Question about Black & Decker 9072CTN 2.4V Cordless Screwdriver
4.5 volt charger
Where can I obtain a replacement charger for this screwdriver please?
  • 39 Answers
Contact Black& Decker or better yet, Google for what you want. You will need to know the voltage {which you know} and the current draw and the size of the plug in to plug into your tool. There are universal chargers that will fir most tools.
Posted on Apr 30, 2017
I have an Everstart Jump Starter hp250,no AC adapter or manual. Not sure it even works. Is there anyway I can test it myself at no cost?
If the battery is discharged and been so for several months the battery is certain to be useless or nearly so. Lead acid batteries need to be kept fully charged or they die quickly. The standing rule for jumpstarters is to recharge monthly and after every use.
A cheap low powered jump starter will be cheaper to replace than to obtain a replacement battery but a replacement battery will be cheaper for a medium duty upwards and they are mostly easy to fit.
It is impossible to test a discharged lead acid battery or indeed a jumpstarter. A manual shouldn't be needed as they are intuitive to use and the safety precautions are generic.
The charger is also a fairly generic 12 volt charger (actually 13, 14 or 15 volts) as supplied with many appliances and accessories of all sorts and in addition the unit would be supplied with a fused lead to charge the unit from the cigar lighter socket, also generic.
If it charges successfully after you have borrowed a charger or connected it via the jump leads to a low powered, 0.5 amp, charger, the battery voltage should be at least 12.7 volts after standing idle for 24 hours.
Sep 12, 2017 | Computers & Internet
Tip
How to convert 220 volts to 110 volts for the iPod Touch
<p> <p>The battery of an iPod Touch prepared for use in the United States is designed to be reloaded from the current supplied by a 110-volt electrical system. Power is transmitted to the battery charger with an iPod battery, which are connected via a USB cable and then connected to a 110 volt outlet. To use the power of a 220 volt outlet with an iPod Touch, set the current 220 volts to 110 volts. A conversion adapter voltage, also known as "Step Down Transformer," it is necessary and can be obtained from an electronics store, a hardware store and even some drug stores. <br /> <p><br /> <p>1. Place the 220-110 voltage converter card (aka, "Step Down Transformer") next to a 220 volt outlet. Plug the adapter into the outlet. <br /> <p><br /> <p>2. Connect the end of a USB cable to the USB connector USB iPod charger iPod. Connect the other end of USB cable into your iPod's own socket on the bottom of the iPod Touch. <br /> <p><br /> <p>3. Plug the iPod into the 110 volt outlet in the battery adapter for the iPod Touch. <br /> <p><br /> <p>4. Unplug the charger from the iPod adapter and the adapter from the outlet when the battery is charged. Unplug the USB cable from the iPod charger and iPod Touch. <br />
on Aug 09, 2011 | Apple iPod touch
I am looking for a charger for a B & D modelKC144BP 14.4 V battery
Check with a local appliance parts supplier or a Back and Decker dealer to obtain a replacement charger.
Jun 20, 2016 | Black and Decker USA 14.4 Volt Battery...
Need charger
www.vectormfg.com
Black and decker bought them out, so should be able to obtain it from them or one of their outlets.
May 31, 2014 | JUMP START SYSTEM
Can I get a charger for a powerbase screwdriver? I've lost mine. Jacqui
Find out what voltage is required for the charger and any universal charger with a compatible connector will work. Batteries are rated at 1.2 volts, so if the screwdriver has 3 batteries you need a charger that delivers about 4 volts. A good hardware store should be able to supply you with a suitable charger.
Jan 17, 2011 | Vacuums
WHERE DO I BUY A REPLACEMENT CHARGER FOR A RYOBI 4V LITHIUM IRON SCREWDRIVER KIT?
Hello. Here is the internet address I use to obtain tool parts. They should be able to help you. http://www.ereplacementparts.com/ryobi-parts-c-7931.html
Nov 28, 2009 | Drills
Looking for Craftsman Cordless Screwdriver Charging cord
Go to the following link:
http://commercial.searspartsdirect.com/partsdirect/parts/5102970-17/0009/900&pathTaken=partSearch&filterPart=&pop=flush
Sep 12, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
I am looking for a charger for a kraft tech cordless screwdriver DS01CN-3.6v. i lost it and have wasted many hours on he web. please can you help me.
Copy the entire address below, paste it in the address box. It will take you to the Kraft tech 3.6v cordless screwdriver web page. From there you can order a new charger It is listed under replacment parts. I think it lists for $3.38.
http://krafttechsupport.com/products/product.aspx?ID=5
You could also take it to Radio Shack and they might be able to fix you up with a universal charger.
Mar 17, 2009 | Hand Tools
Black & Decker 9072CTN 2.4V Cordless Screwdriver Logo
65 people viewed this question
Top Black & Decker Hand Tools Experts
Robert Monigold
Robert Monigold
Don Numinen
Don Numinen
Are you a Black & Decker Hand Tool Expert? Answer questions, earn points and help others
