Question about Denon DRR-M30 Dual Cassette Deck
Denon udra-77 hi the cassete deck will not eject or close on pressing the open close button, the rubber band between the wheel is intact, it will activate when manually turning the top wheel, seems to be stuck at the first phase of opening, grateful for any ideas
  • Denon Master
  • 1,258 Answers
The mechanism maybe out of alignment. Technicians and a service manual is how this gets fixed. The new belts are put in an the mechanism is position to the stop mode for the eject to work.
Posted on Jan 02, 2015
3 Suggested Answers
  • 205 Answers
SOURCE: Need manual for a Denon Dr-M3 cassette deck
http://www.retrevo.com/support/Denon-DRM-555-manual/id/363ci856/t/2/ try this link
Posted on Oct 15, 2009
Grubhead
  • 5152 Answers
SOURCE: Rubber bands
Drive belts are universal. Just measure the diameter of the old belts in MM and put that and the words "Cassette Drive Belt ...mm" into Google.
Posted on Jul 06, 2010
Testimonial: "The problem is that the rubber has lost its elasticity, that's why I'm looking for the service manual. Thank you."
HAVE A SONY DAV-HDX265 DISC TARY WONT OPEN AND DISPLAY READS (c 31 00)
Hi. If you are able to open, do so and check if you find a black rubber band that could have fallen off the tray. If you do just buy and replace. The band is is driven by some gears and helps open the tray and if it ages it gets damaged and cuts off. If the band is still intact, then see if the elasticity is still there and replace if there is no elasticity. If the band seems fine, then look at the gear near the end of the tray and try to open the tray manually.If you open the tray manually try see if there are broken or damaged gears. If non power the system and see if the tray closes. If it does then press the open button to see if it opens. If it does not, change the black rubber band that should work.
Aug 30, 2016 | Sony Audio Players & Recorders
My cassette keeps on ejecting so i am not able to play my tapes
http://www.fixya.com/support/t12006246-ive_got_denon_drr_m30_keeps_poping_back
The solution from AlecBrown133 above fixed the same problem for me. The only comment that I would add is that the same repair can be done with a normal rubber band. I used one to fix the same issue with my Denon drr-m30 and it is significantly cheaper than the 10 pound option.
Dec 23, 2013 | Denon DRR-M30 Dual Cassette Deck
Hi. I have a much-loved Denon DRR-M30 cassette deck but cannot get the system to recognize a tape. When I close the door it whirs for a bit then just reopens. There was no obvious cause and the unit has...
Hi. I had a similar problem. Remove the casing and you will see a rubber belt on the left hand side which looks like a miniature car fan belt. Even if it looks ok, the likelihood is that it is now slack and not operating properly. Its purpose appears to be to drive a white plastic cog wheel which secures the tray in position ready for the cassette to play. If the tension is insufficient to lock the tray, it automatically ejects after a couple of seconds of the whirring sound you describe. Contact Charles Hyde & Son Ltd of York who are main distributors for Denon and order part number 7790031, called a tray loading belt. The Sales number is 01759 303068 and that takes you right through to someone who will process your order; the part costs about £10 incl postage. They sent the part the day after I phoned - great service. It takes a few seconds to remove the old belt and replace it with the new one. Good luck
Aug 01, 2011 | Denon DRR-M30 Dual Cassette Deck
Having tray problems. Will not open or close on its own.When closed it says opening.When open it says closing. But nothing happens.
when you get the xbox tray to open eject then tap it you will see a rubber band take this out with tweezers and give a good clean with alcohol wipe then clean the wheels where rubber band sits put back on the rubber band hey presto 1 fixed draw
Mar 04, 2011 | Microsoft Xbox 360 Console
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
MY DVDR3380 TRAY WILL NOT OPEN, SAYS ITS BLOCKED
I had the same "Blocked" problem and solved it - by using a rubber band! Unplug the machine and take off the outer cover. Remove the DVD reader and take off the cover to the reader - you can now easily recover the DVD that was stuck in the machine. Now slide out the actual DVD tray, you will have to bend back a couple of restraining bars to get the tray out completely. You should now see a small white wheel which is actually the end of a concealed electric motor. There will also be a larger black pulley which controls the movement of the DVD tray. If there is no band connecting the pulley and the white wheel, that is your problem and I solved it with a small elastic band. Put everything back and turn on, wait for all the messages to clear and press the eject button - the tray opens simples. It has taught me never to force the tray in manually, but to always use the eject/open button.
Aug 22, 2009 | Philips Televison & Video
Cassete deck will not work, I put a tape in deck 2 and hit the record button and all it did is started to make a clicking noise. Next I tried to take tape out and the door would not open. I forcefully...
I have a sony twin cassete deck and the same thing happened to mine , it turned out to be the rubber belt inside was broken so i just bought a pack of assorted belts for $7.97 and replaced both belts .
Jun 05, 2009 | Aiwa NSX-A767 Shelf System
Radio preset Denon UDRA-f10 doesn't save
1) tune in to a radiostation
2) press the Memory button
3) select a preset number for 5 Second
4 Skip "press Memory again"
Feb 04, 2009 | Denon PMA-100M Amplifier
Rio HT2030 disc loader will not open
I have had the same problem. There is a rubber ban that acts as a drive belt to open and close the disc loader. i took the cover off and then the disc loader cover off to expose the bubber ban. Then i replaced it using two rubber bans from my daughter's braces and reassembled. Works great again.
Dec 23, 2008 | Rio HT2015 DVD Player / VCR Combo
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Denon DRR-M30 Dual Cassette Deck Logo
150 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
