Hotpoint wf620 the water is not going out when spin is finished
  • 209 Answers
SOURCE: hotpoint aquarious wf620
funny my machine does the same, i have had 2 answers one says to hold both the on off button and start button till it comes out of test mode? well something like that, (didn't work) and another tells me its just the board thats faulty, I do believe myself this can be reset by the right test equipment from Hotpoint (Hotpoint not helpful and i have a Hotpoint engineer as a neighbour), its also most embarrassing as i am a recently retired appliance engineer myself of 20 years, i have also been told its a conspiracy to get an engineer to call out to reset it and charge for doing so (being a computer control machine (not sure myself, these things don't happen - do they) Ps if you get told a cure and it works tell me please
Posted on Sep 19, 2007
barkencoa
  • 3463 Answers
SOURCE: hotpoint washing machine model aquarius+1200 spin wf620
F03 indicates an open or short circuit thermistor, this is associated with heater element, so probably the water is not getting hot.
You need to check the heater and thermistor unit. access is from the rear.
Hope this helps.
Plz leave feedback
Ta.
Posted on Dec 09, 2008
SOURCE: Hotpoint WF620 - flashing error F05
This is a drain problem. Most likely something caught in the pump which is accessed by removing the small panel at the rear/bottom of the machine. The pump slots in place and can be removed by lifting and shifting to the left. Unscrew the pump off or remove the pipes will reveal all.
Posted on Dec 13, 2008
rockfixya
  • 679 Answers
SOURCE: hotpoint wf620 aquarius very noisy and not letin any water in
A washer usually shakes or vibrates when it isn’t sitting firmly and level on the floor or because it has an out-of-balance wash load. First eliminate the possibility of the latter—adjust the load if it has scrunched up on one side of the tub. Then check the machine for solid, level support. For the machine to work properly, the floow must be flat, level, and strong enought to support the heavy, water-filled washer without deflecting under the load.
1) Unplug the washer.
2) Look under the washer, and make sure all feet are resting firmly on the floor.
3) Make sure the front legs have locking nuts to keep them tight and that the legs have rubber caps. If they don’t, buy these parts and install them.
4) Make the front feet as short as possible by screwing them up into the machine. Place a level on top of the washing machine and adjust the front feet slightly if needed to level the washer; do not fully extend them.
5) If necessary, tilt the washing machine forward. This will let the back feet self adjust. Recheck for level, and adjust the front feet again.
6) Plug in the machine, and run it empty through the spin cycle to see if it still vibrates.
7) If it does, call a repairperson or the manufacturer to ask about solutions.
Thanks for your question
Posted on Jan 03, 2009
barkencoa
  • 3463 Answers
SOURCE: Machine full of water and towels. Spinning at same rate then stop
Check pump filter located at rear of washer, remove rear cover, locate and remove large black hose, remove and clean filter.
Please rate my solution.
Thanks.
Posted on Jul 15, 2009
Door stay locked after finished washing hotpoint w/machine ref 9526
See if you notice any water still inside the washing machine, if so run another spin cycle to try and remove it as it will not open if there is still water inside.
If you don't see any water inside, try unplugging it and letting it cool off, the lock should release after this
Jul 03, 2016 | Hotpoint Washing Machines
My hotpoint washing machine WF620, squeeks when it is washing and spinning
On most hotpoint wash machines you cant replace or grease the bearing you have to replace the whole drum which cost around 100 pounds from hotpoint and a couple of hours labour its a common problem on hotpoint machines.
hope this helps.
puggy
Jan 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Where is the filter on a wf620?
Hello! Please ignore previous message; The unit is a Hotpoint...It has a Filters in the water lines and in no other location...See photo below...Guru...saailer
  • Outer diameter: 24mm
  • Inner diameter: 14mm cost $2
Jan 08, 2012 | Cars & Trucks
Hotpoint aquarius wf620 washing machine,machine very noisy when in high spin working ok when golng through program
While spinning every washing machine is very noisy as it rotates in very high speed.This is normal and no need to worry.
Thank You
Sep 08, 2010 | Hotpoint Washing Machines
Hotpoint washing machine model WF620, keeps reading TEST when you select the programme.
depending on which version you have to
Press the 'Start / Cancel' button until ALL the console LEDs illuminate.
then either
1.Press both 'Start / Cancel' and 'On / Off' buttons together until 'd OFF' appears.
or
2. Press 'On / Off' and 'Start / Cancel' together with the top left option button (Spin) until 'd oFF' appears.
Mar 14, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf620 aquarius very noisy and not letin any water in
Dec 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Dec 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint washing machine model aquarius+1200 spin wf620
Hope this helps.
Plz leave feedback
Ta.
Dec 09, 2008 | Washing Machines
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
