Question about Konica Minolta Office Equipment & Supplies
Setting imag adjust - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,595 Answers
Sure what model??????????????
Posted on Mar 11, 2017
How do I adjust the setting to lighten copies?
Canon : PIXMA Manuals : Print Studio Pro : Settings Area ...
figure: Settings area (Correction). (1) Black and White Tone Adjustment Area ... Move the slider to the right to darken and left to lighten the color. ... the XPS printer driver (Canon series XPS) for Printer in the Settings area (Print Settings).
Canon : PIXMA Manuals : MX920 series : Adjusting Intensity
You can dilute (brighten) or intensify (darken) the colors of the overall image data ...Used Settings, and then choosing Color/Intensity Manual Adjustment under ...
Canon : PIXMA Manuals : Image Settings
When Image Adjustment is set, the brightness of the specified portion of the ... Use this function to reduce show-through in duplex documents or lighten the base ...
Oct 20, 2015 | Canon PIXMA MG3222 Wireless Inkjet Photo...
Keystone not working
Installation>Wall Screen>Keystone
The automatic keystone adjustment may not be carried out correctly
because of the ambient temperature and the installation
conditions of the projector and the screen. In such cases, correct
the keystone manually.
• When the projector is projecting images where acceleration is
present, such as in a vehicle and aircraft, the automatic keystone
adjustment may not function correctly. In such a case, set AUTO
KEYSTONE in the INSTALLATION menu to OFF and correct the
keystone manually.
• You can correct the vertical keystones. However, their adjustment
ranges are limited in such correction.
When the keystone adjustment is carried out, the adjustment
value is indicated. Note that this value doesn't mean a projection
• The allowable range of the adjustment value in the keystone
adjustment varies depending on the installation conditions.
• When the keystone adjustment takes effect, the resolution
decreases. In addition, stripes may appear or straight lines may
bend in images with complicated patterns. They are not due to
product malfunctions.
• Noise may appear on the screen during the keystone adjustment
because of the type of the video signal being projected and the
setting values of the keystone adjustment. In such cases, set the
keystone adjustment values in the range where the image is displayed
without noise.
• When the keystone adjustment is carried out, the image may not
be displayed correctly because of the type of input signal.
Mar 13, 2014 | Mitsubishi XD250U-ST DLP Projector
Setting dpi on my nikon d3100
DPI (dots per inch) is an output specification and is irrelevant to the camera. The camera puts a value into the field simply because it has to put something there. The DPI is set by the printing program when it prints a picture. A picture printed at 4x6 will obviously have more dots per inch than the same picture printed at 8x10.
Nov 30, 2012 | Nikon D3100 Digital Camera
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
Store icon
Press SELECT button at this icon to
store the adjustment.
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
For the color adjust on my view sonic VA 721 monitor, the red doesn't seem to work but the green and blue do. I purchased this monitor at a garage sale for not much so its not a big deal, it would just be...
just set the monitor on auto ..and it will adjust by itself..after that click right on the desktop ..than properties,,and after that settings in that click advanced..and you will get some buttons on the top of the window..see which one s for the colors adjustments and complete the setting from here is the image driver adjustment can set the color management ..
also you can make thi sdirectly from the color settings in the image driver ..from clicking on the image icon on the tray of the task bar ..
Aug 30, 2010 | ViewSonic VA721 17" LCD Monitor
How can i adjust the scanner to scan DARKER?
From the scanner menu in the “Advanced mode settings”, you can find the buttons for color settings.
Using Color Settings buttons, you can adjust the brightness and contrast of the whole image, specify highlights and shadows, and adjust the contrast and balance in an image.
Favorite Settings enables you to save a set of settings (Input Settings, Output Settings, Image Settings, Color Settings and Preferences) made for the focal cropping frame. If there are no cropping frames, settings for the whole preview area are saved.
You can also recall the saved settings and apply them to the selected frames or the whole preview area.
And you can adjust the scanner to scan darker.
Please find the explanation pictures attached.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 26, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
Image posterization in photoshop/lightroom on calibrated monitor
try downsizing the image. Else correct the posterization in Photoshop and set it as wallpaper.
Mar 19, 2010 | Adobe Photoshop CS4 for PC
How can a change the settings of the light in a veo stringray cam
go to camera settings and then adjust display settings. increase brightness level.
Jun 18, 2009 | Veo Stingray
Pictures appear to be darker than original in print outs.
You can make several adjustments to improve your images such as lightening dark areas, changing the exposure, sharpening blurred edges, and changing the brightness and contrast.
  • Exposure adjusts the overall intensity of light in an image.
  • Adaptive Lighting improves only the dark areas in an image without affecting the bright areas.
  • Brightness adjusts the amount of light in colors ranging from light to dark.
  • Contrast adjusts the difference in brightness between light and dark areas of an image.
  • Sharpness helps define edges and the smoothness of texture in an image. Use this tool to make a blurred image appear more focused.
Adjusting the image Follow the steps below to make adjustments:
  1. Click the View tab and select the image you want to edit by either clicking the image, or by clicking the small box at the bottom left corner of the image. Figure 1: Select the image c00603524.gif
  2. Click the Edit tab and then click the Advanced tab.
  3. On the Advanced tools tab, click Adjust Image .
  4. Select an adjustment from the list on the left. Figure 2: Adjusting the brightness c00603525.gif
    • The Exposure adjustment is automatically applied when the Adjust Image tool opens. Eight variations of the image are displayed on the left. The current image is displayed in the center. Each image represents a different level of adjustment. When you move the pointer over any of the images on the left, a large version of the image is displayed. Use Preferences to turn this large image preview on or off and to set the timing for the display.
    • If you want to use a different adjustment tool, select Adaptive Lighting , Brightness , Contrast , or Sharpness from the list.
  5. Select one of the images on the left.
  6. Do one of the following:
    • Click Accept to accept all changes and exit from the Color Toolkit.
    • Click Cancel to discard all changes and exit from the Color Toolkit.
  7. If you have finished modifying the image, do one of the following to save your changes:
    • Click Save to overwrite the original image.
    • Click Save As to save the modified image with a different name.
Aug 25, 2008 | HP Photosmart D7160 InkJet Printer
Image adjustment functions
SHARPNESS - The function is to adjust sharpness of capturing images. CONTRAST - The function is to adjust contrast (distinction between light and dark) of capturing images. SATURATION - The function is to set color depth of capturing images. GRADATION - In this function, you can select the brightness of an entire image. It is suitable when you want to add a brighter effect to a bright object (Hi Key) and a darker effect to a dark object (Low Key).
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
23 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
