Question about Acer Aspire 1690 Notebook
Fan runs but then computer does not start - Acer Aspire 1690 Notebook
  • Acer Master
  • 1,087 Answers
Try tapping the F8 key while starting up which should take you into Safe Mode. If that fails get back to us.
Posted on Feb 09, 2014
When i turn on my hp all in one computer,it's telling me cpu fan can not be detected
Hello user...you are receiving this message at start-up because, in your bios system settings, "run fast diagnostic test" is enable...CPU fan is like a computer fan but attached with the cpu to cooled the cpu so that the cpu will function properly so as the computer...perhaps there is a problem with the fan, so its not running when the computer starts. This may harm your CPU, as a result may blow the circuits in the motherboard and eventually your computer will crash....for a technical advice, you may want to visit the nearest PC repair shop and change the cpu fan..
Jun 23, 2014 | HP Mini 1000 Netbook
Dell 370 fan runs loud and won't start
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Apr 23, 2012 | Dell Precision 370 (370TREC) PC Desktop
Fan blows high speed and computer wont start
How long havew you had the present motherboard in your computer? if over 3 years (and used on a dayly basies more then likely, your motherboard is in need of replacment because the capasitor/s are leaking (not giving the proper voltage to start and hold your computer at proper levels
Jan 14, 2010 | Dell Optiplex GX280 (99301) Motherboard
My m-1624 frequently runs at 60C or higher. I dont see a way to adjust fan speed. Or is it not an issue? thanks,
I'd start to worry when it gets to 70 degrees but it's running hot. There are some vents, usually in the bottom of the computer for the fan. You can try blowing them out with compressed air made for computers. That may clean your fan a little and help it work better. The fan may be starting to seize up or get tighter causing it to run and lower rpms. Might have to try and replace it if it gets much hotter but if the vent ports are dirty or the fan is running slower it will have to run longer to cool the notebook thus causing your battery to run down faster.
Nov 06, 2009 | Gateway M-1624 Notebook
All computer fans starts ok but trips with notice,
You may hear the case fans running. Remove PC cover and check CPU fan and replace, it may not be running at full speed.
Sep 23, 2009 | HP Compaq d530 SFF PC Desktop
My IBM T22 LAPTOP cooling fan does not work . When I start LAPTOP SYSTEM START BUT FAN NOT RUN. I dont know whether it its problem or not.
If the fan is not running, your computer will definately have a problem very soon. Sometimes, the fan is just clogged up by dust and debris. Head down to a local computer store or one of the box stores and purchase some compressed air dusters.
Dust out the fan and vents as best you can. If the fan still does not spin, your computer will easily overheat and, in all probablilty, shut down on you at random.
If left for too long, this could cause multiple other problems for your computer. I would recommend you look at getting the fan replaced as soon as possible if you cannot get it to work by dusting it out.
Good Luck!
Aug 07, 2009 | Computers & Internet
Hi there I have a dell computer and I
it is the simple problem of your motherboard you can go to workshop and then checked your RAM and processor fan and it's chipset
Jun 28, 2009 | Dell Computers & Internet
CPU fan not running?
If the fan isn't running, the computer probably shut itself down because it overheated. Check to make sure the cable going from the fan to the motherboard is securely plugged in. If it is and the fan still doesn't run, you have a faulty fan and need to replace it before you start up your computer again. It's not good to run a computer that hot.
Please rate, thanks!
Mar 18, 2009 | Computers & Internet
DELL DIMENSIONS 2300 COOLING FAN
Your system will run fine until the processor starts overheating... why not just replace the fan?
Oct 26, 2008 | Dell Mini Fan. Dimension (W x H x D) in....
Acer Aspire 1690 Notebook Logo
19 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
