Question about Konica Minolta Office Equipment & Supplies
Reseat print head c353 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Have a tech do that unless you been to school on it you have to have done it once to have the idea down what needs to be done
Posted on Jan 22, 2016
2 Suggested Answers
  • 96 Answers
SOURCE: Magenta print head reseat.
i'm sorry to be the bearer of bad news but it sounds like your carriage assembly is bad. the slot that holds the magenta cartridge is defective.have the carriage assembly and trailing cables replaced. this should resolve your problem. these parts are becoming harder to find because of the age of the printer. carriage assembly part number is C6074-69388. trailing cable is C6074-60418 making the assumption this is a 36" plotter. also you can try cleaning the contacts on the carriage assembly. good luck!
Posted on Oct 01, 2009
How do I correct error c4152?
Magenta Print head (print head has the LASER inside of it that writes the image on the drum) in this case it is the magenta LASER. Open and close the front door to reset. If it comes back replace the print head. Normal done as a set of all four. (Black, Magenta, Yellow, and Cyan). Worse case is the relay board is bad or the Image control Board$$$$$$$$$$$$$$$$.
Try this site as a start:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 04, 2015 | Konica Minolta Konica Bizhub C353 Drum...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica c353 double side print
ARE you sure you have checked the box on print properties on you computer that says either left binding or top binding have to let the copier know which way to do binding will go so you don't have to flip the paper over to read correctly or it will be upside down on the other side. Left binding like reading a book,top binding like a classroom lecture notebook.
Apr 02, 2012 | Konica Minolta Konica Bizhub C353 Drum...
My Konica Minolta Bizhub C353 is showing a C-4553 error. What does this mean, and how can it be fixed?
Hi this error is a laser malfunction withe the yellow assembly you will need to change the yellow print head unit what you can do is take out the print head unit assembly swap the yellow print head unit with the cyan unit then you should get error c-4552 then you know the unit is faulty
this will fix your issue
Feb 10, 2011 | Konica Minolta Office Equipment & Supplies
Just stopped working, orange light flashing
  • If it flashes orange five times consecutively, that means there is a print head error.
  • Reseat the print head, then reset the printer.
  • To reseat the print head, make sure the printer is on.
  • Open the paper output tray and top cover.
  • Make sure the print head holder is in the center and open the inner cover.
  • Remove all the ink tanks.
  • Raise the print head lock lever and remove the print head.
  • Reseat the print head and lock the lever.
  • Replace the ink tanks.
Jan 30, 2011 | Canon Pixma iP4500 InkJet Printer
I have problerm with konica minolta c353 .. the error code c4554 showing on display. i cant printing....
this is an easy fix, have you had your fuser replaced recently?? if so then it needs reseated or just do a trouble reset. ask me if you need help with that
Dec 19, 2010 | Konica Minolta Konica Bizhub C353 Drum...
REPLACED PRINT CARTRIDGE NOW STATES THE TYPE OF PRINT HEAD IS INCORRECT.
Canon support suggests that perhaps your print head needs to be reseated. This would be too complicated to explain, plus the documentation at Canon support has pictures to help you perform this task.
You must be willing to use the "Search" feature in order to view this solution. Type in the question:
"The type of print head is incorrect" > Click <Search>
Canon MP830 Reseat Print Head
Dec 21, 2009 | Canon MP830 All-In-One Printer
Put in cartridge error
Hi celcono,
Many times this happens because the Print Head needs reseated.
Here are the instructions from Canon on reseating the print head.
Reseat the Print head Reseating the print head is seldomly required to do.
  1. Make sure the machine is powered on.
  2. Lift the Scan Unit until it locks into place (1). The Print Head Holder moves to the center.
  3. Open the Paper Output Tray (2).
  4. Open the Inner Cover (2). The print head holder (3) should be centered.
  5. Lift up the lock lever and take out the print head. The print head can be removed with the ink tanks installed.
  6. Reinsert the print head back in position and press down the lock lever.
  7. Close the Inner Cover (1) and the Scan Unit (2).
    CAUTION: Press the center of the Inner Cover until the cover locks into place.
  8. After the Scan Unit is return to its original position, the LCD displays a message asking if you replaced an ink tank.
  9. Press [+] and select [NO] to exit.
Regards,
-SHG
Dec 25, 2008 | Canon PIXMA MP130 All-In-One InkJet...
18 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
