Question about Refrigerators
Location antibacterial filter whirlpool fridge freezer
  • 37 Answers
SOURCE: Whirlpool American Fridge Freezer
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Posted on Jan 03, 2009
SOURCE: how to reset water filter indicator on whirlpool
Resetting your "change filter" light:
  • Press the light switch (the one that the refrigerator door presses every time you close the door) 5 times within 10 seconds. OR
  • If the fridge has a filter button, press and hold it for 5-10 seconds.
Posted on May 17, 2009
  • 363 Answers
SOURCE: location of water filter on lg fridge freezer
OPEN DOORS LOOK IN UPPER RIGHT AND UPPER LEFT
Posted on Jul 22, 2009
toolkits
  • 1099 Answers
SOURCE: WHIRLPOOL FRIDGE FREEZER MODEL ART 201. REPLACING
It is often the case that if the thermostat is not working, the best route to take is to replace it rather than try to fix it, unless you have the necessary knowledge to do so. Most of the time, these are not as expensive as you would think and can be easily installed into the refrigerator. Here are some steps to follow to find out what the best route for you to take is in repairing or replacing your thermostat.
Good luck.....
Locate the thermostat and get all necessary model numbers, serial numbers and model codes. This information should be available for the refrigerator itself as well. Use this information to find and purchase the correct thermostat for your refrigerator.
Next, remove all power from the unit. Unplug the unit completely and make sure that it is not running before moving forward. Then, remove the old thermostat by cutting through the wiring.
To install the new thermostat, trim the lead wires to the right length. They are generally too long to start with. Terminate back into the circuit. The device will act as if it is a switch. This means that the direction or the coloring of the wires is not important. So long as you can cut off the current moving through them to the main defrost element you have no problem.
Make sure to properly dress the wires to insure that no part of them comes into contact with the defrost elements as this can cause them to melt.
Replacing a thermostat doesn’t have to be a lot of work, when you know what the problem is and can get easy access to the parts you need. Determine if your thermostat is bad by running through those tests first. When you do replace it, make sure to test to make sure it is working properly by allowing the unit to cool for several hours and testing the temperature within it.
Posted on Jul 30, 2010
rohntech
  • 422 Answers
SOURCE: Unfortunately the freezer side of
Look for the possibility that there is power on the refrigerator. The door gasket must be tight that cooled air isn't going outside. Check the temperature control, be sure it is in correct setting. Also the defrost timer setting, set it to the correct settings.
Be sure also that the freezer has no pinhole otherwise it is cause by a sharp object punctured the evaporator.
Thank you for asking.
Posted on Sep 01, 2011
I have a whirlpool side by side fridge with water dispensor and ice maker. The light is on that the filter needs replacing but I can't find it. Where is the filter located?
For most side by side refrigerators, the filter is in the grill at the bottom in the center (approximately) of the freezer side. Just push in on the cover over the filter (it is a circular piece).
For exact information, you need to provide the model. Many Whirlpool appliance manuals are available here: http://www.whirlpool.com/custserv/index.jsp . Type in the model in the Manuals & Literature box.
I hope this helps.
Feb 14, 2011 | Whirlpool Refrigerators
My whirlpool fridge freezer is not producing water from it the ice is not refilling there is water getting to the fridge freezer as we have check the water input.
Check you filter, if it has been more than a year it is blocked. It might also be a broken pump or froozen water line. I would start with replacing the filter then the pump and if no luck a heater kit
Dec 21, 2010 | Whirlpool GD2SHGX Refrigerator
My side by side fridge freezer is flashing CF alarm code. What does this mean
Change filter most likely this is the filter for the water.Meaning dirty water and foul tasting ice.Some filters are located in the front easy to reach areas at the bottom near the floor usually left side under freezer.
Nov 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Filter changed but still 1% on display panel
Is this a side by side fridge freezer? Most Whirlpool models with LCD display on front- reset filter indicator to display 99% by pressing and holding 'OK' button until filter resets to 99%. If you have a different model, or of this doesn't work, advise on model number and I can instruct further
Aug 10, 2009 | Whirlpool Freezers
Location of water filter on lg fridge freezer
Jul 22, 2009 | Refrigerators
Refridgerated water spout suddenly stopped producing water
Have you changed the water filter. It should be located in the front loer grille of the refrigerator.
Jan 10, 2009 | Refrigerators
Jan 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fridge freezer us
Make sure you have water to the fridge and then make sure your filter is pushed in all the way. If thats not it
Dec 30, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Flickering display panel on Whirlpool american style fridge/freezer
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
Jul 16, 2008 | Whirlpool Refrigerators
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
