Question about Kenwood Toys
MDV 727 dt
Reverse camera
Got a junk yard 727 transmission for my 92 dodge b250 put it in vehicle will not move forward or reverse. Not sure whats up?
junk yard is probably what is wrong
however it indicates that the torque converter clutch servo/ solenoid is not operational --not connected at the wires for the transmission
Jun 28, 2017 | Dodge Cars & Trucks
Mdv-727 dt
Mdv727 dt How to change language
Jul 31, 2014 | Kenwood Car Audio & Video
Memory Navy MDV-323
How can change the time.
Nov 17, 2013 | Kenwood Memory Navy MDV-323
Video noise on jvc gy-dv500u
I have the same camera with the same problem.
Mar 09, 2012 | JVC -GY-DV500 w/lens, VF, Fuji 14x1:...
How may gears are there in the 727 transmission case
A 727 has 3 forward gears and one reverse. Is that what you are wanting to know?
Apr 22, 2010 | 1984 Dodge Ram 50
My car radio Eclipse AVN5435 say (Check map disk )and i lost
my Eclipse AVN5435 is lock is any body know the solution
Apr 11, 2010 | Eclipse AVN5500 Car DVD Player
Put a 727 in place of current piece of junk
you cannot put a 727 trans in place of a a518 trans, will not function due to electronics of gov and o/d, as well as fitting in place, from the looks of your truck is 4x4, repair your a518 trans, les headache in the long run and convent of o/d. have a shift kit put in or modify vavle body for better shifts and cooler flow, power reverse flush your cooler, GOOD LUCK RDJRP
Aug 03, 2009 | 1999 Dodge Ram
Tranny type
You likely have either an aw4 or a chrysler 727 in there (depends on engine) 727 has the reverse/neutral switch above the rear left corner of the pan. AW4 does not (and is smaller) To better identify, there should be an id tag on there somewhere!
Feb 20, 2009 | 2001 Jeep Grand Cherokee
Toys Logo
Top Kenwood Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Kenwood Toy Expert? Answer questions, earn points and help others
