Question about Zoom Wireless-G 4410 (44100000) 802.11g/b
Try to start menu flashes up for only 1 second
Double click icon comes on for split second then goes off
    Master:
  • 409 Answers
Uninstall all Zoom software; restart PC; install software & drivers again.
check MFR's website for more current drivers.
Posted on Apr 14, 2014
Pen drive is slow
Slow Transfer on a USB Flash Drive b> Using a USB flash drive is a convenient way of transferring data and files from one device to another. However, sometimes you may find that your USB drive is slow to transfer files onto your laptop or PC. This lag may also cause your desktop or laptop to slow down while you use other programs. You do not need to replace your flash drive and buy a new one. You can fix a slow file transfer problem in just a few steps.
b>Plug your USB flash drive into your computer. Click the "Start" button and select "My Computer." Right-click the USB icon from the My Computer window and click "Properties" from the menu that comes up. Go to the "Hardware" tab and select your flash drive once you find it in the list of items. Then click the "Properties" option in this menu. Choose "Policies" tab within the Properties menu. Turn on the performance optimization option and click "OK." Click "OK" again to exit out of the Properties dialog box. Go back to the My Computer window and right-click on the USB icon. Select the "Format" option from the list of choices. Select the "NTFS" file system and choose "Quick Format." Press "OK" to confirm the choices and to initiate the formatting. Wait for the drive to finish formatting before ejecting it and removing it from the computer.
USB Flash That Is Slow and Damaged
b> USB flash drives are used to transport data between computer systems. Because it is essentially just a small hard drive, the USB device can become damaged and slow down in performance due to viruses or damaged files. To correct these problems and fix the USB flash drive, you must reformat the drive. This removes all data from the drive, returning it to its factory settings.
Plug the USB flash drive into a USB port on the computer system. Close any AutoPlay window that may load onto the screen. Click "Start" then "(My) Computer." Right-click the removable device icon that appears on the screen. Select "Format" from the pull-down menu. This loads a format options screen. Click "Yes" and the computer formats the USB flash drive, removing the damaged content and returning it to the factory settings.
ReadyBoost With a Slow Flash Drive
b>The ReadyBoost feature in Windows has the ability to increase the speed of low-RAM computers by caching program data on a flash memory device. However, the device must meet minimum performance characteristics in order for Windows to enable ReadyBoost, because ReadyBoost may not meet expectations when used on a slower device. If you still want to use ReadyBoost with your flash drive or memory card, you can make a change in the system registry to force Windows to use the device.
Insert the flash device that you would like to use for ReadyBoost. Open the Start menu, and click "Computer" to see the icon for the device. Right-click the icon for the flash device, and then click "Properties." Click the "ReadyBoost" tab at the top of the window. Clear the check from the "Stop retesting this device when I plug it in" box, and then click "OK." Remove the flash device. Open the Start menu again. Type "regedit" in the "Search programs and files" box at the bottom, and then press "Enter" to run the Registry Editor. Double-click the folders "HKEY_LOCAL_MACHINE," "SOFTWARE," "Microsoft," "Windows NT," "CurrentVersion." and "EMDMgmt." Locate and click the folder for your flash memory device under "EMDMgmt." In most cases, you can determine the correct folder because it contains the name of the device's manufacturer. Double-click the registry entry "DeviceStatus" on the right side of the window. Change the number under "Value Data" to "2" and click "OK." Double-click "ReadSpeedKBs" on the right side of the window. Change the value to "10000000" and click "OK." Repeat this process with the "WriteSpeedKBs" registry entry and close the Registry Editor. Reinsert the flash memory device, and return to the "Computer" window. Right-click the icon for the flash memory device, and then click "Properties." Click the "ReadyBoost" tab. Windows now displays an option to enable ReadyBoost on the device. You might install a usb 3 card the speeds are much faster cheap and easy to install. Hope this helps.
Jan 08, 2013 | Electronics - Others
How to change icon size on laprop
Try to go to this link, on how you change icon size.
http://www.techtalkz.com/windows-7/516049-how-change-font-size-icon-size-windows-7-a.html
AnEspera
Apr 18, 2011 | Computers & Internet
Monitor is in asleep mode comes on 3 seconds goes off how do i get it 2 stay on
Does the monitor do this with other machines? If no or unsure, do the following and see if the problem persists
1. click Start 2. Click Control Panel
3. In Classic View, find the Power Options Icon and Double Click. In Category View, click the Performance And Maintenance and then click on Power Options.
