Question about Drills
I have a Black & Decker hammer drill (Model KD 960) but recently dose not work. I removed the side cover and found a bloated and burnt square yellow capacitor. What cause this? Do I need to replace anything else beyond the burnt capacitor? I'm just curious that I just replace the new trigger switch recently but worry about the wrong wiring from two cables from stator (field coils) to trigger switch. Are these two wires are interchangeably connected to trigger or must be exact.Thnank you
rowdy45176
  • 2176 Answers
SOURCE: I have the black and decker hammer drill model
look at the back of the brush holder for a tab that the forward/reverse lever locks into, it might be broken not allowing it to shift.
Posted on Mar 03, 2009
SOURCE: Can't remove the chuck on a drill.
There are one-way (non-reversible) and two-way (reversible) drills. Mine is one-way. Methods for chuck removal are different for these two types.
Procedure for one-way (non-reversible) drills:
Drills of this type have no chuck screw, so one have to hold the spindle with a wrench, than to sharply strike the wrench with a hammer to spin it off.
Procedure for two-way (reversible) drills:
Open the chuck up and in the bottom is a screw that holds the chuck on the shaft.The screw turns in a clock wise motion to be removed and then you can top the chuck off the shaft.
Posted on May 20, 2009
SOURCE: Why doesn't my HP 1501 Makita hammer drill work
The problem was the cord at the base of the drill. The wires were broken, cause by constant bending. After souldering the wires, the drill works perfectly.
Thanks.
Posted on Jul 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: Need wiring diagram for switch on Cat #5378-20 SN
Go to Milwaukeetool.com and under service/manuals you can type in your model number and download the wiring schematic for this tool. If I have helped you with your request would you please rate this response accordingly and thank you.
Posted on Oct 25, 2009
Testimonial: "Thank you for the info."
wiringlunati
  • 576 Answers
SOURCE: Describe how to remove drill bit and install a
Most cordless drills use keyless chucks these days. Shift the drill into reverse and hold the main body of the chuck. Pull the trigger and the bit should come out. Put it into forward and run it to tighten onto a new bit.
Posted on Dec 03, 2009
I have a black and decker rotary hammer drill i can only read 3 numbers of the model it is 045 but its the last three sn number 0481121 under pat 3309541 need parts manuel for
Your one sounds like this one
http://www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-c-4167_7879_17406.html
However there are three variants on this page.
http://www.ereplacementparts.com/black-and-decker-hammer-drill-parts-c-4167_7879.html
Black and Decker Hammer Drill Parts ' Great Selection ' Great Prices ...
  1. Cached
  2. Similar
Black and Decker 22738 Type 1 1/2-Inch Hammer Drill Parts. 22738 Type 1 Black ... Black and Decker 27106 Type 1 3/4 Rotary Hammer Parts. 27106 Type 1 ...
Black and Decker 5045 Type 100 Rotary Hammer Parts
www.ereplacementparts.com/black-and-decker-5045-type-100-rotary-hammer-parts-...
  1. Cached
  2. Similar
Black and Decker 5045 Type 100 Rotary Hammer Parts .... Drill Parts Hammer Drill Parts Rotary Hammer Parts. Search within model. SEARCH. Discuss ' Repair ...
Black and Decker Hammer Drill Parts & Repair Help ' Fix.com
https://www.fix.com/parts/power-tool/drill/hammer-drill/black-and-decker/
  1. Cached
Shop for Black and Decker Hammer Drill parts today. Find genuine replacement ... (Type 100). Variable Speed Reversible Rotary Hammer · 5014. (Type 100).
Black and Decker Parts - Tool Replacement Parts ' Tool Parts Direct
www.toolpartsdirect.com/brands/blackdecker.html
  1. Cached
  2. Similar
Black and Decker Drill & Driver-Drill Parts · Black and Decker Hammer Drill Parts ... Black and Decker Rotary Hammer Parts Model Schematics and Tool Parts ...
