Question about ASUS Computers & Internet
Hagenuk voiptel 40 - ASUS Computers & Internet
Does it work for ps3?
No, it does not work for ps3. It works for phones and some other types of devices and not ps3. You can check the manual of Your ps3 to see if this confirms the solution i gave You. Hope this helped You.
Jan 18, 2011 | Hagenuk Anycom MILOS-9 Bluetooth Headset -...
How you pair you headset with your pc
With your headset fully charged, and turned off, press and hold the multi-function button, until the blue and red leds flash alternatively. It is now in paring mode. Now, make your PC bluetooth application (don't know which bluetooth stack it has), search for other devices, Select 'MILOS-9', and, if a PIN (or passkey, or pairing code) is requested on your PC, enter '0000' (four zeros). The blue led will flash three times, indicating successful action. If the pairing procedure fails, turn your headset off, wait for 10 seconds, and start it over. From now on, you will need just to turn the headset (and the PC bluetooth hardware) on. They should automatically connect to each other. If they fail to do so, try to right-click on 'MILOS-9', on your PC's bluetooth device list, and select 'Connect'.
Hope you are able to sort your problems out.
Cheers! Carlos
May 06, 2010 | Hagenuk Anycom MILOS-9 Bluetooth Headset -...
HE PERDIDO EL CODIGO PIN PARA EL BLUETOOTH
tratar de 0000 (4 ceros) si eso no funciona, trate de uno de estos:
1111, 1234, 9999
Jan 04, 2010 | Hagenuk Anycom MILOS-9 Bluetooth Headset -...
Can not figure out how to connect my ANYCOM Milos-9 to my cell phone. no instructions came with product.
Turn off the Anycom headset. After it is off, press and hold the silver power button. You will see a blue light come on but dont let go off the power button, keep holding it till the light turns red. Then the device will be in pairing mode. Turn on the phone and make sure that the phone is visible in the bluetooth settings. Scan for a device in the phone and you should see the Anycom headset. If it asks for a code to enter then the code is either 0000 or 1234 or 9999.
Dec 27, 2009 | Hagenuk Anycom MILOS-9 Bluetooth Headset -...
2 1/5 * 3 1/8=
I am not sure if you are trying to simplify the expression or what....
The common denominator for this problem is 40.
2-1/5 becomes 88/40 (5 * 8 = 40, so 8*1 = 8, 8 +2 * 40 = 88)
and 3-1/8 becomes 125/40
You can now rewrite the equation as (88/40) * (125/40) = x
or (88 * 125) / 40/40) = x
that gives you 11000/40/40 = x
x = 275/40 as a fraction, which can be reduced to 55/8 by dividing both part by 5.
or x = 6.875 as a decimal
Oct 07, 2009 | Core Learning Fractions Step-By-Step...
What synthetic motor oil to use in 2007 v/w beetle
Most any 5w-40 fully synthetic oil with be fine in your car.
but here is a list of the recommended oils from Volkswagen.
VW/Audi Approved Engine Oils
Oil Quality Standard VW 505.01
(note: not all oils listed are available for sale in the US)ALL 505.01 Approved Oils are SAE 5W-40 Viscosity
Manufacture: Audi/VW
Description: part number G 052 167 A2
Viscosity: SAE 5W-40
Manufacture: AD Parts
Description: AD SDI
Manufacture: Addinol
Description: Addinol Light MV 0546 PD
Manufacture: Agip
Description: Agip 7004
Manufacture: AMAG
Description: Gamaparts Super LL TDI
Manufacture: Aral
Description: Aral Tronic 431
Manufacture: Avia
Description: AVIA TDi 505.01
Description: Avia Turbo CFE PD
Manufacture: BP
Description: BP Visco Special V
Manufacture: Bucher AG
Description: Motorex Profile V–XL
Manufacture: Carat
Description: Carat ad–Diesel PD–Oil
Manufacture: Castrol
Description: Adamol Multitop PDI
Description: Castrol 505 01
Description: Castrol GTD 505 01
Description: Castrol TXT 505 01
Description: Cepsa Star TDI synt
Manufacture: Chevron
Description: Havoline 505.01
Manufacture: Delek
Description: Delek IDI
Manufacture: Denicol
Description: Denicol Pro Syn 4
Manufacture: Elf
Description: Elf Excellium DID
Manufacture: Engen Petroleum Ltd.
