Question about Sony Grand WEGA KF50SX100 50" TV
Kf-50sx flashes 34 - Sony Grand WEGA KF50SX100 50" TV
Sony su 50sx red light flashing 7 times
This may be your lamp fan not spinning. Sometimes you can get it to operate temporarily by cleaning the dust from it & spin the blade by hand to get it started
May 07, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kf-50xbr800 turns off for about 30 seconds, standby lights blinks 34 times before coming back on. stays on for 2 minutes then repeats cycle...
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Aug 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
Sony grand lcd kf-42sx300u the on and off switch flashes and the tv wont turn on
one or two things....broken or ur a flashes wire need to be turned.....
Aug 27, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony KF-60WE610, green light flashes few times and return to red, what could be the problem TV only five years old
Your lamp (back lighting) is burnt out and need replacement. The instructions are in your manual
Nov 08, 2009 | Sony XL-2100U Projector Lamp for...
Sony KF-50WE620
DEPENDS ON THE # OF FLASHES IF ITS 3 THEN YOUR LAMP HAS BLOWN IF ITS 6 THEN YOUR THERMAL FUSE IS BLOWN THIS IS 2 OF THE MOST COMMENT PROBLEMS
Jul 31, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony Grand WEGA KF50SX100 50" TV Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
