Question about Samsung Notebook NP900X1B-A01US 900X1B-A01
Samsung NP900X1B-A01FR Ram slot
How to access the memory slot to change th SODIMM. I removed the bottom cover and the battery I can see the SSD, ventilator, but the memory slot is not there. It must be on the other side of the motherboard. How to access it ?
    Problem Solver:
  • 18 Answers
Most likely you will have to remove the keyboard to access the memory slots. I don't know why they do that. Most manufacturers have an access panel on the bottom for ram.
Posted on Mar 04, 2014
Testimonial: "Thank you Stephen. Since I digged this question out at Samsung consumer service and at the provider of my useless sodimm memory, I can say now that my particular model NP900X1B-A01FR is NOT upgradable. The memory components are soldered on the motherboard."
How do i find the memory slot on my Advent Quantum Q100?
The Advent Quantum Q100 laptop has one Ram memory slot.
The Maximum Total Amount of Ram Memory is 2GB.
It uses SO-DIMM ram memory that is DDR2 at 667 MegaHertz. (667MHz)
Also known as PC2-5300 {SO-DIMM style}
The Ram Memory slot is under the Keyboard.
Past this point I am at a loss to describe how to remove the Keyboard.
1) Either you have to remove the LED cover above the Keyboard, and below the LCD screen to access screws which hold the Keyboard in place, (Computer off, and ALL power removed. AC adapter {Charger}, and Battery),
OR,
2) The LED cover (Power On button, LED's, etc, are in the cover), has to be removed, and there may be one, or two screws coming up from the bottom of the laptop, which hold the Keyboard in place.
Regards,
joecoolvette
Jun 26, 2011 | Advent Computers & Internet
How to install PNY OPTIMA 2GB DDR2 667 MHz memory card in lap top
Turn the computer off.
Remove the battery.
Unplug the AC adapter.
Turn the computer bottom-up.
Look for a few screws that secure a small panel.
Unscrew those screws, and remove the panel.
If you've selected the right panel, you should see your current RAM.
On the LEFT and RIGHT edges, there are small "fingers" that are holding the RAM.
Gently pull those fingers away from the RAM, and it should pop-up slightly, and you should be able to remove the RAM.
Notice that the "notch" in the middle of the RAM is slightly off-centre.
Insert the new RAM into the socket, and gently press down, until those two fingers "click" to grab the new RAM.
Depending on your "old" RAM, you may have:
* one "occupied" RAM slot (1GB), and one "empty" RAM slot;
* two "occupied" RAM slots (512MB/stick).
So, you may have to remove one RAM stick, to expose an "empty" RAM-slot "hidden" under the RAM.
Or, the "empty" RAM-slot may be visible without removing the RAM.
Or, you may have to remove one of the 512MB RAM-sticks, in order to free-up a slot for the "new" RAM.
Replace the cover-panel, and screw it in.
Reconnect the battery.
Reconnect the power-supply.
Start the computer.
Click Start
Point at My Computer
Right-mouse click on My Computer
Choose Properties
It should display your CPU-speed and the "new" amount of installed RAM.
Dec 10, 2009 | PNY Computers & Internet
I want to upgrade the ram in my IBM thinkpad R52 laptop. Do I have to buy DDR1 or DDR2?
You have to buy DDR2. The compatible memory is DDR2-533 PC2-4200, 200p SODIMM, 1.8v
To install the memory, follow these steps:
  1. Turn off the system; then disconnect the ac adapter and all cables from the system.
  2. Close the system display, and turn it over.
  3. Remove the battery.
  4. Loosen the screw on the memory slot cover; then remove the cover.
    If the SO-DIMM is already in the memory slot, remove it to make roomfor the new one by pressing out on the latches on both edges of thesocket at the same time. Be sure to save it for future use.
  5. Find the notch on the side of the SO-DIMM.
    Note: To avoid damaging the SO-DIMM, do not touch its contact edge.
  6. Withthe notched end of the SO-DIMM toward the right side of the socket,insert the SO-DIMM into the socket at an angle of about 20 degrees (1);then press it firmly (2).
