How to set a hortsmann T50 wireless room stat
Cant seem to set the wireless thermostat for general everyday use. i can override temporally but not permanent setting for the whole week.
4 Suggested Answers
TX_AC_Man
  • 107 Answers
SOURCE: my thermostats seems to be
Either your thermostat is stuck or the sensor detecting the room air is broken. If their is a digital readout telling you the room is down to 63 then I would say the thermostat is stuck but cannot be confirmed without checking with a meter
Posted on Aug 18, 2010
SOURCE: I have installed my Honeywell
Hello Vinny Fear not the thermostat has a built in (factory) deadband of 1 or 2 degrees on purpose to keep the unit from shortcycling.It needs to maintain a minimun run time for the equipment's sake.This is normal and can't be adjusted.
Posted on Sep 17, 2010
hvac1960
  • 2133 Answers
SOURCE: DT92E room stat appears to
All thermostat is calibrated @ difference of 2 degree.to cut in and cut off.
In heat mode, if you keep 25 and your room temp 23. it will start at the end of 24 or beginning of 25 degree.Cut off also @27 degree beginning. Please check Tips & how to do's in Fixya
Posted on Jan 11, 2011
How to adjust thermostat
How to Adjust Honeywell T6360b1028 Thermostat? ' DIYnot Forums
www.diynot.com > Forums > How to... > Plumbing and Central Heating
Unless the thermostat is faulty, the point where your 'stat clicks is your actual roomtemperature. If your 'stat doesn't 'call for heat' when set to 18 and your room ...
Nov 01, 2015 | Honeywell T6360b1028 Room Thermostat
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
I had my 3 year old mid-efficient furnace serviced a few months ago. I have a 4 room small bungalow. The Honeywell thermostat is set to say 72 and it says it reached 72. However, an independant...
Sounds like the switch that controls the blower is faulty. It should heat up then come on at preset temp. As for the stat where is it located. It should be located 60" off the ground not in any direct sunlight and make sure it is insulated behind the stat. You could have more heat loss in those rooms too. IE poorly insulated windows air penetrating through outlets do those walls face the wind? Is the stat located next to a heat supply?
Dec 16, 2010 | Honeywell Programmable Thermostat Heater
I have an inncom thermostat in my room, and it keeps doing a thing where it will turn on, but only the fan, for about 3-15 minutes, then it will shut off. And I can only get the thing to turn on when it is...
if you set the t stat in VIP mode you can operate the fan manually but you shouldnt have to do this. it sounds like the t stat is losing communicatio with the HVAC reciever board.
Jul 08, 2010 | Innocom Technology WIRELES ADAP|INNOCOM...
I have a Honeywell T8400C 1024 thermostat. the last two nights, our heat continues to run without shutting off at the pre-set temperature. We have woken up to 81 degrees in our house. What is the...
Hello
Try taking the batteries out for 5 min,or disconnect power for 5min.
To clear it out.
Then re input all your times days and temps,
Is t stat in a cold location near a door or window?this could also override your settings,most progrmamble stats will go into override at 58.f im guessing this is not your problem.
If it continues after you reset,i would consider a new thermostat.
Hope this helps.
Jan 28, 2010 | Heating & Cooling
I have a fedders ac unit that has temp settings. I was wondering if there is some way to override the 66 degree setting to make it run cooler to make the room colder. (like the older styles...down to 50...
you can get a manual analog dial thermostat, atan appliance store and substitute it for the current stat, some boards also have installer settings that you can reset the limits, (I would try that first) there also are some that have dip switches that can be set to override, the issue with the last two would be finding an installers set-up manual, as I said I would search for that before I tried any non factory components
Jul 15, 2009 | Fedders Appliance Air Conditioner Wall
I'm having a problem in trying to set the time of day on my room thermostat.
If you can find the manufacturer name/ model (sometimes rpinted on the boeard of the stat) generally you can use a search engine and find the user manual
Jul 12, 2009 | Heating & Cooling
Cm921 does not seem to switch back on quick enough
sounds like you might have to move dipswitch to control cycles per hour found on back of t stat set for system type
Feb 02, 2009 | Honeywell Programmable Thermostat Heater
With new digital thermostat furnace runs every 10 min.
which type of T-Stat is it ? most standard t-stats have it built in that the temperature range is only a half a degree, it may seem like its running alot more, but in actuality it is maintaining better home comfort as it is not running as long as the old bimetal t-stats which would have a range of anywhere from 2-5 degrees which would cause the furnace to run alot longer, use more energy, use more fuel, and you would notice a definate change in the house temperture before it would come on or shut off, your t-stat seems to be working properly, and it will save you money, remeber also to change those filters !!!
Jan 20, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
