack between the camshaft and the crankshaft (crankshaft sprocket, intake camshaft sprocket, exhaust camshaft sprocket). The timing mark of each sprocket should be matched with the timing mark (color ink) of the timing chain at installation of the timing chain.
      Fig. Right timing chain markings and installation: (C) exhaust camshaft sprocket (B) intake camshaft sprocket-3.8L Engine
    15. Install the right timing chain tensioner arm. Torque the retaining bolts to 14-17 ft. lbs.
    16. Install the right timing chain auto tensioner. Torque the retaining bolts to 7-9 ft. lbs.
    17. Install the right cam to cam guide and torque the retaining bolts to 7-9 ft. lbs.
    18. Install the oil pump chain guide. Torque the retaining bolts to 7-9 ft. lbs.
    19. Install the oil pump tensioner assembly. Torque the retaining bolts to 7-9 ft. lbs.
    20. Pull out the pins on both the left and right hydraulic tensioners. Install the oil pump chain cover.
    21. Rotate the crankshaft two revolutions in the clockwise direction. Confirm the timing mark. Be sure to rotate the crankshaft in the clockwise direction.
    22. Apply sealant on the chain cover and on the cylinder head, cylinder block, and lower oil pan. Be sure these parts are free of engine oil and dirt.
      NOTE Before assembling the timing chain cover, the liquid sealant TB1217H should be applied on the gap between the cylinder head and block. The part must be assembled with five minutes after the sealant is applied.
      Fig. Sealant application (1 inch bead width)-3.8L Engine
    23. Apply sealant on the chain cover.
      NOTE The liquid sealant TB1217H should be applied on the gap between the cylinder head and block. The part must be assembled with five minutes after the sealant is applied.
      Fig. Timing cover sealant application-3.8L Engine
    24. Install a new gasket to the timing case cover.
      NOTE It is important that the dowel pins on the cylinder block and holes on the timing chain cover should be used as a reference in order to assemble the timing chain cover in the correct position.
      Fig. Timing cover gasket installation (A) gaskets-3.8L Engine
    25. Install the timing chain cover. Torque the retaining bolts in the proper sequence and to specification. The engine should not be started for at least thirty minutes after timing chain cover assembly.
      Fig. Timing cover bolt torque sequence and specification-3.8L Engine
    26. Install the timing case cover oil seal.
    27. Continue the installation in the reverse order of the removal procedure.
May 19, 2012 | 2004 Kia Sedona
Need the timing marks for a 2000 alero
please let me know if you have questions.
2.4L Engine
NOTE It is recommended that the entire procedure be reviewed before attempting to service the timing chain.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Drain the cooling system.
  3. Remove or disconnect the following: Negative battery cable, Coolant surge tank, Accessory drive belt, Alternator
  4. Install an engine support.
  5. Remove or disconnect the following: Upper cover fasteners, Front cover vent hose, Right engine mount and bracket, Right front wheel, Right lower splash shield, Crankshaft balancer, Lower cover fasteners, Front cover
  6. Rotate the crankshaft clockwise, as viewed from front of engine (normal rotation) until the camshaft sprocket's timing dowel pin holes align with the timing chain housing holes. The crankshaft sprocket mark should align with the engine mark. The crankshaft sprocket keyway should point upward and align with the cylinder bores centerline. This is the normal timed position.
  7. Remove the timing chain guides.
  8. Remove the timing chain tensioner.
    NOTE Be sure all the slack in the timing chain is above the tensioner assembly when removing it. CAUTION The tensioner plunger is spring loaded and could fly out causing personal injury.
  9. Remove or disconnect the following: Timing chain, Camshaft sprockets
To install:
  1. Install or connect the following: Camshaft sprockets. Torque the bolts to 52 ft. lbs. (70 Nm),
    Camshaft sprocket alignment pin through the camshaft sprockets holes into the timing chain housing holes to position the camshafts for timing.
  2. If the camshafts are out of position and must be rotated more than 1 / 8 turn in order to install the alignment dowel pins, perform the following:
    1. Rotated the crankshaft 90 degrees clockwise off Top Dead Center (TDC) in order to give the valves adequate clearance to open.
