Question about Sole Fitness Sole E35 Elliptical
We have a new E35/E95 elliptical Trainer, ( 5 wks) and getting a E2 motor error
Error 20 on Q47 Octane Eliptical
Sounds like it needs to be fixed. It will need a new left motor and cord most likely, less likely a lower board.
Apr 14, 2013 | Octane Fitness Octane Q47 Elliptical...
E3 error on sole E95 elliptical
The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
Sep 20, 2012 | Exercise & Fitness
Operating manual sole e35
go to www.iconservice.com for free download
or http://fitness.manualsonline.com
Good luck,sincerely. G-d bless you
ERNESTO CUADRA
MANAGUA,NICARAGUA
Dec 12, 2011 | RTO Sole Fitness Package F85 Treadmill &...
My Kettler cross trainer Mondeo gives me program error E2 on the display. Kettler has cleverly hidden any information about what this actually means (so I can fix it). Thanks for any help you can...
E-2 FAULTS ARE PROBABLY DUE TO A FAULTY CONNECTION BETWEEN THE CONNECTING PLUGS-MINE WAS,I CHANGED A LEAD IN THE END AND SOLVED THE PROBLEM.PLEASE SEE MY POST ON THIS SITE ON THIS MATTER. MARK DAVIES
May 22, 2011 | Kettler Mondeo Elliptical Trainer
Eliptical is showing E2
E2 Error Code - As researched here, I found a problem with the electrical wiring to the motor, dc module (P/N 000-8453}. I checked the plug connection for bent pins and bad continuity in the circuit. Okay. What I found was bad connections at what I will call the stepper motor that is located on the module. This motor adjusts the location of the Magnet Pack Assembly in relation to the Flywheel to change workout resistance. The terminals where the wires are soldered to the motor are of a riveted type of connection. By removing the resistence adjusting cable lock nut, threaded end and the cable, I was able to cycle the pulley back into operating range by plugging in and unplugging the power cable multiple times. Each time that I would plug the power in, the pulley would rotate a couple of degrees in the clockwise direction. Then, reattaching the cable assembly, and applying pressure to the stepper motor terminals, the unit would time and orient itself properly when powered up with No Error. To remedy the problem, I applied a little solder using a soldering iron to the riveted type connections making them a Better, soldered connection. I hope this helps.
Jan 22, 2011 | Schwinn 430 Elliptical Trainer
Error code 2 on schiwnn upright bike
Console displays “E2” error code
Solution: A. Check data cable integrity. All wires in cable should be intact. If any are crimped or cut, replace cable. B. Check data cable connections/orientation. Insure cable is connected securely and oriented properly. Small latch on connector should line up and snap into place. If the above tests reveal no problems, replace the DC Motor.
• TECHNICAL/CUSTOMER SERVICE Nautilus, Inc. World Headquarters 16400 SE Nautilus Drive Vancouver, Washington, USA 98683 Phone: 800-NAUTILUS (800-628- 8458) Fax: 877-686-6466 • CORPORATE HEADQUARTERS
Apr 01, 2010 | Schwinn 430 Elliptical Trainer
Error message on elliptical machine
Try unplugging for 5 mins plug back in might reset .
Jan 23, 2018 | Kettler Mondeo Elliptical Trainer
Sole Fitness Sole E35 Elliptical Logo
67 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