  7. Pivot the SO-DIMM downward until it snaps into place.
  8. Make sure that the card is firmly fixed in the slot and does not move easily.
  9. Replace the memory slot cover by aligning the back side of the cover first and then tightening the screw.
    Note:When you have added or upgraded a memory card, do not use your systemuntil you have closed the cover. Never use the system with the coveropen.
  10. Put the battery back in place, turn the system over again, and reconnect the cables.
To make sure that the SO-DIMM is installed correctly, do as follows:
  1. Turn the system on.
  2. Whilethe "To interrupt normal startup, press the blue Access IBM button"message is displayed at the lower-left of the screen, press Access IBMbutton.
  3. Select Start setup utility.
  4. The BIOS Setup Utility screen appears. The "Installed memory" item shows the total amount of memory installed in your system.
    For example, if your system has 256 MB of memory and you install a256-MB SO-DIMM in it, the quantity shown in "Installed memory" shouldbe 512 MB.
The compatible memory can be purchased here online.
Nov 27, 2009 | IBM ThinkPad R52 Notebook
HOW TO REPLACE RAM?
Hello there !!
Thank you for choosing Fixya.com
It's not difficult to install memory into your laptop. In fact, it is a fairly straightforward process.Using a screwdriver and a little care you can speed your laptop or notebook up significantly.
You'll require:
  • Compatible Laptop SODIMM memory module/s.
  • Anti-Static Wrist-strap (if available).
  • A Screwdriver suitable for your laptop's memory cover
Here's the tutorial that you can use to change the RAM:
http://www.helpwithpcs.com/upgrading/install-laptop-memory.htm
Hope this will be informative.
Sep 03, 2009 | HP NC4010 Notebook
Changing the ram in my toshiba stellite a45 laptop
I don’t have a diagram for upgrading memory in this particular model, but it’s very easy. You can access both memory slots from the bottom of the laptop if you remove the memory cover. The cover is located in the middle, right beside the fans. All you have to do is remove 2 screws and remove the cover. I believe Satellite P15 memory is expandable to 2GB in both slots (Slot A + Slot B = 2GB) and you can use PC2100 DDR RAM, PC2700 memory should work too (it will run at PC2100 speed).
Check the laptop specifications before you buy new RAM module. I just discovered that different Satellite P15 models use different memory types. For example, according to Toshiba specifications Satellite P15-S409 uses PC2100 DDR memory, but Toshiba Satellite P15-S479 uses PC2700 DDR memory (I think it might be a typo, but not really sure).
Jul 31, 2009 | Toshiba A45-S121 Notebook
Can't Find 2nd ram to upgrade memory
Sometimes Laptops will have 1 slot internal and 1 slot on the bottom side thats readily accessible via a removable plate.
You'll be perfectly find with the 1GB internal and adding the 2GB to replace the 1GB stick on the bottom side.
Also Windows XP and VISTA 32bit can only address and use about 3.25GB of ram anyway.
Recently Microsoft released a patch that's kind of tricking consumers, People calling and complaining so much to MS and PC manufacturers about not seeing all their ram when they installed 4GB so they Released a fix that shows it as 4GB but still the 32bit OS cant use the extra over 3GB
Apr 22, 2009 | Computers & Internet
How to upgrade RAM memory for Laptop Philips X50 Freevents?
there are 2 memory slots under the keyboard cover at the front right of the laptop. If you unscrew the 4 screws at that run along the front of the base and the 2 that relate to the front right as you look down at the keyboard you will be able to gently unclip the keyboard cover on that side and gain access. be careful though as the cover is held in place on the left by a hidden clip that I have not found as yet.
The dimm installed in the back slot is a 512mb ddr333mhz pc2700 sodimm.
Apr 16, 2009 | Computers & Internet
Inspiron 6400 notebook
There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
The cover ont he bottom if the laptop is easy to access and add more memory.
Dec 31, 2008 | Dell Inspiron 6400 Notebook
INSTALLING MORE RAM
Located Under That Cover On On The Underside Of Your Laptop , Remove The Screws And The SODIMM Memory Modules Are Located There
Goodluck
Aug 26, 2008 | Dell Inspiron 2200 Notebook
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Samsung Notebook NP900X1B-A01US 900X1B-A01 Logo
231 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
