Question about Garden
Needuser manual for kew hobby 100-1pressure washer
Require user instructions/manual for kew hobby 100-1 pressure washer
  • 389 Answers
SOURCE: Found this presure washer in the basement and want
This may be as simple as still having air in the system.  Connect the machine to the water supply (but not the electric) then squeeze the trigger and allow water to flow for at least 60 seconds.  During that process, hold the nozzle outlet under the surface of water in a bucket so you can see when air stops coming out.  Keep going until you're sure there's no more air in the system.  Then switch it on.  If it still does not come up to pressure you'd probably be wise to abandon it.
Posted on Apr 18, 2009
  • 92 Answers
SOURCE: I have an old kew pressure washer and when I pull
Dear dennis_partr,
In general all pressure washers have a control valve. This is sometimes refered to as the Spill Valve. When the trigger is pulled, the spill valve is in normal position. When the trigger is released, the spill valve compresses to let water circulate from its bottom part. If when the trigger is pulled and the bottom part of the spill valve does not close, then water keeps on circulating and hence no pressure. In this case change the spill valve with a new one. Also there could be a fault in the sucktion valves. If the sucktion vaves do not close, also water keeps on circulating. One also can examine the delivery valves. If these are not closing, then water is being sucked while delivering. Hence no pressure. Another cause but very rare, is that the swash plate that is pushing the pistons got loose. The electric motor will be turning, but the pistons stay in the same position.
I mentioned many causes, but usualy it is the spill valve. If with a new spill valve, there is still no pressure....then you must tackle the sucktion and then the delivery valves.
I wish to add that I assume that you have the correct lance and correct nozzel size. A worn out nozzel, will result in low prssure too.
Regards,
Fulltech.
Posted on Apr 22, 2009
  • 389 Answers
SOURCE: Alto Kew pressure washer stopped working!
Hi Steve, In 3 years of repairing pressure washers I've only ever seen one of these, and am having a hard time remembering much about it, except that it was really awkward to work on! Strictly speaking, many small pressure washer repairs are uneconomical, because the labour time involved costs almost as much as the machine is worth. However, a "motor won't go" problem does narrow things down a lot. To state the obvious, we're looking at an electrical problem. The challenge is to find the cause! Did the motor stop while you were using it, or did it fail to start when you got it out of storage? If you are in the UK you should first check the plug-top fuse and the full length of the flex for any damage. If you have any kind of low-voltage electrical testing device, you can test for continuity between the live and neutral pins of the plug (with the machine switched on you should have continuity). If you have no continuity (and the fuse is OK) there may be a problem with the switch on the machine. Unfortunately, unless you are a really keen DIY person, there's not much you can do by way of self-help. A repair centre may be able to help you, but beware of costs spiraling beyond the cost of a replacement machine. I hope this will be helpful - if you can give more details I'll help further if I can. Good luck!
Posted on Aug 16, 2009
SOURCE: kew hobby 80-1 instructions
I have a kew hobby 70 with little use. The nozzle wont spray, it just sends a weak jet of water. how can i fix it? I have hardly used it. It has been
in a shed for years . thanks
Posted on Dec 19, 2009
  • 569 Answers
SOURCE: I have a Kew Hobby 80. The output from the lance
Could be the input water pressure is not sufficient. There is a pressure valve inside the machine that will cut off the motor if input pressure is too low or non existent.
Try a different source for the water input.
Posted on Feb 22, 2010
Testimonial: "I haven't had a chance to try the suggestion but it makes sense. Thank you."
Kew 1640H with display flashing A 2 fault code
Hi really hope someone can help as I couldn't find a manual for my kew alto 1640hot and cold diesel pressure washer, problem is when I turn it on from been stood over night !i press on button and I see a f then a 1 flashing on the display ,anyone know what it means or we're the fault is,
Sep 18, 2011 | Garden
Kew hobby pressure washer. powers up ok but no pressure behind water jet..??
frozen output valves were the hoses attach to. two or them are present. one is inside the other
Apr 12, 2011 | Garden
Type- KEW Hobby waterblaster- requires addition pump oil. What kind of oil does it take.
Pump oil is 20 or 30 weight non-detergent motor oil. SAE20 or SAE30.
Pump oil fills about half-way up inside pump. Look for fill mark or read manual.
Of course you saved the manual, right? So you're not in line at fixya wanting a manual for some product made 5 years ago in China by a company that doesn't post manuals. Or manual is available in Italian and German with pages missing.
If this is gasoline-powered engine, do not turn machine upside down to drain oil or 10-W30 engine oil will drain into carburetor.
Nov 27, 2010 | Garden
Kew Alto Force X-TRA cold water supply pressure sensor problem
Have the same p-washer (5-6 years old) and the same problem. Opened it and the pressure switch is the crook. A plastic pin has an inner and an outer spring on it (two consentric springs). The smaller inner spring is completely rusted away so the switch no longer operates correctly. Obviously the spring was of a too low quality. The service office say a new switch cost around 400NOK (50 euros) - so the washer is too expensive to mend. But I will try to get it working without the inner spring. Doubt if I succed. So will have to dump the washer.
Mar 19, 2010 | Garden
I have a Kew Hobby 80. The output from the lance is not constant but pulsates.
Feb 22, 2010 | Karcher PSI Electric Pressure Washer
Kew hobby 80-1 instructions
Sep 29, 2009 | Garden
Lost manual for K. E. W. HOBBY 88 pressure washer
Hi, Do you use the unit now. My unit of th same vintage has just failed and I would be interested in purchasing the same model slong as it works. Cliff Cason, Derbyshire DE6. Tel 01889 565574 mob 07711218929.
Sep 25, 2009 | Garden
Found this presure washer in the basement and want to know if it works the motor runs when you plug it in but does not build press. The brand is kew hobby
Apr 16, 2009 | Garden
Garden Logo
94 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
