Question about Motorola Mobility Mbp30L Digital Video Baby Monitor With 2.4 Inch Lcd
TURN OFF TEMPERATURE SENSOR - Motorola Mobility Mbp30L Digital Video Baby Monitor With 2.4 Inch Lcd
Engine cooling fans don't come on
COOLING FANS DONT TURN COULD BE FAULTY FAN RELAY.FAULTY PCM AND FAULTY COOLANT TEMPERATURE SENSOR.CODE SCAN FOR FAULTY PCM CODE AND A FAULTY COOLANT TEMPERATURE SENSOR.SEE IF ENGINE COOLANT TEMPERATURE SENSOR IS GIVING CORRECT COOLANT TEMPERATURE USING A CODE SCANNER.IF ENGINE IS 190 DEGREES AND THE ENGINE COOLANT TEMPERATURE SENSOR READING 100 TO 80 DEGREES COOLANT SENSOR IS BAD.HOT WIRE COOLING FAN TO SEE IF FAN MOTOR WORKS.BECAUSE COOLING FAN MOTOR COULD HAVE OPEN CIRCUIT CAUSING ELECTRIC MOTOR NOT TO TURN ON.
May 13, 2011 | 2003 Dodge Stratus
I was cleaning my double oven and the F2 error message and beep came on. I finally turned the oven off at the breaker. Will the oven doors eventually open when the oven cools down and I turn on the...
F2
During
CLEAN Control senses oven
temperature above 915F-930F If actual over temperature condition occurred: Look for
welded relay contacts. If this happens, replace oven control (also called clock
or ERC).
If no over temperature condition occurred: Look for a
high resistance connection or any other cause of high resistance in the oven
temperature sensor circuit. Check sensor, sensor harness and sensor harness
connection at sensor and oven control. Replace sensor if found defective. Check
door lock switches.
Remember: Oven control (ERC) measures
resistance of sensor circuit , not actual oven temperature.
Dec 22, 2010 | GE JTP86 Electric Double Oven
The fan that comes on when the oven reaces a certain temp will not turn off. The entire front panel was replaced about 1 year ago.
Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
OR
Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness
Dec 03, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Oven beeps and displays F2 or F3?
Hello there:
this error code is telling you that the oven temperature sensor is going haywire and needs to e replaced
Here is the 2 error codes and what they mean and what needs to be checked
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor
Oct 04, 2010 | General Electric Stove/Oven/Range Chrome...
The meaning of error code 24?
Hi, F24 error code a water temperature sensor error or enought hot water to the washer.
check to see you have both valves are turned on. Also, the water inlet valve on the washer has a screen and it is known to get clogged and restrict water flow. Turn off the hot water valve. Pull the hot water hose off where it attaches to the back of the washer.
Even if you are getting good hot water flow, inadequate water temperature can cause an F24 error code. Check the temperature setting on your hot water heater. It should be set at 120 F. You should reach this hot water temperature at your washer within about 1 minute.
If you are getting a good hot water flow, you may one of the following failures:
1 loose or dirty connection at the temperature sensor or control board.
2 The temperature sensor could be out of range. Bad or shorted sensor
3 Control board failure.
The temperature sensor should have a resistance reading of 6.6k ohms at 104 degrees F and should drop in Ohms as temperature rises,
The temperature sensor is located at the back lower section of the tub with 2 small black wires. It would require a ohm meter to measure the resistance of the sensor. .
Sep 13, 2010 | Kenmore HE2 Plus Front Load Washer
My radiator fan is not working on my 2006 Dodge Charger
Hi, If you have truble code check/service engine soon light on,then go to your local Autozone part store for a free scan. If not,i'm going to start with haveing you check the cooling fan relay,this can be found in the power distribution box,this can be found in the engine compartment.I would change places with another relay with the same number on it. If this takes care of it,buy a new relay and it was an easy fix. If not here's tests you will have to do as long as you have a digital volt meter.
The Engine Coolant Temperature (ECT) sensor is used to sense engine coolant temperature. The sensor protrudes into an engine water jacket.
The ECT sensor is a two-wire Negative Thermal Coefficient (NTC) sensor. Meaning, as engine coolant temperature increases, resistance (voltage) in the sensor decreases. As temperature decreases, resistance (voltage) in the sensor increases.
The PCM compares the ECT, Intake Air Temperature (IAT), and Ambient Air Temperature (AAT) under cold start conditions. Following a start to run delay time, the sensor values are compared. If the one sensor value is not within a specified range of the other two sensors, the value is determined to be irrational
2.7L, 3.5L & 5.7L Engines
  1. Turn the ignition off.
  2. Disconnect the Engine Coolant Temperature Sensor (ECT) harness connector.
  3. Turn the ignition on.
  4. With a scan tool, read the ECT sensor voltage.
  5. The sensor voltage should be approximately 5.0 volts (plus or minus .1 volt) with the connector disconnected.
  6. Turn the ignition off.
  7. Connect a jumper wire between the (K2) Engine Coolant Temperature Sensor (ECT) signal circuit and the (K900) sensor ground circuit in the ECT harness connector.
