Bonaire split system error E0
Error code E0 flashing constantly. Fan is working OK but no cool air.
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
  • 30 Answers
SOURCE: control panel lights constantly flashing
You should have a dedicated line that feeds the equipment power look at your main electrical panel or search around your equipment for a pull out disconnect switch or sometimes they will wire it to a light switch. by shutting down the main power and turning it back on it should reset anything.
Posted on Jan 05, 2009
relaga58
  • 158 Answers
SOURCE: Goodman wmc24-1a split system - fan stops on dry mode
that's normal
Posted on Aug 11, 2009
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
hvac1960
  • 2133 Answers
SOURCE: fijitsu wall mounted split system
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Posted on Dec 11, 2010
Wat is H3 error in bluestar split Ac?
Hello Yogesh...
Unless you are familiar with the BASICS of REFRIGERATION...
"H3" ERROR CODE means it is "Out of ORDER"...
Broken: Needs repair.
By searching the internet "split A/C " It defines a
COMPRESSOR overload protection is trying to
SAVE your equipment FROM SELF DESTRUCTION.
See second detail sheet (below)
"COMPRESSER"
Is the heart of MOST modern refrigeration systems.
In a SPLIT system it is the outside unit with the FAN
that should be running when the COMPRESSER is
in action. Typically then compressed & COOLED
REFRIGERANT is then piped into a cooling element
EXACTLY LIKE MOST REFRIGERATORS where the
cooling takes place (expansion valve and evaporator).
Treated AIR (indoor) is then blown through the
evaporator... cooling the room and warming the
refrigerant (which continues to cycle back to the
outside unit where the compressing cycle
continues until the INSIDE temperature is
achieved... (thermostat on the wall)
"COMBINED"
pretty much means EVERYTHING but those combined refrigeration units seen WORLD-WIDE HANGING OUT OF WINDOWS... or on roof-tops with DUCTING for
"treated AIR" to be pumped where needed.
Similarly heat pumps simply have reversible valves...
which turn the coils around (functionally).
There too are split-system (inside/outside) & combined units.
Excellent refrigeration primer (below)
https://camec.com/cameccatalogue/documents/000948_IbisTechManual1.pdf
Alarm Codes
Gree Air Conditioners Error Codes
Hope this helps.
Carnac the Magnificent
May 13, 2017 | Heating & Cooling
Super general air conditioner error code is E0
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need anything else air conditioning related don't be afraid to check us out our AC Repair and information online
Sep 14, 2016 | Heating & Cooling
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Mar 10, 2010 | Carrier Heating & Cooling
Heating & Cooling Logo
173 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
