39" rca tv rldedv3988-a no picture - Televison & Video
I HAVE AN RCA MODEL NUMBER RLDEDV3988-A
could be the power supply , check the ballast if the part is ok most likely is the power unit
Mar 16, 2015 | RCA Televison & Video
Picture quality and resolution
Try to download its user manual by internet. It has all details.
Jul 15, 2013 | RCA L32HD31 32 in. LCD HDTV
Rca L42phd37yx8 42' led tv blackscreen with sound wont show anything
Show a torch light on the screen (not too close) when the TV and program is running. If you can see the picture, the backlights have gone off. Anyhow, the TV needs attention by a qualified service technician.
Jul 13, 2012 | RCA Televison & Video
RCA entertainment series TV does not show the entire image
Check the picture settings. It sounds that the picture settings to TV is Zoomed.
May 29, 2012 | Televison & Video
Rca tv has sound no picture
Check its line output transofrmer [LOT] and related components. Replace them
Apr 22, 2012 | RCA Televison & Video
I JUST CONNECTED THE PC TO TV WITH VGA TO RCA CABLE BUT PICTURE WON'T COME ON THE TV SCREEN
Make sure that you have the correct display mode selected. While many connections like a VGA to VGA connection will automatically detect, I don't think a VGA to RCA adapter will. Go to control panel/display and see if your computer has detected the second display.
Also make sure the RGB or RCA is selected as the input source on your TV.
Once these are both set correctly you should be in business!
Dec 21, 2011 | Computers & Internet
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
How do I connect a VCR with the TV
connecting the VCR to a TV is not a big deal. There are two methods by which you can connect the VCR to our TV.
1. You can use a RF cord.
2. You can use a RCA cord.
I would suggest you use the RCA cord because the RCA connection has a better sound and display quality than the RF. So I would direct you on how to use the RCA connection method.
Here is a picture of what the RCA cord looks like for quick identification;
As you can see from the above picture that there are three cords. The Yellow cord is for display (video), while the with and red is for sound (audio Left & Right).
Turn of the VCR and the TV.
Look at the back of the VCR, connect the yellow to 'video out' and the white and red to 'audio out'. Note that the VCR might have only one audio out, that doesn't matter, just connect any of the red and white.
Now connect the other end of the cord to the back of the TV this way; Yellow will go to 'Video in' while the red & white will go to 'Audio in'.
Turn on the TV and VCR.
Select the TV to Source/AV and the display of the VCR should appear on the TV. Or better still, you can insert a cassette into the VCR, press play before selecting Source/AV on the TV.
By now the connection should be Okay.
If you any more questions or clarifications, please let me know as I would be glad to respond.....
Yours sincerely.
Elect_Comp.
May 24, 2011 | Sanyo Televison & Video
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Electro Med Services...