4. Under the Power Schemes Tab, click the drop down box next to "Turn off monitor" and change the time.
5. Click Apply/Ok
Dec 08, 2010 | Dell E173FP 17" LCD Monitor
Flash error,need to back up data, and fomat player
1. Double-click My Computer on the Windows Desktop or in the Start Menu.
2. Locate the Removable Disk (X:) or Player (X:) icon that is associated
with the player. (X: equals the drive letter assigned to the ILO player.)
3. Right-click the Removable Disk (X:) or Player (X:) icon.
4. Click Format….
Reformatting your ILO player will result in the deletion of all tracks and
settings on the ILO player.
5. If you are sure you want to reformat your player, click Start.
Apr 17, 2009 | iLO (2 GB) MP3 Player
Acer 5610 orbicam
it seems to be an inherrent fault with this model, this sometimes works though.
swivel the camera around to face the rear of the notebook (making sure you turn it the right way) and turn it back again, now try to run the camera again, keep clicking the icon to start the cam and eventually it comes on.
Aug 17, 2008 | Acer Aspire 3680 Laptop
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu.
Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: - Check the product cable
Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds.
Reconnect the USB cable to the product and computer.
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
Click Start and click Printers and Faxes. The Printers and Faxes window appears.
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
On the menu bar, click Printer.
Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it.
If the menu includes Use Printer Online , click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: - Stop the print queue
Double-click Macintosh HD.
Double-click the Application/Utilities folder.
Open the Print Setup Utility folder.
Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
When the print queue is empty, click Start Jobs.
Try the print job again.
Step six: - Remove and re-add the product to the printer list
Select the appropriate product.
Click the red X to delete the product from the computer.
Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Reconnect the USB or Ethernet cable to the product.
If the product is not automatically added, click Add.
Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
I cannot print but i can scan
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 09, 2008 | HP DeskJet F380 All-In-One Printer
Cannot see my desktop
Please try these steps to solve your problem:
1) Press Ctrl+Alt+Del to run the Task Manager
2) Click on "File" on the Task Manager upper menu
3) Click on "New Task (Run)" option, Run window should appear
4) Type "explorer" without the quote, on the Run window
5) Your start menu and icon on desktop should now appears
hope it helps :D
Apr 29, 2008 | ASUS A9RP Notebook
Flash Drive problem
Try opening the 'computer' icon - normally shows as an icon on your desktop or in start menu then you will hopefully see the flash drive listed along with C Drive, CD Drive etc. Double click or right click and open - this should let you see and open individual files on the flash.
Feb 12, 2008 | Acer Extensa 710TE Notebook
IJ650 Printer
Make sure you have properly loaded the paper into the printer. If there is an error message on your screen, follow the instructions on it. If still nothing works try the following: > Check the printer cable. Is it securely plugged into the printer and your computer? > Check the printer status: a From the Start menu, click Settings Printers. b From the Printers folder, double-click the icon for your printer. c From the Printer menu, make sure: > Default Printer is selected. > Pause Printing is not selected. > If you have connected your printer to a device such as a scanner or fax machine, disconnect the printer from that device and connect the printer directly to your computer. > Check the printer port: a From the File menu of a software application, click Print or Printer Setup. b In the Where area, make sure your printer port is set to USB. > Make sure you have not installed multiple copies of the printer software: a From the Start menu, click Settings Printers. b In the Printers folder, make sure there is only one icon for your printer. c If you have two printer icons for the same printer, try printing a test page from each icon. Right-click the icon, select Properties, and then click the Print Test Page ? button. If the test page prints from one icon and not the other, delete the icon for the printer that does not print. If there is still a problem, uninstall and then reinstall the printer software: 1 From the Start menu, click: Programs >Compaq IJ650 >Uninstall Compaq IJ650. 2 Follow the instructions on your screen. 3 To reinstall the printer software, go here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=217392&lang=en& Good luck!
Apr 09, 2006 | Compaq Inkjet IJ650 Printer
Zoom Wireless-G 4410 (44100000) 802.11g/b Logo
42 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
