Question about General Electric Hardware & Accessories
How to set a ge security timer 15151 - General Electric Hardware & Accessories
How set ge timer
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/GE-timers-and-manuals.html
Links above cover wide variety of GE timers
Repost question with clear description of timer
Gene
Feb 11, 2015 | GE Hardware & Accessories
Ge 7day Home Security Timer ge5112n
Copy following link to help identify timer:
Add a comment and include description of timer and question about timer.
Gene
h
Sep 20, 2013 | Hardware & Accessories
Review ge 15312 settings
Copy following link to identify timer, download manual and link to detailed wiring diagrams.
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
This timer has too many buttons, and programming steps are seriously layered. I think they were trying add programming options, and to avoid confusion found with other brands dawn-dusk timer programming, by adding confusing options and issuing a manual with tiny print.
http://waterheatertimer.org/pdf/GE-15312-sun-smart-Manual.pdf
Look on page 1 of manual on right side, just above 'random security options' heading: Manual says you can use + - buttons to scroll through programs.
OR: Press set-up button twice and P1 ON will display: Display should also display selected setting.
Press set-up again to see P1 OFF, etc
OR: Press set-up twice, and press Enter once.
Press auto button to exit programming, and current time should display.
Nov 13, 2012 | GE Hardware & Accessories
GE plug in mechanical timer model 15417
Copy following links to identify timer and setting analog timer by experimenting with features.
GE timers change appearance as model numbers are upgraded, but all 24-hour analog timers have same basic features.
http://waterheatertimer.org/GE-timers-and-manuals.html#15119
Sep 23, 2012 | General Electric Ge 24-hour Mechanical...
How to program residential timer mod no 49750/tm261a
49750 sounds like a Woods timer number, but I can't identify for sure
Woods makes timers for many other brands that are sold under different numbers
http://waterheatertimer.org/Woods-timers-and-manuals.html
Amazon shows First Alert tm261 random vacation timer
http://www.amazon.com/First-Alert-Tm261-7-Day-Vacation/dp/B000P6W4OE
If this is not your timer, then add a comment.
First Alert tm261 random vacation timer is similar to GE 15151 shown on following page.
GE 15151 has a manual
First Alert appears just below GE 15151
http://waterheatertimer.org/GE-timers-and-manuals.html#vacation
A vacation timer cannot be programmed.
Look closely at outer edge of dial and see that dial has small plastic protrusions that stick out.
These protrusions are trippers that cause timer to turn lights on-off at random times so home looks occupied when on vacation.
Dec 26, 2010 | Woods Hardware & Accessories
How do i set this time to come on and go off daily
I believe the First Alert timer is same as GE 15151 vacation timer.
Also look at Woods timers on link below to help identify timer.
A vacation timer turns on-and-off randomly to give the appearance that somebody is home
This timer cannot be set for daily on-off schedule.
GE markets a number of timers for daily repeat programming:
When buying a timer, note that some are for 2-prong plugs and some for 3-prong plugs
http://www.amazon.com/dp/B0015GKI96/?tag=picc-20
http://www.amazon.com/dp/B002HEY300/?tag=picc-20
Woods makes daily timers and a weekly timer
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
http://www.amazon.com/Woods-59202-Vacation-Security-Appliance/dp/B001Q9EFT6
Dec 20, 2010 | First Alert Tm261 7Day Vacation Timer
How do i set this timer to come on and go off daily?
A vacation timer turns on-and-off randomly to give the appearance that somebody is home.
How does this timer work? I lost pkg with info.
Rotate dial until current day and time line up with arrowhead located on inner dial.
The timer will turn on-off according to preset schedule
Dec 19, 2010 | First Alert Tm261 7Day Vacation Timer
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
To override time and turn on Load, move override to ON position.
Dec 06, 2010 | GE 51587 MultiEvent Timer
Hardware & Accessories Logo
162 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Craig Butler
Craig Butler
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
