Question about MSI Ms-7222 Ver 2.0 Pm8pm-v Motherboard Intel P4 3.06ghz Cpu, Fan And I/o Plat
Computer doesn't turn on, only beeping
Hello, I have problem with my computer. I tried to add memory (RAM) but after that my computer didn't turn on anymore. It only keeps making long beeps and the screen is totally black. How to fix this problem? Thanks for the answer.
    Problem Solver:
  • 10 Answers
Hi Agne Suursaar,
Thank you for contacting fixya.
Do a clear cmos and then try reducing the number of ram sticks that you use to just one, and keep alternating ram sticks in different dimm slots. You may have one or more dead ram sticks/dimms.
Posted on Feb 09, 2014
No video on asrock p4i45G motherboards
Hello the homepage is here:
http://www.asrock.com/mb/Intel/P4i65G/?cat=Manual
3 short beeps: base 64 k ram failure.
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Read more here:
http://www.computerhope.com/issues/ch000996.htm
Beep codes:
http://www.computerhope.com/beep.htm
The fault could also be: power supply, or bad capacitors on the mainboard.
Good luck
Nov 26, 2012 | Asrock P4i65G Motherboard
How to fix a laptop that doesn't turn on but beeps 1 long beep and 3short beeps
This POST cade is related to RAM problem
one beep, three short beeps
three short beeps, one beep
  • Memory problem: bad DIMM or bad DIMM slot
Try reseating the RAM, if this does not work then remove the RAM module and take it to your friendly computer repair shop and get them to test the RAM for you.
May 12, 2012 | HP Pavilion ze2000 Notebook
No display when the computer is tuned on
try to release the memory (ram) from *********** board, turn on your pc without any ram, and you should hear a sound beep (voice) if there is any sound the problem is on your ram (memory), clean your ram using a pencil eraser or replace with a new one, if there is still no display maybe the problem is with your vga (display adapter), but if you didn't hear any sounds when your memory (ram) was release the problems is in *********** board or your processor..
hope this post can give you any solutions.. thank you
May 14, 2011 | Intel Motherboard
My dell optiplex doesn't boot... but i can hear the sound (not beeping) and the spinning hard disk. Nothing is in the screen. I tried removing and exchanging RAM but didn't work.
The possible causes that can cause a PC not to boot are:
  1. Defective RAM
  2. Defective Video Card
  3. Defective HDD
  4. BIOS battery
For the RAM and for the video card, check if they are well clipped on the motherboard. Try removing and replacing them.
As for the HDD, check the SATA/IDE cables.
If all the steps above seems to be ok, try changing the BIOS battery found on your motherboard.(Note this will reset your BIOS settings).
Hope this helps you !!
May 10, 2011 | Dell OptiPlex 360 Desktop Computer
Turn on computer, hear beep beep beep. then monitor does not come on, says no signal. looking at black screen only
3 beeps is usually a memory error. In fact, it means there is a failure within the first 64KB of system memory. You can usually find out if one of your ram sticks is bad by taking a stick out and turning the PC back on. If it boots, you found the bad ram. If not, replace and try again.
Once you can ever get it to boot, you can go to memtest (http://www.memtest.org/) and download the auto installer for USB key and boot from USB (usually by pressing f12 or del, depending on your bios...it will say on boot up). This will tell you if you have any further ram issues.
If this doesn't resolve your issue, the other option 3 beeps can mean is a bad motherboard or other system device (worse case scenario, and fairly rare).
Hope this helps...
Jan 03, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
On power up it beeps 3 to 4 times and won't boot up
If there is no display coming on your screen check your computer RAM here is the beep codes for your dell computer i hope this will work for you
Regards
manish
Mar 24, 2010 | Dell Inspiron 530 Desktop Computer...
Pc beeps 4times y?
4 short beeps
Your problem could
be a bad timer. The system timer failed to work properly. It will
require motherboard replacement.
1 long and 3 short beeps
Memory test failure. An error has been detected
in the memory over the first 64K. Try replacing the memory, and if
that doesn’t do it, the motherboard.
Beep codes are the beeps you hear from the
PC speaker when you turn on your computer. They are your computer’s way of letting you know what’s going on when there is no video signal. These codes are programmed into the BIOS of the PC.
Nov 10, 2009 | Dell Vostro 200 Desktop Computer
Did not boot and with 3 beep sound
Remove added memory
  • Additional information about determining the type of memory to use in a memory upgrade can be found on document CH000910.
Open computer and reseat memory
Swap memory location
Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer.
If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Replace memory
If you've determined or believe that the memory in y our computer is bad we suggest that you replace it.
Aug 04, 2009 | Computers & Internet
Cant Start Up
Hi
start with removing the added ram try starting up, if it doesn\t start up does it beep?
if noting happens remove all the ram, the computer should definitely beep now.
Add only the original memory and try starting up you should get picture.
This seems to be a old problem and if you don\t need assistance in solving it. It would be great if you would share to the world how you fixed your problem so other users can benefit from your experience.
Thank you, Ekse
Sep 28, 2008 | Corsair Memory Value Select 1GB PC2700 DDR...
MSI Ms-7222 Ver 2.0 Pm8pm-v Motherboard Intel P4 3.06ghz Cpu, Fan And I/o Plat Logo
93 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
