Question about Drills
Bosch battery 24v charger red light flashing before i put battery in
emissionwiz
  • 79865 Answers
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
Posted on Nov 07, 2008
hawk127311
  • 350 Answers
SOURCE: dc1804f charger
If you have tried discharging the batteries prior to charging them already with no result and from what you describe in your post, then I would have to say the charger has issues. Go to HD or Lowes (not sure if Lowes carry Makita) but another charger and test your battery again. If you get the same fault, there is an issue other than the charger, if not you need a new charger anyway. If you get the same fault with the new charger, you can always return the new one. Short of opening up the charger and using a volt meter, this is the easiest way to test to pinpoint the real problem. I hope this helps and good luck!
Posted on Nov 06, 2009
  • 583 Answers
SOURCE: The red light always flashing when the charger is empty
many chargers do that ,i think it is to let you know thy are on and need to be turned off, when not in use
Posted on Nov 17, 2009
rowdy45176
  • 2176 Answers
SOURCE: when put on charge the green and red light flash
that usually indicates a bad battery. I would unplug the charger for a couple minutes to reset it and then try again before looking at replacing the battery. Most shops have a tester there that can tell if it is in fact bad.
Posted on Jan 23, 2010
SOURCE: I have a Black Max 24V, model JD610424 and when I
Charge for no more than1 hour ..any longer and you have to start over ....don't know why the red light won't come on, but after a few tries, I just observe the less than 1 hour time limit.
Posted on Apr 29, 2010
One red light flashes. I know the batteries are charged 17v. I've checked all connections. apmeter reads zero. What else should i check?
17 volts is a sign of one battery bad, or both. How old are the batteries? Check each battery separately for at least 12v. Check at the batteries themselves. If you don't get the 12 or greater reading replace the batteries. If you don't have insurance check at batterysharks.com.
Jan 20, 2015 | Pride Jazzy 1103 Ultra Standard Power...
Dewalt de0245
These de0245 chargers are designed to detect certain problems that can arise with battery packs which would be indicated by the red light flashing at a fast rate.
If this occurs, re-insert battery pack. If problem persists, try a different battery pack to determine if the charger is OK. If the new battery charges correctly, then the original pack is defective and should be returned to a service centre for recycling.
If the new battery pack gives the same trouble indication as the original, have the charger tested at an Authorised Service Centre.
If you need new battery for this tools
Mar 23, 2014 | Drills
Hitachi cordless drill charger not working
The various rates of flashing are error indicator codes and should be explained on the charger case. They are for the condition of the battery's though and not the charger. It sounds like the charger itself is bad. Can you return it for a replacement? Is it still in Warranty? For whats its worth, I went from Milwaukee tools to Bosch to De Walt before being satisfied with performance. I hope this helps.
Dec 14, 2013 | Hitachi UC18YRL Universal Charger for...
I need to know how to wire the batteries together on my shoprider jimmie chair so they will charge
If the charger is 24 volts and you have 2 12 volt batteries they have to equal 24 volts , so wire the batteries terminals red to black and connect the charger to the other terminals red to red and black to black.
Feb 10, 2012 | Shoprider Jimmie Power Wheelchair
My Duracell battery charger has a blinking red light.Use to be a constant red then green when it was charged. Now, just red..then blinking red..then not at all.
I had the same problem with flashing red lights. Both sides on a four battery charger. I swapped the batteries to another charger and the batteries were fine. They charged normally. I put some different batteries in the charger and the same flashing light situation. Those batteries also charged normally in a different charger. I looked closely at the back of the charger and, low and behold, "made in China". Why does that not surprise me. The bottom line, it may not be a battery issue.
May 08, 2010 | Duracell NiMH AA/AAA Battery Charger with...
I have a Black Max 24V, model JD610424 and when I put the battery in the charger, nothing happens. I just cannot charge the battery. ****
Black Max 24v power drill
Allied International sells them at 1-800-248-6657, drill part # JDB240R. Have the part number from your drill available (on the label on side or top of drill...a number like 33643)
Mar 07, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
Have 24v sds drill older type the one with the charging lights on 2 of the batteries will no longer charge just go to red on charger unit can they fixed
not sure on the charge well have to check out but contact a interstate battery shop thy can rebuild most batteries
Oct 12, 2009 | Bosch Drills
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Drills Logo
118 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
