Question about Car Audio & Video
How do you remove fuse box cover on 2005 ford k a
  • 1201 Answers
SOURCE: no dash lights on a 1985 ford f150.. replaced all the bulbs, fuse box cover is missing and no manual, so which fuse do I check?
Facing fuse box, left hand side, bottom fuse
Posted on Jan 21, 2009
  • 290 Answers
SOURCE: 2005 pontiac grand am lighter fuse
If there is not a map molded into the cover, it will be in the owners manual
Posted on Mar 24, 2009
  • 136 Answers
SOURCE: Can't get the fuse box cover off
There is going to be a small hook and clasp type clip on one side of the box, you will either need to press it in or pull it out, Inspect the clip thoroughly before attemping, IT IS JUST PLASTIC.
Posted on May 07, 2009
  • 316 Answers
SOURCE: location of the fuse box in a 2000 ford escort sedan
You "passenger" fuse box, is located on the drivers side of the vehicle, under the dash. You "engine" fuse box is located under the hood, on the drivers side of the vehicle.
Posted on May 27, 2009
  • 13 Answers
SOURCE: Ford F150 2005 Fuse Box?
You can download the owners manual directly from Ford. It has the fuse box diagrams under the emergency roadside section
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Posted on Jul 24, 2009
Where is the fuse located for the wipers on a 2005 ford focus in the fuse box?
it will say it on fuse panel where fuses plug in or on the inside of fuse panel cover
Dec 30, 2015 | 2005 Ford Focus
Fuse box diagram for a 2005 Ford expedition
If you look inside the cover of your fuse box the diagram is depicted on the inside cover.
Apr 05, 2015 | 2005 Ford Expedition
All fuse box diagram for a 2005 Ford expedition
Look on the inside cover of your fuse box. It should be labled with all the different fuses and sizes.
2005 mustang drivers seat wont move forward, where is the fuse located?
The fuse is located in the motor compartment, passenger side behind the windshield washer reservoir. There is a cover over this power distribution box, pull on the latches on the front and back of this box, remove the cover and flip it over, the fuse will be #14, located at the front right side of the box. It will be a 30 amp cartridge fuse. Check it, if it is good, your problem lies elsewhere.
Mar 08, 2014 | 2005 Ford Mustang V6
How to replace fuse for horn in 2005 ford tauraus car
The passenger compartment fuse box is below the dash under the driverside. The lid that covers the fuse box has the fuse diagram on the inside and it will tell you which fuse is the horn fuse.
Sep 12, 2012 | 2005 Ford Taurus
Power mirrows will not work on 2005 F 150. What could be the problem.
Have you checked your fuse? If not you can look in the fuse box located under the right-hand side of the instrument panel. Remove the trim panel and fuse box cover to access the fuses. The fuse you are looking for is a 5 amp fuse and is in the number 3 position in the box (along the bottom row see diagram below). This fuse also covers the memory seats & pedals. This may be your problem but there may have been a reason it blew if it did blow and then you are looking and more work into the reason it is blowing if it continues to blow. I hope this helped and good luck.
Mar 01, 2011 | 2005 Ford F-150
Locate low beam headlight fuse on 2005 ford focus
The fuse must be in the main fuse box. The position and function of the fuses is normally marked on the inside of the fuse box cover and also in the owner's handbook. If you don't come right with these, work your way through the fuses looking for a blown one. To ease your search the low beam fuse it should be around 15 to 20 amps.
Feb 12, 2011 | 2005 Ford Focus
Where is the fuse panel for a 2005 ford focus four door
Passenger compartment fuse panel
The fuse panel is located below and to the left of the steering wheel by
the brake pedal. Remove the CD stowage box to access the fuses.
To remove a fuse, use the fuse puller tool provided on the power
distribution box cover located in the engine compartment.
Power distribution box
The power distribution box is located in the engine compartment. The
power distribution box contains high-current fuses that protect your
vehicle’s main electrical systems from overloads.
For this and other details can check the 2005 Ford Focus - Owners Manual (page 148 and next).
Hope help with this (remember rated this help). Good luck.
Jul 05, 2010 | 2005 Ford Focus
Which fuse is for ford taurus horn
Feb 01, 2010 | 2005 Ford Taurus
2005 ford focus fuse box
There is a 1 amp fuse in the under hood fuse box for the alternator charging signal. Also, there is a 175 amp fusible link for the alternator, which is located under a plastic cover, next to the top of the timing belt cover.
Sep 29, 2008 | 2005 Ford Focus
Car Audio & Video Logo
13 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
