Question about Kitchen Ranges
Hitachi hbc161e manual
CANT FIND TIMER
I took photo's without a memory card in the camera (Hitachi HBC 161E) and thinking i could retreiv them using my usb cable connected the me pc. However when connected the camera remains out of view to the computer. How do I retrieve my pictures
Apr 24, 2013 | Video Cameras
Hi there, I can not reset the filter timer on a Hitachi CP-x4445 projector
Sometimes the reset on that timer can be picky. Here is the snippet from the manual that suggests you hold the reset for 3 seconds:
If it were me I would skip using the remote and follow these steps using the panel on top of the projector (using the arrows, etc) . Hold the right arrow to get the reset until it shows, rather than trying to count the seconds...
Mar 10, 2011 | Hitachi CP-X445 Multimedia Projector
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
I have the lamp,the tv is still not coming on. Is there something that has to be reset?
Yes. You will have to reset the lamp hours. It should be in your owners manual.
Copy and paste this link in your address bar if you don't have the manual:
50VS810
http://tv.manualsonline.com/manuals/mfg/hitachi/hitachi_projection_television_product_list.html
I have heard that this may work on your tv
1. Switch power ON, and press the TIMER button on the remote control transmitter, or the RESET button on the control panel, for approximately three seconds. The 'LAMP xxxx hr' message will appear on the lamp timer on the bottom of the screen.
2. Press the MENU button on the remote control transmitter, or the RESET button on the control panel, while the lamp timer is displayed. The 'LAMP xxxx [] -> 0 [|] CANCEL' message will then appear.
3. Press the [<|] and select 0, and wait until the timer display is cleared.
Sep 09, 2009 | Hitachi 50VS810 Television
Need user manual for hitachi logicool window ac
check out this link for the timer:
http://www.logicool-ac.com/pdf/015%20-%207%20Day%20Timer%20Operation.pdf
check out this link for the manual
http://www.logicool-ac.com/tech_downloads.html
Jun 09, 2009 | Hitachi RAS-09UH Air Conditioner
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Setup -Video Mode for Hitachi Plasma
You can download the manual from Hitachi here:
http://www.hitachionlinestore.com/manuals/32_42_50HDT50.pdf
Jan 01, 2008 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Kitchen Ranges Logo
26 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
