Question about Air Tools & Compressors
I have a westinghouse RS652M side by side fridge freezer. Worked great for 10 yrs in kitchen, now in shed & trips circuit breaker (clipsal safety switch) after 6 hrs of use. Compressor tank is ver
Unit has been faultless for 10 yrs, now since I moved it, it trips the Clipsal safety switch after about 6 hrs of use. Ive tried different powerpoints with same result.
4 Suggested Answers
  • 14 Answers
SOURCE: Compressor won't restart with any pressure in tank
try replacing the capacitor. a bad start capacitor will not let it start under a load.
Posted on Jul 19, 2009
  • 98 Answers
SOURCE: breaker relay tripping out
If the unloading valve trips , which i think is the safety valve that tells me the compressor is pumping up past its maximum allowed pressure. that black switch should be the overload switch. check the amps of the wires going to the motor while its running and then look at the name plate of the motor to see the maximum amount of amps that the motor is allowed to draw.
Posted on Jul 21, 2009
  • 2468 Answers
SOURCE: compressor starts innitially,then when pressure
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Posted on Mar 19, 2011
Circuit breaker tripping
Sounds like the electric motor in the fridge may have shorted out some of the windings which is causing it to draw more current. You should get one of those clamp on amp meters to see how much current it is drawing when it first kicks on.
Jan 23, 2014 | Admiral 26 cu. ft. Side-By-Side...
Fridge/freezer keeps tripping
Try to plug into different circuit, if it trips that breaker on the board then the appliance is probably at fault.
I must assume that you have not acquired something plugged into the same circuit as the fridge.
Sep 26, 2017 | Beko Refrigerators
My FFA70 fridge/freezer is causing my circuit breaker to trip, when I reset the circuit breaker the fridge/freezer will work again, but both the red bight temp warning light and the freezer defrost light...
kevinmdoyle... Hello and welcome to FIXYA,
Yours is a UK model... so I (usa) can't help you
on SPARES (motor start capacitor) ... however
Circuit breakers do go bad...!!
(easiest & cheapest to check first)
MUCH Easier to test the idea than you would imagine:
- Shut OFF your main breaker.
- Open your panel & swap the wire with an EQUAL breaker
- Tag the wires (to restore when finished trouble shooting)
- Restore the main breaker (wait & see)...
and don't forget to clean that CONDENSOR
per owner manual instructions.
If the failure persists... RESORE the BREAKERS.
and
HOPE it is the START CAPACITOR on your compressor.
Carnac the Magnificent
Jan 15, 2018 | Hotpoint Freezers
My side by side refrigerator started tripping the ground fault protector on the plug after being in the garage and working well. I have had the refrigerator for 10 years and this is the first problem I...
First question I would have is if the outlet is a dedicated line with nothing else on it. Also, does the GFCI in question have a high enough amperage rating for the refridgerator. Next, make sure the circuit breaker is not also a GFCI circuit breaker. You cannot have a redundant GFCI in the same circuit, one or the other. It can be very tricky to put an appliance like that on a GFCI circuit due to its compressor motor. Motors have a large amperage draw on them when they start so, if your fridge runs at around 10 amps, it can take three times as much to start (30 amps) which would trip a 20 amp GFCI.
Nov 29, 2010 | Frigidaire FRT15G4B Top Freezer...
My fridge trips the breaker when you try to turn it on
I have a couple of things for you to check or rule out. Today, a refrigerator is required by electrical code to be connected to a dedicated, 15 amp outlet because the newer fridges are more efficient and use less than 12 amps. Not long ago, a dedicated 20 amp outlet was required because the older fridges were rated to use 12 amps or more (but less than 16 amps) and needed the larger size circuit. A 20 amp circuit breaker or fuse should not open for any standard residential fridge under normal operating conditions. A 15 amp circuit breaker or fuse _MAY_ open if an older fridge (needs 12 amps of more) is connected. Make sure that if a circuit is opening at the fuse or breaker, it is not because there are several appliances or devices in use and on the same circuit as the fridge.
The same holds true for "ground fault" and "arc fault" type circuits. If an older fridge is connected to such a circuit - nuisance tripping may result. Most newer fridges however shouldn't cause a problem on these circuits. Ground fault circuits have a "test" button on the circuit breaker or, "test" and "reset" buttons on an outlet providing this protection. Arc fault circuit protection is available only in circuit breakers (as of this time - but may become available as outlets some time in the future).
If you need to to try to isolate the problem on a 20 amp circuit, disconnect all other appliances on the other 20 amp circuits in the kitchen and dining room, then see if the fridge stays running. Alternatively, you could use a heavy duty extension cord to connect the fridge to a known isolated 20 amp circuit to see if the fridge runs. This is meant only to troubleshoot - the fridge should not be left connected via extension cord for normal operation.
If you still have tripping, you might need to have the fridge professionally serviced, as a ground fault could be a dangerous condition left unchecked.
Please rate this replay id found to be helpful - good luck!
Jul 07, 2010 | Frigidaire Refrigerators
No power while plugged
It probably has a circuit breaker located on the bottom of the fridge, behind the front filter. Also try looking inside the refridgerator side at the top. It may be red colored to indicate it is safety-related. Just push it in - but don't be surprised if it trips again.
WARNING: RESET ONLY ONCE TO AVOID A FIRE OR ELECTROCUTION SITUATION.
You may have an internal problem, in which case the freezer's circuit breaker is your best friend!
Note that the self-defrosting freezers have a timer that shuts them off periodically so they can defrost. Sometimes the timer does the defrosting in the middle of the day, giving the appearance of a failure. This could be your problem.
Oct 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Fridge tripping breaker, ice maker shorting out
Sounds like you have a short in the freezer .Double check all electrical wires with a meter .
I would also check on that bedroom outlet because sounds like that outlet is not grounded
May 26, 2017 | Frigidaire GS26HSZDW Side by Side...
Westinghouse Virtuoso Fridge - Circuit Diagram
It won't be the defrost timer, unusual, it will be the defrost element inside the freezer section behind the back panel or a shorted defrost klixon.
Mar 30, 2008 | Refrigerators
Fridge/freezer trips my circuit breaker
This sounds like a grounded wire in your defrost system. Start by finding the defrost timer and checking the wires. One may have been pulled loose or pinched while it was being moved.
Dec 12, 2007 | Refrigerators
Air Tools & Compressors Logo
41 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