    2. Once the camshafts are positioned and the dowels installed, rotate the crankshaft counterclockwise back to TDC.
      WARNING Do not rotate the crankshaft clockwise to TDC or valve and piston damage may occur.
  3. Install the timing chain over the exhaust camshaft sprocket, around the idler sprocket and around the crankshaft sprocket.
    Fig. Timing chain and sprocket alignment positions-2.4L DOHC engine
  4. Remove the alignment dowel pin from the intake camshaft. Using a dowel pin remover tool, rotate the intake camshaft sprocket counterclockwise enough to slide the timing chain over the intake camshaft sprocket. Release the camshaft sprocket wrench. The length of chain between the 2 camshaft sprockets will tighten.
    NOTE If properly timed, the intake camshaft alignment dowel pin should slide in easily. If the dowel pin does not fully index, the camshafts are not timed correctly and the procedure must be repeated.
  5. Leave the alignment dowel pins installed.
  6. With slack removed from chain between intake camshaft sprocket and crankshaft sprocket, the timing marks on the crankshaft and the cylinder block should be aligned. If marks are not aligned, move the chain 1 tooth forward or rearward, remove slack and recheck the marks.
  7. Tighten the chain housing to engine stud. The stud is installed under the timing chain. Torque it to 19 ft. lbs. (26 Nm).
  8. Reload the timing chain tensioner as follows:
    1. Form a keeper from heavy gauge wire.
    2. Slightly, compress the shoe plunger and insert a small screwdriver into the access hole.
    3. Release the ratchet pawl and compress the plunger completely into the hole.
    4. Insert the keeper between the access hole and the blade.
  9. Install or connect the following:
    Tensioner assembly to the chain housing. Torque the bolts to 89 inch lbs. (10 Nm). Tensioner shoe and retainer. Torque the bolts to 89 inch lbs. (10 Nm). NOTE Recheck plunger assembly installation. It is correctly installed when the long end is toward the crankshaft.
  10. Remove the alignment dowel pins. Rotate crankshaft clockwise 2 full rotations. Align the crankshaft timing mark with mark on cylinder block and reinstall alignment dowel pins. Alignment dowel pins will slide in easily if engine is timed correctly.
    WARNING If the engine is not correctly timed, severe engine damage could occur.
  11. Install or connect the following: Timing chain guides, New seal into the front cover by lubricating the seal lip and tapping it into place, Front cover and gaskets. Torque the nuts and bolts to 106 inch lbs. (12 Nm), Crankshaft balancer. Torque the bolt to 129 ft. lbs. (175 Nm), Right front lower splash shield, Front wheel. Torque the nuts to 100 ft. lbs. (140 Nm), Right engine mount bracket. Torque the bolts to 81 ft. lbs. (110 Nm) plus an additional 90 degree turn, Right engine mount. Torque the bolt to 49 ft. lbs. (60 Nm), Upper cover vent hose
  12. Remove the engine support.
  13. Install or connect the following: Alternator. Torque the bolts to 37 ft. lbs. (50 Nm), Accessory drive belt, Coolant surge tank, Negative battery cable.
  14. Refill the cooling system.
  15. Start the engine and check for leaks.
Oct 04, 2011 | Cars & Trucks
2001 ford ranger 4.0 engine timing chain replacement
Hi Josiah:
According with the repair guide...4.0L Engine
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Drain the engine oil.
    Negative battery cable Engine from the vehicle Oil pan Engine front cover Cylinder heads
  4. Lock the jackshaft tensioner by installing a pin.
    Jackshaft sprocket and chain assembly Left front cassette retaining bolt Cassette chain and tensioner assembly Rear jackshaft plug from the engine Right rear cassette retaining bolt and spacer Right rear cassette chain and tensioner Timing chain (s)
Fig. Remove the jackshaft sprocket-4.0L SOHC Engine 2000-2001
Zooming link for Remove the jackshaft sprocket-4.0L SOHC Engine 2000-2001
To install:
    Timing chain(s) Right rear cassette chain, tensioner and sprocket Jackshaft sprocket and chain on the engine and remove the tensioner pin
  2. Torque the jackshaft sprocket bolt in 2 stages:
    1. 32-35 ft. lbs. (43-47 Nm).