  8. Turn the ignition on.
  9. With a scan tool, read the voltage.
  10. The sensor voltage should be approximately 0.0 volts (plus or minus .1 volt) with the jumper wire in place.
  11. If voltage is present as stated suspect faulty ECT sensor.
I hope this helps,Thank You for using fixya, iluv2fish..... Ray.......
Jun 30, 2010 | 2006 Dodge Charger
When turning on oven a f3 keeps showing up
  • The F3 fault code is indicating an open oven temperature sensor probe or an open oven temperature sensor circuit.
  • The oven sensor probe will need to be removed from inside the oven cavity and tested with an ohm meter. The oven sensor should have a resistance of 1100 ohms at room temperature. If the oven temperature sensor probe measures approximately 1100 ohms at room temperature the oven sensor is OK and the sensor circuit connections will need to checked at the oven control board.
Hope this helps .
Feel free to ask me for further help .
Dec 03, 2009 | Whirlpool Kitchen Ranges
My G.E. Profile would turn on then immediatley turn off. It would finally work if you kept turning it on. Then I started getting the F2 code everytime I turned my oven on. A repairman told us the...
Hi. The F-2 code will appear if the control board is sensing an abnormal oven operating temperature above 615F-630F, during bake, or above 915F-930F, during the self cleaning stages.
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
NOTE_
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
Dec 03, 2009 | GE Profile JTP56 Electric Double Oven
04 Tahoe AC blows hot air on drivers side but resets if restarted
A educated guess I would have to say there is a problem with HVAC control module ! electronics you know ! But that's not the way to do things ! There could be codes stored in the module. The Chevy dealer my have a reflash bulletin for this problem . Then can reflash , reprogram the control module ! The first place to start is checking for codes in the HVAC module.
The HVAC control module is a class 2 device that interfaces between the operator and the HVAC system to maintain air temperature and distribution settings. The battery positive voltage circuit provides power that the control module uses for keep alive memory (KAM). If the battery positive voltage circuit loses power, all HVAC DTCs and settings will be erased from KAM. The body control module (BCM), which is the vehicle mode master, provides a device on signal.
Air Temperature Sensors The air temperature sensors are a 2-wire negative temperature co-efficient thermistor. The vehicle uses the following air temperature sensors:
Ambient Air Temperature Sensor
Inside Air Temperature Sensor Assembly
Inside Air Temperature Sensor Assembly-Auxiliary
Upper Left Air Temperature Sensor
Upper Right Air Temperature Sensor
Lower Left Air Temperature Sensor
Lower Right Air Temperature Sensor
Upper Air Temperature Sensor-Auxiliary
Lower Air Temperature Sensor-Auxiliary
A signal and low reference circuit enables the sensor to operate. As the air temperature surrounding the sensor increases, the sensor resistance decreases. The sensor signal voltage decreases as the resistance decreases. The sensor operates within a temperature range between -40?° to +101?°C (-40?° to +215?°F). The sensor signal varies between 0-5 volts.
The input of the duct air temperature sensors are different from the ambient and inside air temperature sensors. The HVAC control module converts the signal to a range between 0-255 counts. As the air temperature increases the count value will decrease.
If the HVAC control module or auxiliary HVAC control module detects a malfunctioning sensor, then the control module software will use a defaulted air temperature value. The default value for the ambient and inside air temperature sensors will be displayed on the scan tool. The default value for the duct air temperature sensors will not be displayed on the scan tool. The scan tool parameter for the duct air temperature sensors are the actual state of the signal circuit. The default action ensures that the HVAC system can adjust the inside air temperature near the desired temperature until the condition is corrected.
The ambient air temperature sensor mounts underhood and can be affected by city traffic, by idling, and by restarting a hot engine. Therefore, the HVAC control module filters the value of the ambient air temperature sensor for temperature display. The ambient air temperature value is updated under the following conditions: Or you can just buy a new control module an hope that it fixes it. $89.00 at www.partsgeek.com
Search from over 10 Million Auto Parts
Sep 18, 2009 | 2005 Chevrolet Silverado
Fault F24 on kenmore front load washer
Apr 20, 2008 | Washing Machines
Motorola Mobility Mbp30L Digital Video Baby Monitor With 2.4 Inch Lcd Logo
51 people viewed this question
Top Motorola Mobility Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
