Question about Samsung Bdp1500 Blu-ray Disc Player no Remote
Upgraded firmware with usb now get no functions
Upgraded firm ware with usb flash drive and now with the tray closed the display shows close
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 924 Answers
I'm sorry. What is the issue with that? It closed and the unit shows it's closed. Please explain.
Posted on Feb 10, 2014
416b-4174-b680-0f00-c000-0034
I had this error code as well. Here's the solution that ended up working for me:
  1. Eject the disc tray and remove any disc from the console.
  2. Important: Do not close the disc tray. Leave it open.
  3. With the disc tray open, remove the power cord from the back of the console.
  4. Gently push the disc tray about half-way back into the console.
  5. Plug the power cord back into the console.
  6. Push the power button on the console. The tray should close the rest of the way, then the console should restart and display the Xbox Dashboard.
  7. Important Do not use the controller or the disc eject button to turn on the console.
  8. Try updating your console software again.
What this does is put the DVD drive into Mode-B, which is an alternate operating state that allows the drive's physical memory banks to be flashed with new firmware. Because the latest XBL update involves flashing the drive with new firmware, you may need to physically put the drive in Mode-B. The latest update flashes the drive to make it compatible with Microsoft's new high-capacity disc format, XGD3, which will be used sometime in the future.
Jun 10, 2014 | Microsoft Xbox 360 Console
416B-4174-1601-0300-C800-0036
here's the solution that may work for you
My xbox says its connected to xbox live and it updates but when it gets to the end its say cant process update status code:3080-335a-1380-0500-cooo-0032
I think I had this error code as well. Here's the solution that ended up working for me:
If this solution was helpful, please leave a positive rating!
Jun 19, 2011 | Microsoft Xbox 360 Console
I was looking for updates n when it was finished download my i phone model no a1203 8 gb not able strted. in my i phone shows cable n itunes and in laptop itunes shows massage like ' the simcard inserted...
roll back the firm ware ,,,, or check for the old firmware and then install it .. its becaused you have to jailbreak the upgraded firmware
vote if it helps
Mar 31, 2011 | Cell Phones
Display C 4551 open and close front door to reset. Minolta magicolor 8650
Cyan print has failed get it replaced, If you get a KonicaMinolta tech he can try a firmware fix you must have access to KonicaMinolta secure web site for the firm ware.. Normally what is done are all four print heads are changed in one setting
Jan 27, 2011 | Minolta Office Equipment & Supplies
When i turn it on it just shows the ILO symbal and flashes
Hello.
In order to fix Your iLO Mp3 Player please follow these steps:
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
    Download the Firmware.
  3. Click Open to initiate the download.
  4. Double click on the ILO or Siren folder icon. There will be 14 icons.
  5. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
    Then click Run - this will open the Install Wizard.
  6. The Install Wizard has the instructions on the screen as you go through it.
    Once the firmware has installed, please click the Start menu, then Programs.
  7. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
Additional Tip: The player itself requires a lot of power while flashing the firmware. We suggest disconnecting all USB devices from the computer except the MP3 player and mouse; you can reconnect your keyboard once the firmware has been flashed.
Good Luck.
Nov 03, 2009 | iLO (2 GB) MP3 Player
My cd/dvd is making a clicking noise when i listen to it
The clicking noise is most common problem and almost many of the cd drives. the quickest resolution is to upgrade the firmware of the drive. i see you are using 1525 laptop. To upgrade the firmware click here. If this doesnot resolve the problem there is nothing else you can do. its a mechnical problem. Besides upgrading the firm ware the only solution is to replace the drive. Installation Instructions Windows based firmware flash update for HLDS GSA-T21N 12.7 tray IDE DVD+/-RW:- 1. Download and unzip the GSA-T21N_A1R1.zip into your desktop. 2. In ?GSA-T21N_A1R1? folder, please search for the ?Windows? folder. 3. In ?Windows? folder, please make sure you have the administrator right, and double click on ?GSAT21NA1R1.exe? 4. The firmware of the drive will be updated to a newer version. The target drive should be HL-DT-ST DVD+-RW GSA-T21N. 5. Please close other applications before updating and click on the ?UPDATE? button. 6. Now updating in progress. It takes a few minutes. Don?t turn off the PC. 7. Updating was completed successfully. Please reboot the PC and click on the ?REBOOT? button. DOS based firmware flash update for HLDS GSA-T21N 12.7 tray IDE DVD+/-RW:- 1. Unzip the GSA-T21N_A1R1.zip into your bootable USB key. 2. In ?DOS? folder, just type ?DOSA1R1.BAT? and answer ?y? if you want to download the firmware. 3. Now updating in progress. It takes a few minutes. 4. FW Update Completed. If this was helpful information. please rate my solution Very High.
Sep 22, 2009 | Dell Inspiron 1525 Notebook
IC25n020ATMR04-0 firmware how can i remove the firmware and replace it
certain utilities from salvationdata or acer lab can help one do a firmware back up and restore, also certain hard drive companies like seagate and wd have firm ware backup and restore utilities,hitachi has its firm ware saved in three places on the harddrive in the SA areas as SA A SA B AND SA C. one has to have hdd hitachi from salvation data to back up firm ware , which i feel is an expensive affair. or just go to a recovery guy and ask for firm ware upgrade done by salvation data or acer equipments
if the charges are exorbitant , let me know the firm ware of your hitachi drive and i will try to give it to you. pm me if you are not in a position to back up by any of my recommended methods
datarecoveryfactory
Sep 04, 2009 | Hitachi 08K0632 (ic25n020atmr04-0) 20 GB...
I have xerox workcentre xd105f, can't make copies,paper jam
P will flash on the screen when the paper tray is empty, paper misfeeds or the paper tray door isn't closed all the way. Make sure both (if you have 2 paper trays) are loaded, that the paper isn't folder and wrinkled, and ensure that the tray doors are closed firmly. Then hit start on the workcentre to continue any unfinished jobs.
Jun 19, 2009 | Office Equipment & Supplies
I need the drivers for a DVD-RW drive model # GSA-T40N. didn' t know if you could help
You do not need drivers for DVD-RW especially if you are installing it in Windows Xp or Windows VIsta.
Jan 01, 2009 | Computers & Internet
Samsung Bdp1500 Blu-ray Disc Player no Remote Logo
29 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