    2. Turn an additional 65 degrees.
    Cylinder heads Front cover Oil pan Engine to the vehicle Negative battery cable
  4. Fill the engine with clean oil.
  5. Start the vehicle, check for leaks and repair if necessary.
  2. With the vehicle in neutral, position it on a hoist.
  3. Remove the intake manifold.
  4. Remove the fuel supply manifold.
  5. Remove the accessory drive belt.
  6. Remove the thermostat housing.
  7. Remove the roller followers.
    NOTE You must retime the LH and RH camshafts when either camshaft is disturbed. Turn the crankshaft clockwise to position the number one cylinder at top dead center (TDC).
    NOTE The special tool must be installed on the damper and should contact the engine block to position the engine at TDC.
  8. Install the special tool.
    NOTE The right-hand camshaft sprocket bolt is a left-hand threaded bolt.
    NOTE If necessary, use camshaft gear torque adapter to loosen the camshaft sprocket bolt.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 08, 2011 | 2001 Ford Ranger Regular Cab
I have a 2001 Olds Aurora with a V6 3.5 and I need the timing diagram for this. I have looked everywhere and can not find a book with it in it. Would you happen to have this??
Please let me know if you have questions, and thanks for using Fixya.
To install:
  1. Rotate the crankshaft so the No. 1 piston is at TDC and the mark on the crankshaft is at the 4 o-clock position.
  2. Rotate the balance shaft so the timing mark is at the 5 o-clock position.
    NOTE Be sure the painted links are facing the front of the engine.
  3. Install the timing chain on the sprockets.
  4. Center the mark on the left intake camshaft sprocket between the 2 painted links.
  5. Lift the chain onto the right intake camshaft sprocket. While doing this, align the marks on the balance shaft and crankshaft sprockets with the painted marks on the chain.
  6. Verify that all of the timing marks are aligned.
  7. Install the primary chain tensioner shoe. Torque the bolt to 22 ft. lbs. (30 Nm).
  8. Compress the primary chain tensioner using the following steps:
    1. Rotate the ratchet release lever counterclockwise and hold it.
    2. Press the tensioner shoe in and hold it.
    3. Release the ratchet lever and slowly release the pressure on the shoe.
    4. Insert a pin through the hole in the lever as the lever moves to the first click. The ratchet should hold the shoe in the compressed position.
      NOTE Be sure the lever on the tensioner is facing you when installed.
    Primary chain tensioner. Torque the bolts to 18 ft. lbs. (25 Nm); then remove the chain tensioner pin. 4 chain guide access plugs. Torque the plugs to 44 inch lbs. (5 Nm). Front engine lift bracket. Torque the hex head bolt to 37 ft. lbs. (50 Nm) and the internal drive bolt to 18 ft. lbs. (25 Nm). CMP sensor. Torque the bolts to 80 inch lbs. (9 Nm).
  10. Remove the camshaft holding tools.
  11. Place a small bead of RTV sealant on the 3 areas indicated in the diagram.
  12. Install or connect the following:
    Front cover with a new gasket. Torque the bolts to 124 inch lbs. (14 Nm) and the coolant drain plug to 89 inch lbs. (10 Nm). Crankshaft balancer. Torque the bolt to 37 ft. lbs. (50 Nm); then an additional 120 degree turn.
  13. Raise the engine cradle and install new bolts. Torque the bolts to 133 ft. lbs. (180 Nm).
  14. Coat the sub-frame bushings with rubber lubricant.
  15. Install or connect the following:
    Water pump with a new gasket. Torque the bolts to 124 inch lbs. (14 Nm). Belt tensioner. Torque the bolts to 37 ft. lbs. (50 Nm). Idler pulley. Torque the bolt to 37 ft. lbs. (50 Nm). Power steering pump pulley Drive belt Underhood accessory wiring junction block Washer and coolant reservoirs Battery and tray Front diagonal brace Rocker arm covers. Torque the bolts to 80 inch lbs. (9 Nm). Negative battery cable
  16. Refill the cooling system.
  17. Refill the crankcase.
  18. Start the engine and verify no leaks.
Secondary Chain
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative battery cable.