Description: Engen Formula 505.01
Manufacture: Esso
Description: Esso 505 01
Manufacture: Eurol
Description: Eurol Turbo DI
Manufacture: Fina
Description: Fina Delta 505.01
Manufacture: FL Selenia
Description: Aktual Top Synth
Manufacture: Fuchs
Description: Fuchs TITAN Supersyn Plus
Description: Labo Syntha High Tech Synthese
Manufacture: Galp energia
Description: Galp Formula 505
Description: Galp Formula TD 505
Manufacture: Gedol
Description: Champ
Manufacture: Ginouves
Description: York 742
Manufacture: Gulf
Description: Gulf GDI Extra
Manufacture: Igol
Description: Igol Process 505.01
Manufacture: Ina
Description: INA 505.01
Manufacture: IP
Description: IP Sintiax 505
Manufacture: Kuwait Petroleum
Description: Q8 Motoroil 505 01
Manufacture: Liqui Moly
Description: Liqui Moly Diesel High Tech
Manufacture: Mapetrol
Description: Mapetrol 505 01
Manufacture: Meguin
Description: megol Motorenoel Super Leichtlauf Technology
Manufacture: Minerva–Oil
Description: TSH 5W–40 505.01
Manufacture: Mitan
Description: Alpine PD Pumpe Dã¼se
Manufacture: Mobil
Description: Mobil Synt S Special V
Description: Mobil Syst S Special V
Manufacture: Mogul
Description: Mogul Forte Racing S
Manufacture: MOL
Description: MOL Dynamic Synt
Manufacture: Motul
Description: Motul Specific 505.01
Manufacture: MRD
Description: Motor Gold Supertec PD
Manufacture: Oel–Brack
Description: Midland Axxept
Manufacture: Oest
Description: Oest Leichtlaufã¶l 505.01
Manufacture: OMV
Description: OMV syn com diesel
Manufacture: Panolin
Description: Panolin Daytona
Manufacture: Pentosin
Description: Pentosynth 5W–40 TS*
Manufacture: Poweroil High–Tech–Schmierstof
Description: HD SL CF PD Pumpe/Dã¼se Synth.
Manufacture: Quaker State
Description: Quaker State Diesel Plus
Manufacture: Rafinerija Modrica
Description: Optima 505 01
Manufacture: Ravensberger Schmierstoffvertri
Description: Ravenol VPD
Manufacture: Rothen Oil
Description: Rothen Extrasint
Manufacture: Shell
Description: Shell Helix Diesel Plus VA
Manufacture: Sinopec
Description: Blue Spirit
Manufacture: Slovnaft
Description: Madit 505 01
Manufacture: SRS Schmierstoff Vertrieb
Description: Wintershall Leichtlauf–Motorenã¶l PD
Manufacture: Startol
Description: RASANTA SPECIALSYNT
Manufacture: Statoil
Description: Statoil SuperWay 505.01
Manufacture: Sunoco
Description: Sunoco Ultra semi synthetic
Manufacture: SWD
Description: Concep–Tech Synth.
Description: swd Primus Synth.
Manufacture: Texaco
Description: Texaco Havoline 505.01
Manufacture: Total
Description: Total Quartz 505.01
Manufacture: Unil Opal
Description: Opaljet 505.01
Manufacture: Valvoline
Description: Valvoline DuraBlend Diesel motor oil
Manufacture: VAPS
Description: VAPSOIL 505 01
Manufacture: Westfalen AG
Description: Westfalen Megatron
Manufacture: Wolf
Description: Wolf Masterlube Synflow PI
Manufacture: Wã¼rth
Description: Triathlon Special PD
Manufacture: Yacco
Description: Yacco VX 505
Manufacture: YPF
Description: YPF Elaion Full Performance TDI
Jul 11, 2009 | 2001 Volkswagen Golf
Urgent notice
Go to:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?BV_SessionID=%40%40%40%401047994115.1225656652%40%40%40%40&BV_EngineID=cccgadefijdhhdecgfkceghdgngdgnn.0&ModelDLOS=Windows+XP|132594&ModelDLCat=null&x=50&y=7&BV_SessionID=%40%40%40%401047994115.1225656652%40%40%40%40&BV_EngineID=cccgadefijdhhdecgfkceghdgngdgnn.0&ListType=Model&ct=DL&moid=1209157&rpn=PSAA0U&OrderBy=D&PublicStartIndex=0&PrivateStartIndex=0&PublicCutOff=&PrivateCutOff=&AddOldPublicItems=false&AddOldPrivateItems=undefined&all_docs=false
Good luck
Nov 02, 2008 | Toshiba Satellite A100-S8111TD Notebook
Hotkeys
Go to:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?BV_SessionID=%40%40%40%401047994115.1225656652%40%40%40%40&BV_EngineID=cccgadefijdhhdecgfkceghdgngdgnn.0&ModelDLOS=null&ModelDLCat=null&BV_SessionID=%40%40%40%401047994115.1225656652%40%40%40%40&BV_EngineID=cccgadefijdhhdecgfkceghdgngdgnn.0&ListType=Model&ct=DL&moid=882862&rpn=PSM40U&OrderBy=D&PublicStartIndex=25&PrivateStartIndex=0&PublicCutOff=&PrivateCutOff=&AddOldPublicItems=false&AddOldPrivateItems=undefined&all_docs=false#PublicList
and get the HotKeys Utility there. It should solve it.
Oct 31, 2008 | Toshiba Satellite M45-S331 Notebook
Instal modem
Hello.
Just go to:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?BV_SessionID=%40%40%40%401983738700.1225160255%40%40%40%40&BV_EngineID=ccccadefhmefmdecgfkceghdgngdgnj.0&ModelDLOS=null&ModelDLCat=Modem|105511&x=9&y=8&BV_SessionID=%40%40%40%401983738700.1225160255%40%40%40%40&BV_EngineID=ccccadefhmefmdecgfkceghdgngdgnj.0&ListType=Model&ct=DL&moid=128929&rpn=PS500U&OrderBy=D&PublicStartIndex=0&PrivateStartIndex=0&PublicCutOff=&PrivateCutOff=&AddOldPublicItems=false&AddOldPrivateItems=undefined&all_docs=false
and dowload according to your operating system (only Windows 2000 and XP are available).
Oct 27, 2008 | Toshiba Satellite 5005-S504 Notebook
Computers & Internet Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
