Question about 1996 - 1999 Chevrolet Tahoe Exhaust Muffler Kit 15701 Chev
Tank pops and you can smell gas on a 1999 chev tahoe
    Master:
  • 442 Answers
Sounds like you need to check the evap system are there and
engine codes stored
Posted on Feb 11, 2014
Remove fuel pump from gas tank on 96 chev Tahoe 4door
You have to drop the fuel tank carefully (easier to do if the tank is empty). Disconnect hoses and wiring connectors from the pump/fuel level sensor. Vacuum or brush off any debris on the fuel pump and around the locking ring. Remove the locking ring and wiggle the pump assembly out.
Feb 14, 2017 | Cars & Trucks
The gas pedal does not give me power when I push the gas chev Tahoe 03
Fuel delivery problem. Fuel pump. fuel pump relay, fuel filter, trash in the tank outlet. (least likely) Sensors that also have imput to ECU that controls the above. Possibly the throttle position indicator or it's connection/s or Mass air flow meter.
Mar 31, 2015 | 2003 Chevrolet Tahoe
Gas smell
I have a 1999 Chevrolet Lumina with the 3.8L engine. In 2009 I also smelled fuel when I drove my car. My leak was located at the fuel rail output connector. Chev house said I had to replace the entire fuel line all the way back to the tank. Say what? I easily fixed the problem by installing a NAPA #7304922 3/8" Nylon Fuel Line Retainer (repair kit - $25).
Mar 22, 2014 | 1996 Chevrolet Lumina Mini
Gas smell at rear of 1997 tahoe
Could be the gasket on top of the tank or one of the vent lines.
Is the check engine light on ?
Sep 29, 2012 | 1997 Chevrolet Tahoe
My 1999 chev. tahoe backfires when i step on the gas
The problem sound like you have too much back pressure building up in the exhaust. Start by disconnecting the exhaust Y-pipe. Then start the engine and run again if the engine does not back fire, reconnect the exhaust everything after the Y-pipe. If the problem returns it is safe to say that the catalytic converters are clogged and need to be replaced.*** Make sure you use PB BLASTER or LIQUID WRENCH on the exhaust bolts to help with removal.***
Mar 29, 2012 | 1999 Chevrolet Tahoe
2002 Tahoe gas leak on top of tank
The top where the pump goes in is could be leaking. Have it checked ASAP, a gas fire is a dangerous thing.
Jan 28, 2010 | 1998 GMC Safari
2000 Tahoe, I smell gas after I turn off the
May be nothing more than a faulty gas cap or vent hose from the tank to the filler neck. Your charcoal canister for the fuel evaporation system may not be purging. It could be filling up with gas. It will eventually overflow, allowing you to see the problem.
Dec 29, 2009 | 2000 Chevrolet Tahoe
Does replacing a blown rear brake line involve the
Shouldn't unless they had to remove the gas tank to get to the wounded part of the brake line. They most likely had to, which in turn they had "trouble" getting the fuel lines to separate, and then, before you know it your putting a new $500 fuel delivery module to repair a $15 brake line.
Jun 24, 2009 | 1996 Chevrolet Tahoe
1996 - 1999 Chevrolet Tahoe Exhaust Muffler Kit 15701 Chev Logo
44 people viewed this question
Top MagnaFlow Vehicle Parts & Accessories Experts
Johnathan Lence
Johnathan Lence
Dan Horsefield
Dan Horsefield
ray gallant
Are you a MagnaFlow Vehicle Part and Accessory Expert? Answer questions, earn points and help others
