Question about Shimano WH-R540 Wheelset
RD-TY23 What is an equivalent to this 6 speed Rear Derailleur since I cannot find any for sale (Feb 2014)
4 Suggested Answers
  • 484 Answers
SOURCE: Need to replace a Shimano 7 speed SIS rear
Go to parktool.com/repair for pretty great step-by-step instructions with diagrams and pictures on the procedure. It would be easier to see than to try to tell.
i hope this helps you out,
matthew
Posted on Oct 23, 2009
Coachphil
  • 347 Answers
SOURCE: Describe your shimano xtr rear derailleur spare
Broken inner plate can be a potential warranty. Contact your local bike shop and they can process the warranty for you, if it isn't a warranty then the same shop can order you a new plate.
Posted on Dec 12, 2010
Coachphil
  • 347 Answers
SOURCE: Hi Everyone! I have a Shimano
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Posted on Dec 18, 2010
Testimonial: "Thanks v much......ok so will use my 6603 levers, 5603 Hollowtech triple chainset, then 6700 derailleurs (front and back) and 6700 cassette!!!!! "
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
Apr 24, 2015 | Shimano Cycling
How do i connect cable to front derailer on shimano comfort 050 gears ?
I'm confused, You show a rear derailleur and ask a question about a front one? Cable for front usually goes from bottom up, through an eyelet then into the holding bolt. Make sure your cable is in the low gear setting and your chain is on the smallest gear. Pull cable tight, and secure. If you have problems, take your bike to the nearest bike shop, they can help you
Sep 01, 2014 | Shimano Rd TX50 Tourney Mega Range Rear...
Fitting instructions needed for Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur with Bracket
The semi-circular spacer is what holds the derailleur in the dropout. Take the part that looks like a "C" and line it up on the drop out, the spacer goes on the other side of the dropout. There should be a screw that fastens to the spacer and clamps the derailleur to the drop out.
Apr 14, 2014 | Shimano Rd-Ty18-6-Gsd Bike Rear Derailleur...
I have a RD-TZ30 derailleur, runs great in all gears except the 6th. I have adjusted up and down 5 to 6 time on the adjustment according to the manual. It keeps trying to jump. Im at my wits end. Any...
Perhaps you have a tight link. Is it always the same place on the chain. Can you duplicate the problem in a static setting, say, with the bike suspended so you can 'pedal' it and observe what is happening at the rear?
http://www.parktool.com/blog/repair-help/tight-link-repair-ct-3-ct-5-ct-6-ct-7
or the B-screw adjustment could be such that the upper pulley is touching the cassette.
Or the RD may be bent out of alignment with the cassette.
Damaged/worn teeth on the cassette?
http://www.sheldonbrown.com/derailer-adjustment.html
See "Skipping/Autoshifting"
Frame flex/cable stiction?
Jun 30, 2011 | Shimano Xtr Rear Derailleur
Could you advise on which jockey wheels I need to suit Shimano RD-M581 and where to buy them thanks Jon
"Need to suit"????
Find all documentation here.
http://techdocs.shimano.com/techdocs/index.jsp
Then use a search engine to locate a source or just call a local bike shop.
May 30, 2011 | Shimano Rd M581 Lx Rear Derailleur, 9...
I am trying to fix a Huffy Blackwater bicycle (15 speed). The rear derailleur is missing. Can I use a 6 speed derailleur from a Next bike? Can I disable the indexing of the Huffy (Falcon) shifter? Thanks
You can use the 6 speed rear derailleur with no problems. The 5-spd shifter does not need to be disabled, as it will work just fine.
The shifter controls the rear derailleur, telling it how far to move. The rear derailluer just follows what is dictated, so there is no real difference mechanically between the 5spd and 6spd derailleurs, only in the shifter.
If you wanted to make the bike 6spd, you would have to change the shifter and gears along with the derailleur.
Dec 21, 2010 | Huffy Blackwater Men's 26-Inch Mountain...
Shimano 105 10 speed rear derailleur doesn't shift up or down well and doesn't stay in gear. Fairly new ( 250 miles)
Try this:
Set your shifter to the highest gear while turning the crank. If you have to, manually set the derailleur to the highest gear.
Release the derailleur cable by loosening its screw.
Pull the cable taut and re-tighten the screw that clamps the derailleur cable.
You should be all set.
The cable stretches over time. This can be avoided by "pre-stretching" new cables. To do this, simply shift into first gear and pull the derailleur cable away from the frame (where you are able to do so) fairly hard, several times. Then you just release and re-tighten the cable like mentioned in the steps above.
Happy riding!
matt
Allrotor13b@gmail.com
Sep 12, 2009 | Shimano Rd 5600 105 Rear Derailleur, 10...
Shimano WH-R540 Wheelset Logo
195 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
