My weston clocko 20 color tv is not switching on due to over voltage
    Top Expert:
  • Televison & ... Master
  • 74,232 Answers
Check and replace damaged component/s at its main power supply regulator [SMPS] section circuit. Contact any service technician. Gopakumar Gopalan Google
Posted on Feb 10, 2014
By mistake lock my weston color tv..i have not orgnl remote..please help to unlock.
Ernesto answered it in a great way : ) http://www.fixya.com/support/t18940539-unlock_weston_tv
Aug 28, 2014 | Televison & Video
How to fix overlap color green and red on the lcd tv screen?
Mostly it is due to the cable TV operators defect.
Or reduce the Sharpness by going to Settings.,in the LCD tv.
Or try reducing the COLOR.
Aug 25, 2014 | Sony KLV-40BX420 40 1080p Full HD Bravia...
My weston tv remote brocken and i sarch all market but not recive me please tell me remote no
Hi, What about buying a unified remote 4 remotes in one. It will work with your TV. You can do most function with this remote. ON OFF Vol. CH and menue. Also you can operate 3 more items DVD , AV reciever. and Cable or Sat Box. Hope that helps.
PS. or you can write to Weston and they can get you a new remote. $$$
May 01, 2014 | Televison & Video
Weston tv model no smile 2211 is asking for password... what is password???
My Weston TV is want limit set password who can I set it
Oct 26, 2012 | Televison & Video
My coby tv started changing colors and then i unplugged it and no it wont turn on
If the set was changing color it indicates a picture tube problem, plus you also have a shutdown problem, probably due to the picture tube loading down the circuitry, far cheaper to replace the combo tv.
Apr 30, 2011 | Coby TVDVD2050 20 in. TV/DVD Combo
The screen is green all around and the middle is purple.
This is case of colored patches due to magnetic field,check and remove any magnetic thing close to the set, if the same problem is seen than switch off the set by main ON/OFF and switch on after about half hour,if still the problem remains than replace PTC used for de-gaussing,connected with de-gaussing coil mounted around the picture tube i.e electrically removes magnetic field every time TV is switched on.
Feb 06, 2011 | Sony KV-20TS32 20" TV
VERTICAL COLOR LINES CAME UP ON THE SCREEN AND A HIGH PITCHED CONTINOUS NOISE. TURNED TV OFF AND TV CAME BACK ON WITH A BLACK SCREEN, NO SOUND. NOW THE TV WILL TURN ON BUT WILL NOT TURN OFF. THE...
Issue with your Vertical Holder and your Hi Voltage Regulator
..Check for Regulator Leakage on your Hi Voltage Board and Resitor over heat due to overload voltage on the Vertical holder
Cause,,, Due to Static Shoc ...Check also for bad Ground connection
Sep 22, 2010 | Vizio VW42LF 42 in. LCD HDTV
My tv keeps switching off after about 20 minutes after initial starting. if tv is switched on immediately, then it works for less than 5 minutes before switching off. model: power vision.
I do not knowtis make , but this type of fault is sometimes due to dry joints in the flyback circuit or power supply try resoldering all pins on flyback transformer and chopper transformer, also cheek that the ht voltage is as the makers state. Waring unplug from mains before removing back and discharge ht resiour capacitor before starting repair
Mar 04, 2010 | Televison & Video
Tv high pitch
Hi This is most likely a problem in the High Voltage section of the set, probably the High Voltage Transformer, this is something only a qualified technician should service due to the dangerous voltages and shock hazzards involved.
Mar 27, 2007 | Funai EWF2004 20" TV
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
