Question about Remington Garden
Gas comimg from exhaust - Remington Garden
  • 30 Answers
Needle valve stuck, carb needs cleaned and new kit.
Posted on Feb 10, 2014
What modified exhaust system is best
exhaust systems are more complex than just sticking on any old thing
exhaust systems that are "mandrel bent) have a smoother flow of exhaust gas
systems that have a balance pipe between banks is a must but the balance pipe has to be of a particular size
to understand an exhaust system you have to have some understanding of how it works
yes--- it takes the exhaust gas out the back and sounds real good when it is loud and if that is all you want then any system will do the job
the fact is , exhaust systems when operating correctly are designed to move the gas at such a speed so as to have the low pressure shock wave return to the exhaust valve at the moment when it is opening and so the compression gas exits into a low pressure are
this low pressure shock wave is created when the high pressure of the expanding gas in the exhaust reaches the end of the pipe and explodes into the air.This creates a low pressure in the pipe behind it which then travels back up the system to get to the exhaust valve at the precise moment it opens
Now if the system is too long, too big or has too many bends or wrinkles in the bends, that movement of the low pressure is lost to the exhaust valve and so the gas escapes into a pressure area
in effect exhaust gas flows as a pulse as each exhaust valve is opened in succession
this pulse is what is heard as a loud noise from a bad system
it indicates a system that is not getting fully performance from the engine
another point --- exhaust gas noise echoes in a pipe as like ripples from a stone dropped in water
to have an efficient exhaust system that is quite , that principle has to be acknowledged and the system muffler silences that echo without affecting the gas flow
that is why a muffler works as it shuts down the echo out the pipe but it also blocks the gas flow
items fitted such as "hot dog " type mufflers absorb and the way such a muffler is fitted depends on the amount of echo captured the echo with out affecting the gas flow
so now having some understanding of the purpose of an exhaust system , you should be able to select a performance enhancing system with out the noise problem that will attract the law enforcement agencies
the cost is no guarantee of performance but design suited to the car is
Sep 08, 2015 | Cars & Trucks
I have a 6.5 kw kohler marine generator in a 95 sea ray. the motor start find,but when I release the start button it dies.It pumps lots if
Start circuit bypasses the resister which reduces voltage when running so as to increase amps for better fuel burn. Engine starts on 12 volts for hotter starting spark, but when start mode is released, voltage to coil comes from a circuit which has resistor in it somewhere, often inside a wire so you don't even know it is there. A break in that circuit will act as yours does.
Dec 19, 2014 | Cars & Trucks
2007 chevy cobalt ls 2.2 liter ac clutch not comimg on
i think the system is low on gas, check it
Mar 30, 2013 | Heating & Cooling
Transmission fuild comimg from radiator
Check your transmission cooler lines.
Feb 23, 2013 | 1999 Dodge Durango
How do I adjust the oiler
As standard the 345 did not have an adjustable pump, there was an option of an adjustable pump, if it has the on, then the adjuster is a three position screw comimg up from under the crankcase below the sprocket, you will see a + and - on the edge of the tank at this point.
Nov 14, 2012 | Husqvarna Forest & Garden No.967012396 345...
I have a mitsubishi air conditioning unit model MUH-12v. The fan on the machine outside has stopped and of course inside the air is not cold. Could this be a problem with replacing the gas or could it be a...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Aug 30, 2010 | Heating & Cooling
My N73 phone hangs. Only Nokia symbol is comimg when switched on. What can I do?
use this. press simeltaniously (star key + 3 + call(green)key ) and power on
Jun 04, 2010 | Nokia N73 Cellular Phone
Oil leak comimg out of exhaust on a briggs strattom lawn mower mountfield
oil ends up in the muffler if you over fill the oil...re-check the level and adjust as necessary...after that, run it...you need to "burn" the oil residue out of the muffler..
May 31, 2010 | Garden
Please help , cant pass inspection
replace the O2 sensor in bank 1 sensor 1, this is the sensor before the catalytic converter, bank one is the exhaust pipe comimg from the cylinder head that has cylinder # 1 in it.
Feb 02, 2009 | 2000 Ford Expedition
Garden Logo
18 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
