Question about Dryers
What is the F 01 error message on a HE 2 Dryer
    New Friend:
    Problem Solver:
  • 5 Answers
Possibly bad control board
Posted on Feb 09, 2014
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
What does this error mean dryer has error f-01?
The "F1" error means that the dryer's thermistor failed and needs to be replaced. Make sure you check the dryer vent for clogs before installing the new part.
May 04, 2014 | Kenmore Dryers
E 01 display and beeping
Hi
Check for the following if you get "E01" error message 1. Check for the vent hose whether it is clean which is less than two feet (to outside). 2. Check for the temperature sensor probes one in back at heating element and one in front by the lint filter for the temperatur rises resistance increases on both of them and visa versa. 3. Check whether the unit has been grounded. 4. Check for the element that turns off and on during drying process. 5. When first starting and dryer is cool it will dry one load of clothes, it also seems to work for at least the first part of the cycle, until clothes began to get dry then it over heats. display shows E01 and will not run until it has set for about an hour.
Thank you!
May 09, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
E:01 error keeps coming on, what do we do
If you look on the insideiof the dryer door toward the top . you should see a clamp or something ..if that clamp or screw is broken it will nit operate and giv eyou an error messsage ... what we did was put a little screw back into that hole and made sure it;'s long enough to push in the button at the opening of the dryer .. try that .. if that does not work then you might want to try . to replace the dryer plug ( and or electrical box) if you have a 3 prong outlet and cord then that will give you the error message also , these dryers are picky ...
Oct 30, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Error message & dyer stops
If it's new take your receipt and go to where you bought it and ask them to look into the problem.
Feb 25, 2018 | Dryers
Wd865 error f01
f01 is a motor problem. may need a new one but an engineer visit would confirm this.
Feb 01, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
Top Dryers Experts
