Question about Denon Rc-820 Remote Control Avr-3600 Avc-3800 Receiver
Remove cover from denon RC-820 remote
Have removed batteries and small screw under battery cover. Just need to dismantle to clean
5 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
  • 93 Answers
SOURCE: Denon RC-978 remote... every button shuts receiver off
Drop the front panel of your receiver,there is ZONE 2 ON/OFF switch.
Good day!
solutiondoct
Posted on Nov 06, 2008
SOURCE: Denon RC 969 Remote .Not Lighting up anymore ?.
These remotes are known to be weak, Denon is aware of the problem, here in the Netherlands they've sold out. Spare part no longer available. Try an older remote to an Denon AVR. these will work for say, 98% and are more reliable.
Posted on Nov 30, 2008
  • 336 Answers
SOURCE: Denon Remote Required
www.encompassparts.com has them but hold on to your hat!
Manufacturer den.jpg Part Number 3990949003 Part Number Variations Description REMOTE CONTROL RC974 AVR2805 Your Price $118.29 Detailed Description n/a
Posted on Jan 24, 2009
Ho do I open a Denon remote control unit
Make sure there are no hidden screws , top and bottom of remote snap together, usually top snaps over bottom so you have to slide something between halves and push in on bottom or pull out on top to get them to seperate.
Nov 18, 2014 | Denon Dvd Home Theater System Remote...
How do i disassemble the DirecTV RC71 Remote?
Check for more screw(s) behind the label/sticker. Also, you may need to have a flat edge screwdriver or knife to prise open the remote.
Sep 24, 2014 | Directv Televison & Video
How do i clean the directv rc32rf remote control device?
remove 2 screws under the battery compartment but you should remove the battery first.. and remove the front cover design and you can find a hidden 4 screws. after removing those screws then you can clean the keypad by water with soap using used toothbrush.
Jul 06, 2014 | Directv New Original RC32RF Remote Control
I need to replace the 4 cell rechargable ni-cad battery for my Denon RC 8000 remote control.Denon informs me that the battery pack is no longer available.Is there another manufacturer that has a compatible...
Hello
Nickel-Cadmium battery will have a voltage of 1.2V. Four cells together with in series connection give you 4.8VDC, The number 8000 on Denon battery denotes, that it has a current rating of 8000ma [milliampere]. Most of the Ni-Cd batterys will have the same rating. You can use any company's prodcut, provided the size should be the same. That is all. Some battery packs will have 1 ampere capacity, can be used in place safely. No problem at all. OK.
Mar 29, 2011 | Denon RC-8000 LCD Touchscreen Remote...
How do you change battery for casio 1174 CMD-40?
I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
  • A small Phillips heads screw driver
  • A pin (or needle)
  • A replacement CR2032 battery
Instructions :
  1. Remove the 4 screws from the back of the watch
  2. Carefully remove the back plate, do not damage the delicate rubber seal
  3. Carefully remove the delicate rubber seal
  4. Use the pin to remove the small rubber block from the battery cover clasp.
  5. The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
  6. Use the pin to gently pull back the clasp of the battery cover.
  7. The battery cover will then open with a 5mm gap approx. It does not need to be removed.
  8. Use the screwdriver to remove the battery.
  9. After the battery has been replaced, just follow the instructions backwards.
I hope this little tutorial has helped.
Feb 10, 2011 | Casio Watches
(I) spilled milk in my Denon RC-802 audio/video remote control. How do I get it open to clean it without damaging it?
You can find replacement remotes at places like this:
Replacement Remotes
As for cleaning it, most remote controls have TWO different ways of fastening the two halves together. The first is screws. Open the batter compartment and remove the batteries. You may find one or more screws there. Remove the screws and set them aside in a safe place. Sometimes the screws are under labels on the back (the screws are almost always on the back side of the remote). Unfortunately, after you remove the screws, the remote may not open. This is because it is usually also held together by plastic snap tabs. Each remote is different, but the method used is always the same: you take a very thin metal blade, like the edge of a putty knife, and move it along the groove separating the front and back halves of the remote until you feel a "bump" of some sort. Press in firmly on this bump while at the same time torquing the blade to separate the two halves. You will have to do this for each latch, making sure the previous latch you undid doesn't click back in place. You will probably end up marring the edge of the remote a little bit while you do this, but that is unavoidable.
Jan 25, 2011 | Audio Players & Recorders
How do you dismantle the Yamaha RAV-249 remote without damaging the unit. Removing the set screw under the battery cover does not seem to help.
Once you remove the screw from the battery compartment you will need to find a long flat iten to pry the remote open, such as a knife, metal ruler or the like. There is no way to do this without marking the sde of the remote. Simply place the pry between the two halves of the remote and gently pry. You will hear a snapping sound as their are 4 internal catches on either side. Tease it apart in more than one place along the edge. and it will eventually pop apart.
If you have the slow button problem a small circle of tin foil/aluminium paper glued to the back of the rubber pad will have your remote working good as new.
Mar 04, 2010 | Audio Players & Recorders
Have a denon rc-921 remote that setup techs locked. how do I unlock it.
Remove the batteries. Press and release each button. (If you have slide switches, you must move it to each positon and then press and release each button for each of the switches selections.)
Install the batteries and try.
Dec 24, 2009 | Denon AVR-3803 Receiver
How to dismantle the housing of my P910i without damaging it?
On your flip top key pad, you can remove first the middle cover, it is clip type so no need to un scew, but just be very carefull.
after removing it, you'll see to set of screw, remove it so that you can take out the flip key pad,
turn your unit back, near the camera , there are two small cover there , remove it and you will see two screw, take it out
open the battery cover, remove the battery and sim card and the memory card, inside you will see, again two set of screw, take it out,
now all the screw has been removed
on the side oy your unit where you ca find the scroll, try to plip out the cover usig a twizzer or any pointd object, just flip the cover easily until you where able to remove the topcover completely
now just support the LCD, be very carefull so that may never damaged the flex of your screen
at the back of the screen, there are again another set of screw, remove it slowly, make sure that you supported the screen properly
then you can remove the lcd after taking out the stainless cover protection
removing the board is very simple, just lift the board a little higher enough for you to see the back of the board, there is another flex wire attached to the board and the scroll switch, remove it carefully.
then thats it, you had dismantle your unit
Nov 01, 2009 | Sony Ericsson P910i Cellular Phone
The only screen I get is5/1 nothing else on my denon rc-8000 remote. I can not get any other funtions to work. Not even the back light. Can anybody help? PLEASE
Dear granggreen....Patrick here....
Even if you have performed these functions I want you to do them again. Remove the battery cover, remove the re-chargeable battery and it's blocks that hold it in position. Install new AA batterys, press the RE-SET BUTTON and hold for three seconds. If these steps prove nothing my instinks say that one or all Joy Stick discs are flat. Surgery is needed.
Patrick
Jul 02, 2009 | Denon RC-8000 LCD Touchscreen Remote...
Denon Rc-820 Remote Control Avr-3600 Avc-3800 Receiver Logo
82 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
