Question about Samsung ML-2855ND Laser Printer
Stripes on printout - Samsung ML-2855ND Laser Printer
Samsung CLX-6220-FX vertical lines when scanning and copying
The reason for such lines if they appear only on scans/copies from the automatic document feeder (adf), but not on regular scans and printouts is that there is dirt on the small glass stripe next to the scanner area that is used for scanning from the adf. Just clean that glass stripe and the lines should go away.
Jan 21, 2014 | Samsung CLX 6220FX - multifunction fax /...
Stripes in the printout
Step1:Take out cartridge, check any vertical toner tracks on cartridge drum surface? replace cartridge if found. Step 2: Remove back cover take out fuser assembly, verify any toner tracks or toner particles deposited on Teflon sleeve?replace teflon sleeve.
Jan 22, 2012 | HP LaserJet P3005n Printer
I am getting vertical banding or stripes on my printout
Hi, I have solved the problem by taking the R2400 to a Epson agency to have the heads cleaned and the leaked black ink cleaned up.
Many thanks,
Howard
Oct 03, 2009 | Epson Stylus Photo R2400 InkJet Printer
Black stripes on fax printout
Do you have the stripes on all faxes coming in, regardless of the origin, or from just one place? If just one place, then the problem is that they have some dirt on their scanning glass. If from your machine, then check the photoconductor (if yours is a laser fax) or the printhead (if a thermal fax).
Sep 14, 2009 | Philips Office Equipment & Supplies
Stripes through printout epson c86
Click on Printer choose properties and choose maintenance and cleaning
Aug 29, 2009 | Epson Stylus C86 InkJet Printer
1 inch black stripe down edge of page
can you try to post a copy of what you see wrong . and try to do an internal printout " function-6-4-start- under the fax button. "
Nov 21, 2008 | Panasonic DP-150FX Laser Printer
My Canon PIXMA MP760 printer had been printing a horizontal stripe of a lighter cyan where ever that colour occurred. Today during printing it displayed an error. Unfortunately I didn't catch the number. I...
Maybe an obvious answer, but have you cleaned the print heads several times? You can also remove the cartridges, remove the entire print head and clean it with rubbing alcohol and a q-tip.
Mar 28, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Stripes on printout MD5000P
This happens alot, iteithermeans your inks running low, your inks too new, or its a low quality printer.
My suggestion would be to check your ink level, and if its fine, print out a few pages, then see if it helps.
Dec 29, 2007 | Alps MD 5000 Thermal Printer
Samsung ML-2855ND Laser Printer Logo
27 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