  3. Remove the rocker arm cover and install camshaft holding fixture J-42038.
  4. Remove the camshaft sprocket bolts and install the timing chain holding fixture J-42042 on the cylinder head.
    Sprockets and chain Secondary timing sprocket and chain
To install:
Fig. Correct sprocket alignment for the left secondary timing chain-3.5L engine
Fig. Correct sprocket alignment for the right secondary timing chain-3.5L engine
    Secondary timing chain on the sprockets, with the drive pins at the 12 o-clock positions Sprockets and chain assembly onto the camshafts, with the chain properly aligned on the tensioner
  2. Remove the timing chain holding fixture
  3. Install the sprocket bolts. Torque the bolts to 18 ft. lbs. (25 Nm); then an additional 45 degree turn.
  4. Remove the camshaft holding fixture.
    Rocker arm cover Negative battery cable
Apr 09, 2011 | 2001 Oldsmobile Aurora
Need directions on how to install a timing chain on a 2002 Saturn L series 2.2 liter along with the allignment marks for the intake and exhaust cams
To Install:
    • Timing chain drive sprocket to crankshaft
      1. Rotate the crank so the mark on the sprocket is at the 5 o'clock position
  2. Assemble chain to the intake camshaft sprocket alignment copper link to the "INT" diamond timing mark on the camshaft sprocket sat_car_22_tmng-chn_pos.gif
    NOTE: When lowering the timing chain rotate the assembly 90° to allow the chain to fall between the cylinder block bosses then rotate the assembly back so the camshaft sprocket is facing forward.
  3. Lower the assembly through the chain housing opening on top of the cylinder head. Use care to ensure that the chain goes around both sides of the cylinder block bosses NOTE: The crankshaft sprocket timing mark will be at approximately the 5 o'clock position.
  4. Route chain around crankshaft sprocket and align silver link to the timing mark sat_car_22_set_tdc.gif
    NOTE: The camshaft sprocket bolts are not reusable; they are torque-to-yield and must be discarded to prevent premature failure.
    • Intake camshaft sprocket loosely onto the intake camshaft then install the new camshaft sprocket bolt finger tight NOTE: It is not necessary to align the sprocket-to-camshaft offset notch at this time.
    • Adjustable timing chain guide through the opening on top of the cylinder head then install the chain guide bolt; torque to 89 lb-in. (10 Nm) sat_car_22_ajst_tmng-ch_guid.gif
    • Exhaust camshaft sprocket loosely onto the exhaust camshaft with the timing mark on the sprocket aligned with the silver link then install a new camshaft sprocket bolt finger tight
  6. Align the camshaft sprocket-to-camshaft then tighten the camshaft bolt using the following procedure: sat_car_22_crnk_tmng-c_mrk.gif
    NOTE: Do not rotate either camshaft more than 1/2 turn in either direction with the crankshaft at Top Dead Center (TDC). To do so may cause valve to piston contact resulting in a damaged valve and/or a damaged piston.
    • Ensure that the sprocket timing mark is at the 5 o'clock position
    • Rotate the intake camshaft using a 24mm wrench on the flats of the camshaft until the sprocket-to-camshaft alignment notch seats
    • When the sprocket seats on the camshaft tighten the sprocket bolt finger tight
    • Rotate exhaust camshaft using a 24mm wrench on the flats of the camshaft until the sprocket-to-camshaft alignment notch seats
  7. Verify that all colored links are aligned with the appropriate marks on the camshaft and crankshaft sprockets NOTE: If they are not repeat steps 1C through 4.
