Question about Hardware & Accessories
Ignition lockout L2 ideal logic combi 24 boiler
Hi, im having a living nightmare with my logic combi 24 and since day 1 which was 3 and a half years ago it has always on regular occasions locked out and flashed L2. very rarely can i get it to restart again and if i do it only lasts an hour if that and locks out again. iv had more than 10 different plumbers come to it and even a new electorode been put in but despite them getting the boiler going its been a few hours later its back to square one lockout. these cheeky beggars then want paying as they claim there work is done as they got the boiler on and going when they were present. pure cheek if you ask me as a decent tradesmen wouldnt do or say that. what they needed to do was admit they couldnt fix the problem with their 15,20,25 years experience and just say that. please help i have 4 kids and were neth heat or hot water and cant be paying anymore dodgy plumbers when the jobs not getting done. thankyou
  • RJ Systems (Retired) Feb 19, 2014
    Hi Donna. I added 2 comments for you and don't see then now. I think we can get you through this if you still need help. Let me know. Roger
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
  • 7 Answers
SOURCE: Combi bolier problem
either the h/w flow switch or diaphram reqs replacement or the secondary heat ex or (calorifier) is blocked and prevents the heat from leaving the biler to hget to he taps- the heat starts ok but backs up to the boiler very quickly causing it to shut down
Posted on Sep 18, 2008
SOURCE: no hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Posted on Mar 20, 2009
frcs68
  • 1605 Answers
SOURCE: I need user's manual for Danfoss Randall Thermostat TP4000
go to the following link.
download and print the user namual.
http://randall.danfoss.com/PCMPDF/40811v01.pdf
Posted on Apr 06, 2009
  • 6 Answers
SOURCE: Tascam DM-24 mixer is running crazy! Please help!!!
it needs a power supply.
Posted on Aug 16, 2009
Ideal Logic + Combi C30 not firing up.
Isconnect from the hive ,it has been known the hive thrmostat fails on ideal boilers.
Mar 22, 2017 | Water Water Heaters
My ideal logic combi 30+ is saying ignition lockout and my radiatiors arent heating up as well as my water not turning hot. How can i fix this please?
Lockout is a safety feature. Usually a latching condition and needs to be investigated rather than blindly reset. (The Combi has a bit more intelligence.) With the ignition locked out, you can't hi-fire the boiler, so no hot water of either type. The 'L' should also show a code number - check your user manual (google) for more guidance.
I've had a lockout on a non-combi: it was caused by lack of circulation of central heating water through the boiler.... The system boiled and the trip tripped. The pump WAS running, but wear in a valve actuator resulted in the valve feedback saying valve open while it was physically shut.
Dec 31, 2016 | Water Water Heaters
We have a Raypak Water Heater Boiler Model # H9-2002. Our problem is the boiler don't give to much heat The Safety Ignition light is red and I check the Fenwal Diagnostic Status Codes it is blinking 3...
is it a combi boiler pressure system if it is they need about 6 bar of water you have to top them up once in a while there are taps on them you turn one off and the other on dont turn the gas one off look at the instuctions you will hear the water coming in and turn it off when it gets to 6 bar about half way up on your gauge do not fill up passed the red line its about half way between 0 and the red
Nov 06, 2011 | Pool & Spa
MY IDEAL LOGIC 30 HAS FAULT CODE L2 ALMOST EVERY DAY SINCE INSTALATION DEC 2010
is boiler still under warranty?
normal warranty lasts at least 2 years
if so get ideal to send one of their engineers out
L2 relates to flame failure
either boiler has failed to ignite
or
boiler has not detected flame once lit
several causes
failure to ignite
ignition electrode/spark generator
failure to detect lit flame
detection electrode/detection lead
blocked condensate pipe
or defective condensate syphonic trap
you really need an engineer to check these components
Mar 16, 2011 | Heating & Cooling
Manual for MAINE COMBI 30 ECO BOILER
Hi and welcome to FixYa. I am Kelly. I think this is your manual but if not let me know and I will do my best to find it for you:
http://www.burgeandgunson.co.uk/heating/Main_images/5119467_-_Main_Combi_Eco_Users_issue_01.pdf
Natural Gas
Main Combi 25 Eco
G.C.No 47 467 01
Main Combi 30 Eco
G.C.No 47 467 03
Thanks for choosing FixYa,
Kelly
Oct 21, 2010 | Heating & Cooling
On the ideal c95ff the boiler the red neon lockout
overheat stat , does it come back on with reset ?best of luck
Jul 23, 2009 | Water Heaters
Combi boiler problem
most have an overrun built in for a few minutes. if much longer have you got a room thermostat anywhere to turn down
If it never turns off check the switch which controls ON/TIMED/OFF and turn to timed or off. if it still continues on timed then it's the timer
Jan 22, 2009 | Whirlpool Aquatic Millennium VII -...
Hardware & Accessories Logo
299 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
