Question about Clover Corporation CDR-4070 Video Recorder
How to dvr connected laptop - Clover Corporation CDR-4070 Video Recorder
How can I find lost dvr recordings?
A DVR is basically a hard drive. Connect a laptop to it using a USB cable and see if you see the hard drive as a removable volume in Windows Explorer.
Mar 10, 2016 | Televison & Video
Connect dvr
Connect DVR to what?
Dec 19, 2013 | Lenovo 3000 Y410 Laptop
I'm trying to transfer video from my Swann DVR4-1000 to my laptop using a USB transfer cable. When I plug the cable in, the laptop doesn't seem to 'find' the DVR. What am I missing? Thanks...
Did the system come with a setup CD? If so, unplug the DVR from your system, insert and run the setup CD then plug in the DVR and it should recognized.
May 28, 2011 | Computers & Internet
CAN I CONNECT MY DVR TO MY LAPTOP TO DOWNLOAD
It depends on your DVR. In most cases, the answer is NO, unless you have a DVR that accepts an RJ45 (similar to the one used in your computer to connect to the internet). SOME DVRs can be connected to an ethernet hub, and if you connect your computer to the same hub, you MAY be able to access it. Once again, it depends on the specific DVR model you have.
Mar 26, 2010 | Gateway Computers & Internet
Cant access lorex DVR from the internet
u need a public ip with an open port, and portforward the port with the ip of ur dvr
Mar 15, 2009 | Home Security
Trying to connect dvr to my laptop
did you enter proper ip or url in configuration . when cldvr v 101206 opens ther is config button u click that enter same ip adress of dvr. this dvr ip adress you will see in dvr system ip configuration. that ip you have to eneter in config button and than click connection button and eneter passowrd admin and there you go
Jan 22, 2009 | Clover Corporation CDR-4070 Video Recorder
Actiontec GT701-WG doesn't recognize a DVR on the LAN
I think the screen you may be looking at is the Application layer forwarding screen, the drop down box being populated by DHCP clients, that's why it isn't seeing the DVR. The DMZ Hosting screen doesn't have a drop down box, it only requires an IP address to be entered.
Hope this helps!
-Backu
Jan 16, 2008 | Actiontec (GT704WG) Router
How to connect YAMAHA DVR-S120 to computer
As long u`ve got audio out on ur Vaio (usually headphone mini jack on laptop`s) use stereo mini jack to RCA (both male plugs) extension cable. U may use video or vcr inputs on Yamaha. Be careful, when adjusting volume on ur Vaio - start from mid range & compare with other sources - DVD, TUNER etc. I`m not sure, but ur model got an optical SPDI/F audio output. In this case use toslink cable. Cheers
Dec 27, 2007 | Yamaha DVR-S120 DVD Player
Clover Corporation CDR-4070 Video Recorder Logo
15 people viewed this question
Top Clover Corporation Televison & Video Experts
Electro Med Services...
Are you a Clover Corporation Televison and Video Expert? Answer questions, earn points and help others