  8. Install the fixed timing chain guide and bolts; torque to 89 lb-in. (10 Nm)
  9. Install the fixed timing chain guide bolt access hole plug; torque to 30 lb-ft. (40 Nm)
  10. Install upper timing chain guide and bolts; torque to 89 lb-in. (10 Nm) NOTE: Use a 24mm wrench to support the camshaft while applying torque to the camshaft sprocket bolt. Do not torque the camshaft bolts against the timing chain as it may damage the timing chain.
  11. Torque the intake and exhaust camshaft sprocket bolts; torque as follows:
    • First Pass: 63 lb-ft. (85 Nm)
    • Second Pass: Turn an additional 30° using a torque angle gauge
  12. Install the sealing ring and tensioner assembly; torque to 55 lb-ft. (75 Nm)
    • Timing chain oil nozzle and bolt; torque to 89 lb-in. (10 Nm)
    • Camshaft cover assembly
    • Engine front cover
    • Negative battery cable; torque to 13 lb-ft. (17 Nm)
Nov 12, 2010 | 2002 Saturn L-Series
I need to know how to set thte timing chain
Discoverd this indepth expalaination of process steps involved in the installation of the timing chain from an ASE certified technician. I hope this helps. See the repair manual on the link below.<br /> <br /> Link: <a href="http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html">http://www.2carpros.com/forum/2002-jaguar-xj8--gearbox-default-appear-on-dashboard/2000-jaguar-xj8-timing-chain-replacement-vt218070.html</a><br /> <table id="table14" style="BORDER-RIGHT: #000000 1px dashed; BORDER-TOP: #000000 1px dashed; BORDER-LEFT: #000000 1px dashed; BORDER-BOTTOM: #000000 1px dashed" bordercolordark="#000000" width="100%" bordercolorlight="#000000" border="0"> <tbody> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"><span class="name" roundtrip="0" lastvisited="3">By <a name="755408"></a><b roundtrip="0" lastvisited="0">Dave H</b>,<b> </b></span><span class="postdetails" roundtrip="0" lastvisited="0">Certified ASE Technician</span></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="100%" roundtrip="0" lastvisited="6"></td></tr> <tr> <td style="BORDER-TOP-WIDTH: 1px" width="700"></td></tr> <tr> <td style="BORDER-LEFT-WIDTH: 1px; BORDER-BOTTOM-WIDTH: 1px; BORDER-RIGHT-WIDTH: 1px"> </td> </tr> <tr> <td colspan="2"> <span class="postbody" roundtrip="0" lastvisited="77">PRIMARY TIMING CHAINS (NON-SUPERCHARGED) <br />NOTE:The 4.0L V8 has no engine timing alignment marks on the crankshaft or camshafts. Engine timing is achieved by installing the Crankshaft Setting Peg (303-531) and Camshaft Locking Tool (303-530). With the crankshaft setting peg in position, ensure the timing flat on each camshaft is in the uppermost position before installing camshaft locking tool. Variable camshaft timing unit may also be referred to as Variable Valve Timing (VVT) unit. <br /><br />NOTE:Special Tools Required: Crankshaft Setting Peg (303-531), Camshaft Locking Tool (303-530), Chain Tensioning Tool (303-532), Primary Chain Wedge (303-533) and Variable Camshaft Timing Oil Control Unit Setting Tool (303-654). See Fig. 232-Fig. 236 . <br /><br />NOTE:"A" bank refers to the right/passenger side of the vehicle and "B" bank refers to left/driver side of the vehicle. <br /><br />NOTE:Each door glass automatically drops 12 mm when the door is opened or when the convertible top is raised or lowered. It is important that windows are lowered before battery is disconnected to allow doors to shut properly. <br /><br />Removal ("A" Bank) <br />Tips Click a link to view tip <br />Tech1Tip: special tool <br /><br /><br />Remove timing cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). <br />Remove the variable camshaft timing oil control solenoid. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove the variable camshaft timing oil control unit housing retaining bolts and remove the variable camshaft timing oil control unit housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Remove and discard the variable camshaft timing oil control unit housing "O" rings. <br />Raise and support vehicle. Remove the bolt which secures the Crankshaft Position (CKP) sensor to the flywheel housing. Remove the CKP sensor and allow it to hang free under the engine. Remove the torque converter bolts access grommet from the flywheel housing. </span><br /> <span class="postbody" roundtrip="0" lastvisited="77">Install the crankshaft damper bolt (old one) to the crankshaft, hand-tight only. Rotate crankshaft until the triangular arrow indent on the flywheel is visible through the access hole. See Fig. 144. Confirm that the timing flat on each camshaft is uppermost position. <br />Position the crankshaft so that the Crankshaft Setting Peg (303-531) engages fully into the timing slot. Install and tighten the bolt to secure the crankshaft setting peg. See Fig. 145. Remove the crankshaft damper bolt from the crankshaft and lower the vehicle. <br />Install the Camshaft Locking Tool (303-530) to the "A" bank camshafts, aligning the shafts slightly as necessary. Loosen the bolt that secures the exhaust camshaft sprocket and the bolt that secures the variable camshaft timing oil control unit. See Fig. 146. Remove camshaft locking tool. <br />Remove the primary chain tensioner bolts, primary chain tensioner and tensioner backing plate. See Fig. 147. <br />Remove the primary timing chain tensioner pivot bolt and remove the primary timing chain tensioner blade. See Fig. 148. <br />Remove the bolt which secures the primary timing chain guide. Noting the position of the primary timing chain guide, remove the primary timing chain guide from the upper retaining pin. See Fig. 149. <br />Remove the primary timing chain from the variable camshaft timing oil control unit and from the crankshaft sprocket. Clean and inspect all components. <br />Installation <br />If "B" bank timing chain was removed, see INSTALLATION. If not, go to next step. <br />If previously removed, install the timing chain sprocket to the crankshaft. The teeth of the "A" bank and the "B" bank timing chain sprockets on the crankshaft must be out of phase with each other. If they are in phase after installing, remove the sprocket, turn it on its vertical axis and reinstall sprocket. See Fig. 150. <br />Install the chain tensioning tool to the exhaust camshaft sprocket. Reposition the sprocket (and the variable camshaft timing oil control unit) for the most advantageous position for use of the tool. See Fig. 151. Remove the tool. <br />Install the primary timing chain into position over the crankshaft sprocket and the variable camshaft timing oil control unit. There must be no slack on the drive side of the primary timing chain and the sprockets must not be rotated on the camshafts, or the tensioning tool may not fit. See Fig. 152. <br />Install the primary timing chain tensioner blade to the cylinder block. See Fig. 148. Install the pivot bolt and tighten specification. See TORQUE SPECIFICATIONS. <br />Push the primary timing chain tensioner piston into the tensioner body to provide clearance for installing the primary timing chain. Insert a thin rigid wire through the hole in the end of the tensioner piston to displace the ball from the non-return valve seat. See Fig. 153. With the wire in position, press the piston fully into the tensioner body. Remove the wire. <br />Install the 2 primary timing chain tensioner bolts to the primary timing chain tensioner and locate the tensioner backing-plate on to the 2 bolts. Align and install the primary timing chain tensioner to the cylinder block and to the mating slot on the rear face of the primary timing chain tensioner blade. See Fig. 147. Tighten the primary timing chain tensioner bolts to specification. See TORQUE SPECIFICATIONS. <br />Use a Primary Chain Wedge (303-533), or 2 if needed, between the primary timing chain tensioner and primary timing chain tensioner blade, to take up the slack in the chain for tightening of the variable camshaft timing control unit and exhaust camshaft sprocket. See Fig. 154. <br />Using the chain tensioning tool, apply force to the tool in an counterclockwise direction to tension the chain on its drive side. See Fig. 151. While applying opposing force to the sprocket and chain, tighten the exhaust camshaft sprocket bolt to specification. See TORQUE SPECIFICATIONS. <br />Using the Variable Camshaft Timing Oil Control Unit Setting Tool (303-654), rotate the variable camshaft timing oil