Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Appear code F023 when I Have started c351 bizhub
  • Konica Minolta Master
  • 6,696 Answers
Your firmware (Operating Software for the copier is bad) Will require a tech, as the firmware for the copier is located on a secure web site only access able via Konica Minolta Dealership and KMBS, they like to protect there firmware
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 22, 2016
SOURCE: bizhub c250 error code
There are 4 things to try to reset any error codes on these machines
1.) open and close front door
if that fails go to number 2
2.) open front door and turn off main power switch and then turn back on and close front door.
if that fails go to number 3
3.) turn machine off and then turn back on while holding down the utility/counter button after a while a trouble reset box will appear on the screen press on the box and then restart the machine.
If this fails go to number 4
4.) failing all this call your local service agent.
Posted on Mar 10, 2008
herminio_hal
  • 210 Answers
SOURCE: how to set scan for a new person on bizhub c351
If you know the ip address of the copier printer, it will be easier for you to add e-mail address. open the internet browser and type in the ip address. admin password 12345678. or use public. Click the scan tab.
Posted on Jul 09, 2009
  • 51 Answers
SOURCE: Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
Posted on Aug 30, 2009
  • 51 Answers
SOURCE: I have a Konica Minolta Bizhub c351 and all of a
u ned to change image unit
  • 44 Answers
SOURCE: how do we change the language on the konica minolta bizhub c351
1) Press "Utility-User Setting-Language Selection
2) Go to service mode System 1 - Marketing Area - US
You have to do both
Posted on Nov 29, 2009
What is a Error code # C F023
On a Bizhub C450 the C-F023 code could be following.
-RAMs on PWB-ES Board.
-Old FW Version.
-Connection problem.
-PWB MC
-PWB MFP.
I would suggest you have a tech make a memory check in "state confirmation" in service mode , clean and reseat all memory chips and upgrade the machine to the newest Firmware.
Aug 23, 2014 | Konica Minolta bizhub C450P Laser Printer
Bizhub C450 has error code C-F023
CF023
MsgQue OverFlow
An exceptional instance occurred due to the unexpected Parameter in the System F/W.
Relevant Electrical Components, Units, and Options - MFP Control Board (PWB-MFP)
Try to reset it. If it is still showing up, you should try a new firmware version. If it is not working with a new firmware, you should check all the connection to the MFP Control Board. In the worst case scenario, you should change the board. I hope a reset will do the job
My konica minolta bizhub 361 has an error code c-2801.... what does that mean?
In my experience you have to change the developer and the machine will be ok.Also there is a chance that you have to clean the two toner sensor that are located in the end of the toner bottle,sometimes there is the problem.please let me know.
Aug 16, 2011 | Konica Minolta bizhub C351 All-In-One...
Minolta Bizhub C351 Error code C-2152
• The 1st Image Transfer Retraction Position Sensor
is not activated (retracted position) within 5
sec. after the 1st Image Transfer Pressure/
Retraction Motor has started turning during a
sequence of the Transfer Belt's retracting motion.
is not deactivated (pressed position) within 1
sequence of the Transfer Belt's pressing motion.
you need the retract motor or the sencor that sees it
Jun 27, 2011 | Konica Minolta bizhub C351 All-In-One...
I have a konica minolta bizhub c351 How do I
select "PDF"- MMH option, not the "MMR" option from one touch menu.......
May 15, 2010 | Konica Minolta bizhub C351 All-In-One...
check in one touch setting, PDF-MMH and MMr, multiple files and single file option, if having problem then call your tech service rep
Mar 29, 2010 | Konica Minolta bizhub C351 All-In-One...
adjustment.
Change PWB-C.
Aug 03, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica bizhub C351 copier with a C9401 error code
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and
make sure that the machine properly starts.
Aug 02, 2009 | Konica Minolta bizhub C351 All-In-One...
Desktop faxing from Konica c351
Go to this link to get the fax drivers you need.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=827&filetypeid=0&osid=3
You should have had a cd that came with the machine that has them as well. Once they are installed, go into Microsoft Word and select the fax to print from. A screen should appear asking you for the phone number of the name out of the address book.
Sep 26, 2008 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
71 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
