Question about Western Digital Scorpio Blue WD6400BPVT - Hard drive - 640 GB - internal - 2.5 - SATA-300 - 5400 rpm... SATA II
Looking for a connector for wd scorpio blue WD6400BPVT to move data to jump drive
  • 56 Answers
These kind of "docks" can be found on ebay for drive diagnostics or file transfers without opening your computer.
Posted on Mar 22, 2014
5 Suggested Answers
  • 166 Answers
SOURCE: Installed a 250GB WD Scorpio and it shows as a 130GB drive
make sure the laptop will handle a drive bigger than 130 gig. if not make two partitions when you set it up, bios wont see it but usually windows will. also, sometimes ive found that if i delete the partition a few times it eventually reads right. dont know why but have done it that way several times. you can also download a diskmanager program from thier website which makes an overlay if your bios wont support a 250.
Posted on Aug 23, 2009
  • 118 Answers
SOURCE: wd scorpio blue 160 gb
Reset it or format it ? cause there is no reset for hard disks.
Is your hard disk operational ?
Posted on Jul 29, 2011
bronk50
  • 27725 Answers
SOURCE: is it a common issue
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start righy click on my computer you should see your drive select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors or you could tick one box and wait until its finished then return and tick the other box
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive also download and run a registry cleaner cc cleaner is 100%free
http://download.cnet.com/ccleaner/
hope this helps
Posted on Aug 17, 2011
SOURCE: I got a HP DV6833us.
Note: If you cannot find drivers for your WD drive, it may be because most WD drives do not include drivers as they use a standard driver built into the OS. If the driver is built into the OS or is already installed and the OS continues to look for a driver, your drive has most likely failed or been damaged and needs to be replaced.
According to Western Digital: "Most current WD drives do not require additional drivers on the Windows or Mac OSX Operating System (OS) beyond the ones that are included with the OS."
In order to simplify the installation process WD elected to use the standard drivers that are built into common operating systems. While there are a few exceptions to this, in general, there are no drivers provided by WD for our drives. That's because the drivers a WD hard drive or SSD uses are part of your Operating System. As such, any trouble with these drivers should be handled by the regular line of support for your operating system - in most cases by contacting your system manufacturer, IT department, or the publisher of your OS.
Internal Hard Drives and SSD: All internal Hard Drives and SSDs use drivers that are built into the operating system. There are no drivers available for download because of this. If your internal drive is not recognized, it can be caused by one of the following problems:
  1. During an operating system installation, it may not see your drive at all or may request a driver. Under Windows you will need to press F6 in order to be prompted to enter a driver. Once you are prompted for a driver you will need to remove your Windows CD, and place a CD with the drivers for your SATA or EIDE controller card. These can be obtained from your System Manufacturer (Dell, HP, Toshiba, Gateway, etc.) your motherboard manufacturer, SATA or EIDE card manufacturer (if it is connected to a PCI or PCIe slot). Western Digital cannot assist you in locating these drivers, as every controller card requires a different driver.
  2. Your driver may be corrupted. The symptoms of this problem can vary - if it is your boot disk, your operating system may fail to load. If it is a secondary drive it may request a driver. You will need to contact Microsoft or your System Manufacturer for assistance in resolving this issue.
  3. Your drive may be damaged or have failed. A good test for this is to try the drive in another system. If the issue continues to occur, then this is most likely the case.
Posted on Sep 16, 2011
How to fix my wd scorpio and can use it again?
Open Control Panel ' select System ' select system devices ' look for yellow triangle on unknown device or under storage device / hard drives. Select detect / add new device with drive connected.
Feb 12, 2015 | Western Digital WD Scorpio Blue WD2500BEVT...
Lost password on WD Scorpio Blue WD5000BEVT hdd
Password is for the computer, not the hard drive. Get a Linux LiveCD and reformat the drive.
May 05, 2014 | Western Digital WD Scorpio Blue WD1600BEVS...
WD1600BEVS Scorpio pin settings
You shouldn't have any problems. The computer uses SATA drives and the drive is SATA and is also a 2.5" laptop HDD. Make sure that you have a way to install an OS , etc
Nov 13, 2013 | Western Digital WD Scorpio Blue WD1600BEVS...
Format wd scorpio blue wd250bevt
IS WINDOWS ON THE DRIVE THEN IT'S NOT POSSIBLE.
Jul 06, 2013 | Western Digital WD Scorpio Blue WD2500BEVT...
Will a 500GB hard drive work in a 250 GB slot on laptop without having to change partitions or anything
You did not mention which operating system you are using. Almost every operating system has partition manager utility. you can use any other utility by downloading from net. just search google.
Jan 23, 2013 | Western Digital Computers & Internet
Hard disk failure
Check if your hard drive is still in warranty period so you could ask for replacement from the manufacturer. Otherwise, simply buy a new hard drive and move all your data from the old one to the new drive.
SMART always predicts correct hard drive status and probably this time, you need to change it ASAP.
Hope it helps!!
Dec 07, 2012 | Western Digital WD Scorpio Blue WD2500BEVT...
Wd scorpio blue 160 gb how to reset
Jul 29, 2011 | Western Digital WD Scorpio Blue WD1600BEVS...
My hdd wd scorpio doesn't read in my Laptop, how can I fix it?
This guy does remote data recovery he may be able to help you. http://FreeDataRecovery.us
May 19, 2011 | Western Digital WD Scorpio Blue WD5000BEVT...
What do i need to install a WD Scorpio Blue 500Gb hard drive in my HP dv90052us laptop - i've got the drive but it does not fit in it's slot like the original drive does - i'm putting it in the second...
You may need a "caddy" -- a metal shell that wraps around the disk-drive, in order to line-up its "data" and "power" connectors with the matching "sockets" inside the second drive-bay.
Order the caddy from http://support.hp.com
Apr 18, 2010 | HP Pavilion dv9005us Notebook
I am using SuperDuper to clone my 160GB MacBook Hard Drive to a 500GB Western Digital Scorpio Blue. My problem is that I cannot determine why neither the SuperDuper program nor the MacBook itself...
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
Oct 24, 2009 | Western Digital Elements powered by WD 320...
Western Digital Scorpio Blue WD6400BPVT - Hard drive - 640 GB - internal - 2.5 - SATA-300 - 5400 rpm... SATA II Logo
89 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