control unit fully counterclockwise to the fully retarded position. See Fig. 155. <br />Check that the primary chain wedges are still in place. While applying opposing force to the sprocket and chain using the chain tensioning tool, tighten the variable camshaft timing oil control unit bolt to specification. See TORQUE SPECIFICATIONS. Remove the chain tensioning tool and the primary chain wedges and camshaft locking tool. <br />Raise and support vehicle. Remove crankshaft setting peg. Install the CKP sensor and bolt to the flywheel housing. See Fig. 143. Tighten the CKP sensor bolt to specification. See TORQUE SPECIFICATIONS. Install the access grommet to the housing and lower the vehicle. <br />WARNING:Check that the ring dowels are engaged squarely. Fully locate the assembly as much as possible by hand. Failure to follow this procedure may result in damage to the vehicle. <br /><br />Install NEW "O" rings to the variable camshaft timing oil control unit housing. Lubricate the "O" rings and the bushing. Install the variable camshaft timing oil control unit housing. See Fig. 142. Install the variable camshaft timing oil control unit housing bolts. Tighten to specification. See TORQUE SPECIFICATIONS. <br />Install the variable camshaft timing oil control solenoid. See Fig. 141. Install and tighten the variable camshaft timing oil control solenoid bolt to specification. See TORQUE SPECIFICATIONS. <br />Install the timing chain cover. See TIMING CHAIN COVER (NON-SUPERCHARGED). </span><br /></td></tr></tbody></table>
Aug 26, 2010 | 2001 Jaguar XJ8
What is the right way to time a 4cyl Chevy S-10 timing chain
1998-2003 To Remove:
  1. Remove or disconnect the following:
    • Crankshaft pulley and hub
    • Timing chain cover and gasket
  2. Install a bolt in the end of the crankshaft CAUTION
    Do not install the crankshaft balancer bolt or a bolt longer than 1 inch or damage to the crankshaft threaded hole will result.
  3. Rotate crankshaft until the number 1 piston is at Top Dead Center of compression stroke.
  4. Make sure that the alignment marks are aligned with the tabs on the timing chain tensioner. gm-03-22-611.gif
  5. Measure distance between hole in bracket and unworn surface of timing chain tensioner shoe. NOTE: If distance between the hole and unworn surface of timing chain tensioner is greater than 0.314 in (8 mm), replace tensioner, timing chain and sprockets.
  6. Remove timing chain tensioner bolts.
  7. Remove the timing chain, timing chain tensioner and camshaft sprocket at the same time.
  8. Remove the crankshaft sprocket using special tool J 22888-20A or equivalent.
  9. Remove crankshaft sprocket alignment key.
NOTE: If any camshaft components are being replaced to correct a noise problem, all camshaft drive components must be replaced.
To Install:
  1. Install the crankshaft sprocket alignment key.
  2. Install the crankshaft sprocket using special tool J 5590 or equivalent. gm-03-22-613.gif
  3. Compress the timing chain tensioner spring and insert a pin into the tensioner hole to retain the tensioner shoe.
  4. Install timing chain and timing chain tensioner (do not tighten tension bolts).
  5. Align the crankshaft and camshaft timing marks with the tab on the timing chain tensioner.
  6. Tighten the timing chain tensioner bolts.
    • Torque to: 18 ft lbs (24 Nm)
  7. Tighten the camshaft sprocket bolt.
    • Torque to: 96 ft lbs (130 Nm)
  8. Remove pin from timing chain tensioner hole.
  9. Remove bolt from end of crankshaft. CAUTION
    Inspect the timing chain cover for warping or damage. Replace if needed.
  10. Clean all timing chain cover mating surfaces.
    • Timing chain cover to the engine block
      1. Ensure that the gasket is installed properly in the groove in the timing chain cover
    • Timing chain cover and make sure it fully seated on the alignment dowel pins
    • Timing chain cover bolts
      1. Torque to: 97 inch lbs (11 Nm)
    • Drive belt tensioner
    • Crankshaft damper hub and the crankshaft pulley
Aug 17, 2010 | 2000 Chevrolet S-10
Ford Explorer Sport, Sport Trac & Ranger 4.0 SOHC thermostat housing k Logo
146 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