Black and Decker 5043K_TYPE_3 ROTARY HAMMER KIT Parts ' Tool ...
www.toolpartsdirect.com/blackdecker-5043k-type-3-rotary-hammer-kit.html
  1. Cached
Find the Black and Decker blackdecker_5043K_TYPE_3 ROTARY HAMMER KIT parts you need at Tool Parts Direct. Shop thousands of Black and Decker ...
Black and Decker Rotary Hammer Parts ' Tool Parts Direct
www.toolpartsdirect.com/hammer/rotary-hammer/blackdecker.html
  1. Cached
Replacement Black and Decker Rotary Hammer Parts online. Tool Parts Direct has thousands of Rotary Hammer Parts to fix Black and Decker tools. Shop by ...
www.toolpartsdirect.com/hammer/rotary-hammer.html
  1. Cached
  2. Similar
Tool Parts Direct carries the largest inventory of replacement Rotary Hammer Parts for thousands of make and models. Buy Rotary Hammer Parts online for all of ...
Black & Decker Replacement Parts - 1800ToolRepair.com
https://www.1800toolrepair.com/tool-repair-parts/black-decker
  1. Cached
Black & Decker replacement parts for all Black & Decker tools. ... Black & Decker Cordless Circular Saw Parts ... Black & Decker Electric Hammer Drill Parts.
Beyond Parts - Black & Decker ServiceNet
servicenet.blackanddecker.com/Parts/Detail/29096
  1. Cached
  2. Similar
Available, Add Parts to Cart ... Model #, Model Description, Parts Diagram. 5041K Type 1 · MACHO I ROT HAM KIT · 5042-09 Type 1 · HD ROTARY HAMMER.
black and decker rotary hammer drill Google Search
Dec 25, 2016 | Rotary Drills
I have a Black & Decker 12 volt cordless power/hammer drill. I think it needs a new battery & possibly changer. Can I purchase a new battery & charger or is the drill too old?
try this parts supplier
Black and Decker Cordless Drill Parts
see if your model has a parts list for battery and charger
if discontinued
look for tha same used drill in better condition
or toss in the bin
Oct 20, 2016 | Drills
How can I reverse the direction on the drill?
Above the trigger there is a black slide switch that will reverse the direction if its in the colckwise direction the richt side is pushed in if counter clockwise the left side is pushed in.
Apr 06, 2016 | Black & Decker Black and Decker FIRESTORM...
Chuck removal B&D KD335 drill
I have instructions in the tip section that might help. There is usually not much difference in the removal of a corded or cordless drill. Let me know if you need more assistance.
Jan 25, 2012 | Decker BlackN Household Drills and Kits...
We need operating instructions for a Black and Decker 1.6J SDS Hammer Drill
Go to the Black & Decker website at http://www.blackanddecker.com/Manuals.aspx. Put your model number in the search block and it will give you your manual if it's still available.
Dec 26, 2011 | Black & Decker Drills
How do I remove an attachment to chuck of black & decker household drill with cord
There is an 2 types of chuck ether it is an screw type or not..If your drill chuck is an screw type it is easy to remove if it is not you must have a special tools to remove it.
Jul 23, 2011 | Decker BlackN Household Drills and Kits...
How to remove the chuck of Black & Decker Drill BD154R?
You need to open the chuck and remove the bolt from the bottom of it[usually a #2 phillips].The next step is to insert a 5/16 allen wrench into the chuck and tighten the chuck.Hold the drill with the chuck facing away from you then strike the allen wrench with a hammer on the right side[so it goes down] and now you will be able to remove it by hand,good luck.
Mar 21, 2010 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
I can't find how to put the drill into reverse! Model KD 562
The actuator should be on the top of the drill. if your holding the drill it is on top toward the front, moves left and right to change directions.
Feb 11, 2010 | Black & Decker Drills
Drills Logo
71 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
