Panasonic Viera TV has bar of incorrect colours in top left corner of screen
I have a panasonic viera TH-P50VT20A tv that has a bar in the top left corner of the screen where the colours are wrong and slightly flicker. It shows pink/ red where it should be white and shows blue when it should be red. Any ideas how to fix? Thanks!
  • 184 Answers
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Posted on Aug 01, 2011
  • 3 Answers
SOURCE: Panasonic viera will not turn on
Try the following troubleshooting steps.Check power cord and power outlet, possible light switch problem.
Check if you TV savy check the P board if the P board is not good check the fuses on the P board.
If the P board is OK check the A board.
To check these Unplug the TV , Disconect A5 A6 and A7 on the A board and plug the TV in and see if you get a white screen if this is the case your P board should be OK.
Posted on Dec 04, 2011
bugoy31
  • 1238 Answers
SOURCE: I have left my viera panasonic plasma tv model TH-P50X10A, unpluged for two months I tried to power it up the green light flickers for a moment then slowly flashes red and the tv dosen't work.?
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Jun 19, 2012
lars_olsson6
  • 3400 Answers
SOURCE: My Panasonic Viera TH-42PZ77U tv won't turn on.
http://www.youtube.com/watch?v=qQ_iLxx3Fj4
ARE THIS RIGHT PROBLEM.?
Posted on Jul 11, 2013
gopakumarg43
  • 75571 Answers
SOURCE: Can anyone help pinpoint the issue of red screen on Panasonic TH-42PZ700U?
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jan 12, 2017
How to get netflix streaming to my Panasonic Viera TH-50PZ80U
if your tv dose not have viera cast and if viera csat does not offer netflix
you will have to connect your computer directly to the tv with hdmi
Oct 30, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Can i connect my panasonic viera th-42px8ou plasma tv,to my vista desk top? my tv has hdmi on it,my vista tower also says it has 1 hdmi connector on the back of it
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
Dec 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera TH-42PV60H displays vertical lines on left side of screen.\r\nThese lines flickers and changes colors. Initially was about 2cm wide and now it is about 4cm.
Either LCD transistor got moist or the video chipset got condensation. Keep TV on standby to dry it out. Unless there is also mechanical damage to the lcd screen on the edge..
Dec 15, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Hi, the lower half of our Viera screen is unviewab...
Yes the problem is the following.
Either the ysus board is defective or the y buffers are faulty.
more likely the ysus board.
May 20, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Panasonic viera with vertical lines down the screen which change colour randomly
Either the buffer board is bad or the plasma panel,sometimes it coult be bad connections on the interconnect ribbon cables from the plasma panel to the buffer boards.
Mar 19, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Have a black box in the top left corner of tv how can I get
check and see if your tv has PIP (picture in Picture) which you turn on and off with the remote. If you do you have PIP turned on, but not set to any station.
Nov 30, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic viera doesn't display computer correctly
Right click onyour desktop and click properties (Windows XP) or personalize (Windows Vista).
Click the tab that says Settings(XP) or the link that says Display Settings (Vista)
Adjust your resolution by sliding the bar up or down until your dispaly matched the optimum resolution of your TV.
Dec 29, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic viera 37"
I solved it switching on and off the satellite cabled on scart 1, it was like it sent some strange bits of activity, even though being turned off
Sep 27, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
Top Televison & Video Experts
